Author Topic: Removing legends  (Read 6289 times)
Offline ninjacore
Removing legends
« on: Sun, 03 December 2017, 16:11:01 »
What’s the easiest way to remove printed legends? I know I could buy blanks, but I’ve got a couple sets of printed caps I’m not using and I’d like to use the modifiers, but they wouldn’t be “correct”.
Offline Duckyreddy
  • Better skadoodle, poodle.
Re: Removing legends
« Reply #1 on: Sun, 03 December 2017, 16:55:06 »
Pad Printed? If so, it might be as easy as scratching them off.
Ducky One Cherry MX Silent Reds
Leopold FC660M MX Blue
Logitech G403/ Razer Naga 2014
« Reply #2 on: Sun, 03 December 2017, 17:00:32 »
70% isopropyl alcohol and a paper towel
Offline ninjacore
« Reply #3 on: Sun, 03 December 2017, 20:44:02 »
Combination of pad-printed and front-printed sets.  I'll try the alcohol before the scratching :)
I saw something about alcohol having the potential to ruin caps. Is that only with really high percentages?
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #4 on: Mon, 04 December 2017, 00:13:18 »
Alcohol does funny things to acrylics but i think more ABS type stuff should be ok. I also remember someone posting up a set of Realforce black caps that got kinda faded from alcohol?
Best bet would be to grab an esc key or something easily replaceable and test it out there first.
-Dana
