Author Topic: SA set for 40% keyboards  (Read 4288 times)
Offline asdflkweoiaf23452
« on: Fri, 01 December 2017, 14:58:39 »
Has anyone outfit a staggered 40% with SA keycaps?  How did you do it?
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: SA set for 40% keyboards
« Reply #1 on: Mon, 04 December 2017, 00:18:37 »
I pressed them down straight as possible onto the stem.   :p
I assume you're looking for 1U labeled stuff thats the correct row sculpt and things like that.. yes it would be difficult with out buying a "planck" add-on set or something that was specific to the weird setups.
Another option would be to buy all 'row 3' caps. I know you can buy them individually here but there was another website in England that had some sets also but I cant think of it. Maybe someone else will post it up.
-Dana
Offline bitzie
« Reply #2 on: Fri, 29 December 2017, 12:05:14 »
I outfitted my Vortex Core with SA vomit from grab bags. It's row 2 for the uppermost and row 3 for the rest. I would have like to have them properly rowed, but that's the best I could do. So far I'm loving it. It feels way better than the DSA set I had on it previously.
