Author Topic: [IC] Polycarb Switch Films from Kin (GB live)  (Read 22638 times)
Offline xondat
  • i'm not a star
Re: [IC] Polycarb Switch Films from Kin
« Reply #50 on: Sun, 03 December 2017, 13:21:07 »
Your vid helped me finally understand how these help. Is it correct that the wobble is only reduced on PCB mounts? I can't seem to move mine on a plate like that
Doesn't matter if plate/PCB, once the tops have been removed, there is still wiggle room.
Offline feediko
« Reply #51 on: Sun, 03 December 2017, 14:40:38 »
In for at least 3-5 packs depending on the colors.
Offline n0rvig
« Reply #52 on: Sun, 03 December 2017, 15:13:07 »
+1 I’d be down for a couple. I’m not sure about the colours yet.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #53 on: Sun, 03 December 2017, 19:13:48 »
I'm in for a couple of packs of the clear ones.
Offline Kavik
« Reply #54 on: Sun, 03 December 2017, 23:39:34 »
Is it only recommended to use these if one has already taken apart the switch for other reasons? I did the same test on my Zealios and MX Blues which are both plate mounted, and the top housings wiggled. (I've never disassembled any of them).
« Reply #55 on: Mon, 04 December 2017, 01:29:12 »
they're good either way
Offline xZ3ROx
« Reply #56 on: Mon, 04 December 2017, 05:16:18 »
I'd be in for 2 packs
Offline MeloDet
« Reply #57 on: Mon, 04 December 2017, 10:12:22 »
I'd be in for 2/3 packs
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #58 on: Mon, 04 December 2017, 13:15:31 »
Thanks everyone for the great response to this.
I went to the post office today and it appears I was very close with my estimates. The included insurance is up to 25€, every additional 100€ (so for 26-125€) costs another 2€ postage. I'll be declaring all shipments correctly, I don't really see the need to undervalue a shipment that is probably around the 15-25€ mark for most anyways, and only the declared value would be refunded on insurance claims.
I've also talked with Kin and we are looking into offering 3 more colors, he'll let me know how close these can be reproduced as the factory uses dye-sublimation which is known for being hard to work with for saturated colors.
I'll now go hunt down a seasoned GB runner on Slack/Discord for how to best setup order collection (a google form probably) and think we can launch this at the end of the week or so.
Edit: finished setting up the google sheet, I'm confident that all information is collected. Waiting for kin to confirm the new colors now.
« Last Edit: Mon, 04 December 2017, 15:41:00 by Oblotzky »
Offline Vadurr
  • Valar Morghulis
« Reply #59 on: Mon, 04 December 2017, 13:34:13 »
This is great news! Color me interested for our three new colors :]
Offline vtachkov
« Reply #60 on: Mon, 04 December 2017, 17:47:25 »
Thanks for the update. I'd definitely be down for a couple more packs of the cyan if Kin confirms it.
Offline typischt
« Reply #61 on: Mon, 04 December 2017, 17:55:47 »
I know, it is probably obvious with all the color choices, but I still like to ask: Are the colors actually visible when installed on a board and if so, how?
Envoyé de mon iPhone en utilisant Tapatalk
« Reply #62 on: Mon, 04 December 2017, 17:56:53 »
they are visible, but not when you have keycaps on
Offline typischt
« Reply #63 on: Mon, 04 December 2017, 18:36:58 »
Perfect, thanks a lot!
Offline Kafka
  • i like clean things
« Reply #64 on: Mon, 04 December 2017, 19:03:26 »
https://imgur.com/a/sH685
Canoe with white films
Offline typischt
« Reply #65 on: Mon, 04 December 2017, 19:09:23 »
Ah yeah, I see. Thanks a bunch!
Is this your Canoe?
Offline Kafka
« Reply #66 on: Mon, 04 December 2017, 19:11:44 »
Is this your Canoe?
Nope, guy on mechmarket is selling it
Offline FreeCopy
« Reply #67 on: Mon, 04 December 2017, 19:29:21 »
I want at least 3 sets. Pink, white, and clear. Depending when the buy launches I could go for more.
If other colors are possible I'd love a light blue.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline kin25
    • TXKeyboards
« Reply #68 on: Mon, 04 December 2017, 20:01:58 »
thank you~
I don't want to make you wait for a long time.
so I ordered factory to make new 3 colors.
It will make waiting time shorter after your order.
Offline funderburker
« Reply #69 on: Tue, 05 December 2017, 00:31:00 »
thank you~
You are amazing. Best vendor ever. :)
Keyboard design by Skepur
« Reply #70 on: Tue, 05 December 2017, 00:33:22 »
thank you~
golden god
Offline cocobrais
« Reply #71 on: Tue, 05 December 2017, 01:49:09 »
thank you~
always amazing!!
Offline Oblotzky
« Reply #72 on: Tue, 05 December 2017, 08:40:53 »
thank you~
Great to hear!
I have just posted the GB thread, awaiting approval now. Once approved, this IC can be closed. Thanks!
Edit: Live! https://geekhack.org/index.php?topic=92878.0
« Last Edit: Tue, 05 December 2017, 09:37:17 by Oblotzky »
Offline tanvir175
Re: [IC] Polycarb Switch Films from Kin (GB live)
« Reply #73 on: Tue, 05 December 2017, 12:18:10 »
If you have a floating key design keyboard and transparent switches, wouldn't they still be visible even with the keycaps on?
I saw a video on TaeKeyboards where he used pink stickers with transparent switches and a floating key design case so you were still able to see them from certain angles even with keycaps on.
