Author Topic: edit  (Read 3252 times)
Offline zimo
edit
« on: Tue, 12 December 2017, 16:01:03 »
edit....
« Last Edit: Wed, 13 December 2017, 06:46:29 by zimo »
Offline Oblotzky
  • Backspace is for people that make mistakes.
Re: Pandora box
« Reply #1 on: Tue, 12 December 2017, 16:02:53 »
What's the clearance distance towards the acrylic panel? Some artisans might be too high to fit.
Offline ns90
Re: Pandora box
« Reply #2 on: Tue, 12 December 2017, 16:04:02 »
I would probably be in for at least one, BUT I would say that the spacing between switches should be increased just a bit more than standard spacing. I've tried to use switch testers as artisan holders in the past, and some things just don't sit nicely side by side.
Offline zimo
Re: Pandora box
« Reply #3 on: Tue, 12 December 2017, 16:05:19 »
You can put in a Kosmo,I made for this standard
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: Pandora box
« Reply #4 on: Tue, 12 December 2017, 16:39:30 »
Aside from the clearance concerns people are voicing here, it should also spell "Pandora's Box".
Offline Kafka
  • i like clean things
Re: Pandora’s Box
« Reply #5 on: Tue, 12 December 2017, 17:44:34 »
+1 "Pandora's Box"
Offline Vloshko
Re: Pandora’s Box
« Reply #6 on: Tue, 12 December 2017, 17:51:33 »
"Pandora's Box" - I concur.
Man, this box is sleek.  I love the facets more so than if it was square or rounded on the sides. I'm so down with this to be the storage space for not in use art.
Keycap Compendium
Discord: Vloshko#1327
Key Cap Wishlist
2019: Configure Optimal Audio Settings
HHKB Pro 2, Model M, Unicorn X Legend, ESPECTRO 96, SaiB CP, E8-V1.
Offline KaminKevCrew
Re: Pandora’s Box
« Reply #7 on: Tue, 12 December 2017, 21:06:31 »
If this box will have a PCB so I can use it as a game pad in addition to using it for switch display, I'd definitely buy one.
Sent from my Nexus 6P using Tapatalk
Offline kingnestea
Re: edit
« Reply #8 on: Wed, 13 December 2017, 10:47:56 »
fk zimo old driver
no time to explain, let's get on his train!
