Author Topic: Trying To Find Simple Keycaps  (Read 4951 times)
Offline Areyn13
« on: Fri, 01 December 2017, 13:38:09 »
So I was wondering if anyone could help me find a simple keycap set... I just need White ABS keycaps, without the overly aggressive "gamer" font that supports backlit boards. I generally enjoy a more smooth texture to my keycaps, so high quality ABS is my best bet. Something similar to this:
I tried finding that exact set but to my knowledge, it's discontinued  :(
Re: Trying To Find Simple Keycaps
« Reply #1 on: Fri, 01 December 2017, 14:10:16 »
« Last Edit: Fri, 01 December 2017, 14:12:22 by Puddsy »
Offline Tactile
« Reply #2 on: Fri, 01 December 2017, 14:58:54 »
REΛLFORCE
Offline aspenc4
« Reply #3 on: Fri, 01 December 2017, 15:57:58 »
Ice caps are such a nice set; high quality ABS, smooth and just tastefully done. Check them out -
https://pimpmykeyboard.com/sa-ice-cap-keyset/
Offline Areyn13
« Reply #4 on: Sat, 02 December 2017, 05:59:30 »
Thanks for the replies, I might try out the Vortex PBT set.
That being said, what's the difference in texture compared to standard/mainstream ABS keycaps?? I know PBT is generally mean't to be grainier, but as someone who's only ever used ABS and likes the smoother (almost rubberized feel) will this be a noticeable change?
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Sat, 02 December 2017, 08:46:04 »
Vortex caps are quite smooth actually. Smoother than Cherry and definitely not as rough as DSA, for example.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #6 on: Sun, 31 December 2017, 17:44:14 »
Unfortunately this is out of stock:  https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1579
If you can find this elsewhere it would be more ideal.
As you've mentioned ABS and PBT will have a different texture and different feel to them, the above link I linked is double shot ABS.
