Author Topic: Where to find 1.5x right shift key?  (Read 10446 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Sat, 02 December 2017, 16:40:02 »
Just ordered a e element z88(impulse buy) and I'm really not a fan of the stock keycap font. I can't seem to find anything that has a 1.5(I think is correct size), anywhere I can custom order something?
Keyboard in question https://www.amazon.com/Element-Mechanical-Keyboard-Waterproof-Anti-Ghosting/dp/B01FXF7HFC
I saw this massdrop https://www.massdrop.com/buy/tada68-aluminum-mechanical-keyboard and that shift size is wonky  too. Ideally I'd want  a white pbt set.
« Last Edit: Sat, 02 December 2017, 16:41:53 by C5Allroad »
Offline Tactile
Re: Where to find 1.5x right shift key?
« Reply #1 on: Sat, 02 December 2017, 16:59:15 »
[EDIT]Sorry, I typed too fast. it doesn't look like your 1.5 rshift is there.[/EDIT]
You can do it with the Ice Cap set + the Alternate kit. These are very nice keycaps, BTW.
« Last Edit: Sat, 02 December 2017, 17:03:09 by Tactile »
REΛLFORCE
Offline C5Allroad
« Reply #2 on: Sat, 02 December 2017, 17:19:36 »
Thanks for the link. The search continues for a 1.5u shift key.
Offline desal
« Reply #3 on: Sat, 02 December 2017, 20:30:13 »
Look like a 1.75u to me, and that's what i'd expect given the rest of the layout which looks more or less standard left of right shift.
Offline C5Allroad
« Reply #4 on: Mon, 04 December 2017, 18:11:53 »
It's the same size as the backslash key. :/ This is going to be interesting cause the stock caps aren't that bad but they're not great. Thankfully they're not smooth.
Offline enero30
« Reply #5 on: Mon, 04 December 2017, 21:30:23 »
Have you checked out WASD? Their not the best, but they’ll have what you need if you’re looking for OEM keycaps. You can have anything printed on it. I had to do this for my Drevo Excalibur which has a 1.75 right shift key.
http://www.wasdkeyboards.com/index.php/products/printed-keycap-singles/custom-text-cherry-mx-keycaps.html
Offline C5Allroad
« Reply #6 on: Tue, 05 December 2017, 14:05:25 »
I think what I'm going to do is get a set of pbts, and then I'm going to use one of the 1.5u keys from the first row on the shift key. Thanks for the help guys
Offline xondat
  • i'm not a star
« Reply #7 on: Tue, 05 December 2017, 14:13:49 »
Tada68 has a 1.75u shift?
Offline C5Allroad
« Reply #8 on: Tue, 05 December 2017, 20:24:05 »
From what I can see it does.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #9 on: Thu, 07 December 2017, 02:11:33 »
you could always make a custom one if you really needed: http://www.maxkeyboard.com/custom-art-icon-or-text-cherry-mx-keycaps.html
-Dana
Offline xondat
  • i'm not a star
« Reply #10 on: Thu, 07 December 2017, 02:20:36 »
Ohh... My bad.
I clicked on the wrong link.
GMK don't have the mold (or at least no one uses it), not sure about other common profiles.
