Author Topic: [opensource] GH80-3000 | Cherry G80-3000 replica  (Read 489147 times)
Offline TalkingTree
    • My projects
Re: [opensource] GH80-3000 | Cherry G80-3000 replica
« Reply #150 on: Fri, 29 May 2020, 06:22:44 »
Woops :-[
What clock rating should be used? (If this is explained elsewhere I'm truly sorry)
16 MHz is mandatory. By the way, I had already put a crystal and capacitors in the BOM list so you should be ready to go.
Offline DevilZmods
    • Etsy Shop
« Reply #151 on: Sat, 13 June 2020, 12:48:43 »
I'm looking to get some of these made and shippied to germany, but shipping is just as much as the pcbs themselves even before tax.
I Also fiddled around with smt assembly, but somehow the components don't align (identical misplacement within each component type) and i don't know how to "re-assign a correct 0 orentation package" which should be the definitive fix for the issue.
Is anyone interested in a blank pcb + components from lcsc? I might be able to assemble a few boards as well as i recently acquired a hot air soldering station.
Even better would be, if anyone could help me modify the project to make use of JLCPCBs (more or less - but advertised as) free smt assembly service!
I'm from germany, so at least the logistical part of this would be limited to the EU.
Offline IkabodLame
« Reply #152 on: Thu, 18 June 2020, 11:13:34 »
Hi, I'm in the UK and I would be down to put in for a group buy of these PCB's. I wouldn't be able to help in terms of modifying it for the free SMT, but I might be able to ask around and see if I can find some help with regards to it.
Offline AngryCoder
« Reply #153 on: Fri, 19 June 2020, 19:33:48 »
I am still interested an also from Germany. But I only have a TS100 at hand, not hot air soldering station, so for the first board an assembled one to start with is definitely a plus. But I am also interested to solder one by hand, because why not :D. On the long run I would also like to try to modify the files myself. But this will take time as I have no background in electronics. I'll write you a PM for further communication.
Offline Azurewrath
« Reply #154 on: Mon, 22 June 2020, 14:52:03 »
Btw. could it be that your diode pads are too small/narrow? Or did i order the wrong diodes? It's almost impossible to solder a nice joint on both sides, since the contact is always at the absolute edge on one side. No matter if hand soldering or paste plus hot air..
I'm using 1N4148W in a SOD-123 package.. just as you wrote.
Edit: Yeah.. just checked. They are a bit too small. Looks like you used normal 0805 pads for the diodes, but they should be bigger/wider?
I mean, it's possible to make it work.. but it's a pain in the ass.
« Last Edit: Mon, 22 June 2020, 15:53:38 by Azurewrath »
Offline Rayndalf
« Reply #155 on: Sat, 05 September 2020, 06:17:46 »
I've figured out how to load the gerber and bom into JLCPCB, but I'm having troubling generating the correct pick and place file (the SMD components appear rotated 90 degrees and offset).
This is strange because the PCB appears correct in the 3D view in EasyEDA, but I have to export the files and load them into JLCPCB because the site integration between EasyEDA and JLCPCB isn't working for me.
Any idea what to do (other than learn to SMD solder :p)
« Last Edit: Sun, 06 September 2020, 01:52:22 by Rayndalf »
Offline Rayndalf
« Reply #156 on: Sun, 06 September 2020, 01:53:00 »
I figured out how to manually edit the CPL file for component placement. I have confirmed the orientation of the diodes, clock, and ATMEGA32... does capacitor orientation matter?
Offline TalkingTree
    • My projects
« Reply #157 on: Sun, 06 September 2020, 13:20:32 »
Only if they are electrolytic and on this board they are not.
Offline Rayndalf
« Reply #158 on: Sun, 06 September 2020, 16:29:17 »
So are the crystal, diodes, and ATMEGA the only components that require a specific orientation? Is it fair to assume that all the other components aren't polar?
It looks like every part except for the USB C connector is supported for SMT assembly, so I guess I'll have to attach those myself.
Would it be alright if I ran a group buy for this board (after I order a set and can confirm that they work?)
« Last Edit: Sun, 06 September 2020, 16:47:37 by Rayndalf »
Offline TalkingTree
    • My projects
« Reply #159 on: Wed, 09 September 2020, 16:14:48 »
Technically the crystal isn't, you could turn it 180° without a problem.
The USB type C connector has through hole mounting but, if you look closer, you'll notice the connection pins are actually SMD.
License is CC-BY 3.0. You can even sell it for your own profit. You just have to share any modification you make, if you then sell the board.
Offline Rayndalf
« Reply #160 on: Wed, 09 September 2020, 16:49:37 »
As for the USB C connector I meant that JLCPCB's SMT assembly service doesn't support the component, but I'm sure I can install it myself.
If the first 5 I order work I will run a group buy if there is interest. The only modification I've made is fixing the pick and place file generated by EasyEDA, but I'd be happy to share it once I can confirm it works.
Offline Rayndalf
« Reply #161 on: Wed, 09 September 2020, 18:13:29 »
I finally go to place an order and there is an inventory shortage of the ATMEGA32U4
Guess I'll have to wait to place an order until they restock.
Offline TalkingTree
    • My projects
« Reply #162 on: Thu, 10 September 2020, 06:59:49 »
Try LCSC.com
Offline Rayndalf
« Reply #163 on: Wed, 16 September 2020, 02:07:41 »
The ATMEGA32U4 was restocked. Assuming the first order works I'll start an IC in the next 2 weeks.
Offline Rayndalf
« Reply #164 on: Thu, 17 September 2020, 15:37:36 »
So uh... JLCPCB decided the diode footprints were wrong so they... decided to flip the diodes?
Here is the original orientation
251886-0
and here is how they decided to correct it
251888-1
I'm hoping I'm the one who made a mistake and they're fixing it, but otherwise  :'(
Offline TalkingTree
    • My projects
« Reply #165 on: Thu, 17 September 2020, 15:41:10 »
Why on God's green earth?
That's guaranteed not to work.
Offline Rayndalf
« Reply #166 on: Thu, 17 September 2020, 15:49:18 »
I originally flipped the diodes because of an issue with the preview of the pick and place, but I rotated it around 90 + 180 instead of just 90(?) because the pick and place preview was upside down. I think they actually saved me from double stupid.
Edit: If the line on the diode is negative then positive side facing up is consistent with the image in your second post.
« Last Edit: Thu, 17 September 2020, 15:52:33 by Rayndalf »
Offline TalkingTree
    • My projects
« Reply #167 on: Thu, 17 September 2020, 16:04:46 »
It is.
Offline Rayndalf
« Reply #168 on: Thu, 17 September 2020, 16:11:18 »
It is.
In that case then despite my best efforts JLCPCB will ship me some functioning boards.
I... I really think I need to brush up on my understanding of electrical engineering. My university touch on it in physics, but success (and sanity) in this hobby requires a bit more than being able to work a soldering iron.
Offline TalkingTree
    • My projects
« Reply #169 on: Fri, 18 September 2020, 09:56:38 »
My university taught me a whole different set of things, and I still managed to make some working boards. Anyone can succeed.
Offline Rayndalf
« Reply #170 on: Tue, 29 September 2020, 23:52:33 »
The boards arrived, and I can safely say the switch alignment holes are painfully tight, but the PCB fits the case well (and if I drill the out some of the case supports I can bolt it shut for greater stability).
This one is shaping up to be a "scrap" build. Hopefully I don't regret installing the switches (not soldered yet, but still painfully tight) before I get a USB C connector attached.
Offline heavyheaded
« Reply #171 on: Mon, 19 October 2020, 01:51:15 »
So I've built one of the old rev with the misalignments and whatnot, but I had to use 3-pin switches b/c I couldn't get any 5-pin switches to fit.
Now I'm looking to order probably 10 or so PCBs, but I'm worried about the switch aligment holes still being too tight in the new revision.
Has this been addressed in the new rev, or can someone explain some easy steps for a PCB design noob to fix the holes with kicad? Are there settings in the JLPCB order that change the fit?
Offline Rayndalf
« Reply #172 on: Mon, 19 October 2020, 15:42:04 »
Yes, they are painfully tight to assemble with modern MX blues (which should be standard Cherry spec).
The callus I got from installation just broke yesterday :-\
Offline DevilZmods
    • Etsy Shop
« Reply #173 on: Tue, 20 October 2020, 14:39:42 »
Hey @Rayndalf thanks for putting in the legwork here. I'd be interested in getting involved in a potential groupbuy by designing a vectorgraphic to put on the back of the board. Maybe something cherry (company) themed.
Offline Rayndalf
« Reply #174 on: Thu, 22 October 2020, 02:34:37 »
;) I didn't do anything except ask a bunch of question and still almost screw my order up.
I'm still waiting on USB C connectors, but the PCB I hardwired seems to work (I only checked a few pads, I was missing my trusty conductivity testing fork).
I guess there's a chance I could run a buy, but I'd definitely need to figure out why the switch holes came out so small for me (but not for other orders). Either way I'll be wearing gloves next time.
Offline TalkingTree
    • My projects
« Reply #175 on: Thu, 22 October 2020, 07:13:33 »
I just updated the current revision with an increased center hole diameter in the footprint.
Offline Rayndalf
« Reply #176 on: Thu, 22 October 2020, 12:08:08 »
My central "spring" holes were properly sized, it was the 2 smaller PCB mount holes that were small. Not sure if others had the same issues I did though.
Offline TalkingTree
    • My projects
« Reply #177 on: Thu, 22 October 2020, 12:16:33 »
Spec sheet states they should be 0.059 in +/- 0.002. Mine are 0.06 in.
Offline Rayndalf
« Reply #178 on: Thu, 22 October 2020, 14:05:31 »
I think it was either a mistake I made (scaling the submitted PCB?) or a problem of JLCPCB's end.
I assume the PCBs you received snugly held PCB mounted switches (but wasn't a thumb breaker).
Offline TalkingTree
    • My projects
« Reply #179 on: Thu, 22 October 2020, 14:35:20 »
Indeed. The center hole what a bit tight but not painful to deal with at all. The connection holes were just fine.
PCBs shouldn't be scaled at all.
Offline Rayndalf
« Reply #180 on: Thu, 22 October 2020, 20:32:02 »
JLCPCB lists the dimensions as manufactured as 436.7 mm* 133.1 mm. Is that consistent with the order you had fullfilled?
Offline TalkingTree
    • My projects
« Reply #181 on: Fri, 23 October 2020, 01:08:57 »
Should be appropriate.
Offline Rayndalf
« Reply #182 on: Fri, 23 October 2020, 02:12:01 »
Guess I just got "unlucky". They caught my diode issue and the boards seem to work so I don't really have any reason to complain. I guess I'll wear gloves next time I try to install switches.
Offline dredwerker
« Reply #183 on: Wed, 28 October 2020, 04:17:20 »
Hi all
A redditor put me on to this thread. I have an MY8300 and I really want to get a few of these pcbs. I tried downloading the EASYEDA gerber file and the bom and pick and place. Most of the pick and place stuff wasn't ready to be manufactured. Has anyone got a link on how order one of these PCBS with the pick and place done?
Or just to buy a few of these pcbs populated apart from the the switches?
I can solder switches but smd looks scary. :)
Also, has any one connected two pcbs together as my MY8300 has another double row at the top.
Thanks in advance all
Offline TalkingTree
    • My projects
« Reply #184 on: Wed, 28 October 2020, 06:43:02 »
Mind the different layout. The MY8300 has two extra top rows and this PCB doesn't.
Offline Rayndalf
« Reply #185 on: Wed, 28 October 2020, 12:56:43 »
Hi all
JLCPCB only need a Gerber, a Pick and Place file, and a Bill of Materials.
You can download the BOM from here https://easyeda.com/farmakon/GH80_3000-4f3cee521afd4be3858c4b5cc3b76f9e then open the EasyEDA file "in the editor"
Once you have that file open in EasyEDA you can go to File - Generate PCB Fabrication File(Gerber) to create a zipped Gerber file and generate the Pick and Place using the File - Export Pick and Place File. I found the diodes where showing up incorrectly when I loaded it into JLCPCB. I modified the orientation of the diodes (Pick and Place files are just a table you can edit in Excel LibreOffice Calc, which properly interprets the file as a table)... but wrong way (I rotated them 90 degrees, but upside down).
I will try to fix my Pick and Place File (with respect to the corrections made by JLCPCB) and upload it here, but JLCPCB was able to interpret my (wrong) Pick and Place file, make corrections the needed corrections, and manufacture at least one working board (I hardwired one, but I'm waiting on USB C connectors, the only component other than switches and lock light LEDs that JLCPCB didn't attach).
Once I get those connectors I'll have 2 extra PCBs if you'd rather go that route.
« Last Edit: Wed, 28 October 2020, 13:02:12 by Rayndalf »
Offline dredwerker
« Reply #186 on: Wed, 28 October 2020, 19:35:51 »
Hi all
Thanks for the corrected file.
I must be going wrong with the BOM file it doesnt include things like the processor or the diodes :
D1,D2,D3,D4,D5,D6,D7,D8,D9,D10,D11,D12,D13,D14,D15,D16,D17,D18,D19,D20,D21,D22,D23,D24,D25,D26,D27,D28,D29,D30,D31,D32,D33,D34,D35,D36,D37,D38,D39,D40,D4...
NO
SOD-123
No part selected
117
Would your boards have usb c and processor etc soldered on?
 I have just soldered diodes and switches ok but my soldering skills are pretty sketchy.
Offline Rayndalf
« Reply #187 on: Thu, 29 October 2020, 01:38:07 »
Hi all
NO
SOD-123
No part selected
117
I used this BOM file, I think it's the one located at the first EasyEDA page, but it might be the one in the EasyEDA editor instead (I'm not sure, but it worked). The boards I received have everything attached except the USB C socket, LEDs, and switches.
U1 (ATMEGA32U4) and P2 (ISP header for hardwired cable?) are currently out of stock (and grayed out). You'll have to wait for the ATMEGA32U4, but I opted to not have the ISP header attached (I wasn't sure if it was meant for the back or front and I don't have any compatible cables anyway).
Edit: the last 4 items are not selected and I believe that is correct (they need to purchased and installed by you) because either go on the front (the LED lock lights) or are the USB C connector (which is a hybrid SMT and through hole component which doesn't support factory assembly). I forgot to order the USB C connectors with my order. I'm not sure how JLCPCB bundles parts with orders, but I've heard it's an option.
« Last Edit: Thu, 29 October 2020, 01:44:13 by Rayndalf »
Offline dredwerker
« Reply #188 on: Thu, 29 October 2020, 03:47:38 »
How much would your boards cost?
Offline Rayndalf
« Reply #189 on: Thu, 29 October 2020, 04:37:52 »
I'm still waiting on USB C connectors :'(. I currently have a couple left though. They'd be $25 a piece + shipping flashed and ready to go.
JLCPCB is pretty much idiot proof (by some miracle even I figured it out), so I'd totally recommend going that route if you don't mind getting some extras.
Offline dredwerker
« Reply #190 on: Fri, 30 October 2020, 00:42:10 »
I have invented a bigger idiot. Possibly its just because parts are out of stock. I think I am nearly there but I am missing too many pieces. I don't even know what the usb part is
7   USB   P1   HDR-5X1/2.0   1
It doesnt seem detailed enough and nothing comes up on google. Nothing comes up on JLCPB either. Maybe I might be better off getting your ones. I am in Australia so I dont know what the shipping would be like.
Offline Rayndalf
« Reply #191 on: Fri, 30 October 2020, 07:54:07 »
You can get the USB C plug here https://lcsc.com/product-detail/USB-Connectors_SHOU-HAN-TYPE-C16PIN_C393939.html
If you can find a way to order some as loose parts alongside the otherwise completed boards that would be ideal.
Are the ATMEGA32U4s already back in stock?
Offline TalkingTree
    • My projects
« Reply #192 on: Fri, 30 October 2020, 12:02:07 »
That's  the USB Mini female connector which is obsolete since I replaced it with the USB type-C socket. You may skip that.
Offline dredwerker
« Reply #193 on: Sun, 01 November 2020, 15:50:52 »
Thank so much for your help so far.
I am at the pick and place bit again and this is what I have:
No USB, get the USB C like you suggested.
Dont get the ISP ?
NO
SOD-123
No part selected
117
What is the Diode that needs to be selected?
X1
16MHz
OSC-YSX-3225_4P
No part selected
1
Which crystal?
U1
ATMEGA32U4
SPARKFUN-DIGITALIC_TQFP44
No part selected
1
Is there a replacement for the sparkfun atmega?
I think this is the only three parts I am stuck on. Along with a basic understanding of what I am doing :)
Offline Rayndalf
« Reply #194 on: Sun, 01 November 2020, 22:38:28 »
This is strange. Effectively there are two different BOM files, one directly linked at the EasyEDA project page, and one you can generate from the PCB layout file you open with the EasyEDA editor. I used the file from the project page (I guess I manually entered missing info from the generated BOM and completely forgot?)
The diodes (D1-D117) is LCSC part # C30353
The crystal (X1) is LCSC part # C12668
The ATMEGA32U4 microcontroller (U1) is LCSC part # C44854
The microcontroller seems to still be out of stock though.
Offline Auslander
« Reply #195 on: Thu, 05 November 2020, 23:50:45 »
v1.1: Replaced USB mini with Type-C; fixed many misalignments. This should address every report posted so far.
Is it possible to upload v1.1 but with USB mini instead of Type-C?
HHKB JP | Realforce 104UB-DK | HHKB Pro 2
Offline TalkingTree
    • My projects
« Reply #196 on: Fri, 06 November 2020, 08:47:45 »
Sorry, I won't. I don't wanna fork the project myself and I'd rather enhance the PCB with the latest technology (granted that I can manage that).
Offline Rayndalf
« Reply #197 on: Fri, 06 November 2020, 13:54:12 »
Speaking of which, are either of the hardwire cable points compatible with a JST daughterboard? A USB C connector that remains hidden in a chunky plastic case is fine, but I'm wondering if I could cut the case slightly and mount a daughterboard for a detachable cable.
Offline TalkingTree
    • My projects
« Reply #198 on: Fri, 06 November 2020, 15:34:56 »
There's a header for that purpose. In other words, yes.
Offline dredwerker
« Reply #199 on: Mon, 23 November 2020, 17:54:54 »
I have waited ages to see if stuff comes back in stock please can I buy some boards from you? I will then just get the USB C connector. How do you want to go about it?
