Author Topic: Need some qmk assistance  (Read 1641 times)
Offline R0b
« on: Fri, 01 December 2017, 11:20:28 »
So I just completed a DZ60 build and I’m trying to optimize my layout. I play MMOs and my plan was to utilize a function key in the same way you would a standard modifier to give me more functionality of my number row. However, I have this issue that when I trigger a function key it interrupts any other commands that were previously being sent. ie I’m strafing by holding down E and then use my Fn key to swap layers and gain access to F keys on my number row but my E command is interrupted and I stop moving.
Using qmk firmware builder I’ve configured my movement keys to be transparent on the function layer and if I re-press my keys everything continues as normal, but I can’t have my movement commands interrupted every time I swap layers. Is there a way around this issue?
I also plan on configuring the Fn key in question as a multi touch key with layer mod capabilities when held and an alternate key command when tapped. Would this complicate any possible solutions to the original issue?
Offline ander
  • I type, therefore I am
Re: Need some qmk assistance
« Reply #1 on: Mon, 04 December 2017, 23:00:28 »
Hey, sorry for my stupid irrelevant post here the other day.. I shouldn't be allowed near a keyboard when overcaffeinated. Hope you get some help with your questions.   :thumb:
