Author Topic: [IC] TKC1800 Kit, QMK PCB, Plate (G80/G81 compatible) Official Announcement  (Read 55109 times)
Offline Rayndalf
Re: [IC] TKC1800 Kit, QMK PCB, Plate (G80/G81 compatible) Official Announcement
« Reply #100 on: Thu, 01 February 2018, 09:47:25 »
I already have a windows 8 logo 1800, and have a 1838 on the way, but I fear I'm going to have to get my hands on a third one and PCBs for each.
In my experiences I've had good luck with (OG) PCB mounted Cherry, would a plate even be noticeable in a case designed to support a plateless PCB?
Offline duynguyenle
  • Personal text? What personal text???
« Reply #101 on: Thu, 01 February 2018, 09:54:32 »
I prefer using any G80 case with a plate. It's borderline unbearable to type on a PCB-mounted build
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline TheKeyCompany
  • Because You Need the Feels...
    • The Key Dot Company
« Reply #102 on: Thu, 01 February 2018, 10:08:42 »
I agree with the plate. Its a good idea to have one in there. The stock G80s used a really thick PCB and offered decent stability. The newer PCBs (like the one I will be selling) arent as rigid. A plate takes it to a whole other level. Its slightly visible between the caps. The case does require a slight modification, and thanks the the help of duynguyenle, Ill have a pretty easy guide to follow in order to make the modification. Originally I planned to mod the cases in house but its far too time consuming for me to offer that.
Offline Delirious
« Reply #103 on: Thu, 01 February 2018, 10:45:56 »
https://imgur.com/a/gwMJg
This was a few months back, gonna build another one with this pcb
Offline Rayndalf
« Reply #104 on: Thu, 01 February 2018, 11:09:57 »
The (original) PCBs are black or dark brown, so a black plate would blend right in. I have no problem cutting into the newer 1800, but I'm not sure I want to modify the 1838. I may try to reinforce the PCB from below, but I won't know till I have the parts partially assembled
« Last Edit: Thu, 01 February 2018, 11:19:46 by Rayndalf »
Offline heckenjoni
« Reply #105 on: Thu, 01 February 2018, 11:18:36 »
is it possible to just buy an pcb ?
« Reply #106 on: Thu, 01 February 2018, 11:19:26 »
Of course! How many do you want?
Im going to open the sale probably next week (pending order being confirmed)
« Reply #107 on: Thu, 01 February 2018, 12:41:02 »
Dont worry about the case too much. All the modification are hardly visible when assembled. Also, I will have brand new off the line black G80-1800 cases for sale.
Offline Rayndalf
« Reply #108 on: Thu, 01 February 2018, 12:46:46 »
I know I'm going to need 2 PCBs and at least 1 plate (really depends on the price per plate).
I already have a new 1800 (got it nib, but its basically the same board you guys gutted for cases). It feels like a wasted opportunity to retrofit an 1800 with maybe 2 months of solid use, as the switches are just about the worst cherry blacks available (a few years too old to be 'new' and too new to be broken in or 'vintage'). I had gotten a board with vintage blacks on the cheap, but I finished handwiring the rows, and its too clean to scrap. Guess I'll just have to use the 1800 often enough that I can break in the switches myself :p
Offline heckenjoni
« Reply #109 on: Fri, 02 February 2018, 02:05:03 »
I need 1 PCB what would be the price for 1 shipped to germany ? also is there a picture of the bottom side of the pcb ? how much smd underglow leds does it support ? greetings from germany ! :)
Offline A.L.
« Reply #110 on: Sat, 03 February 2018, 14:31:37 »
interested aswell, how will the underglow of the pcb work ? and shipping quotes to Germany would be awesome aswell ! :)
Offline p_blaze
« Reply #111 on: Sat, 03 February 2018, 16:29:26 »
Is there an underglow or diffuser insert for the case?
Offline heckenjoni
« Reply #112 on: Mon, 05 February 2018, 09:32:20 »
any updates here ? rly looking forward to this one ... :o
« Reply #113 on: Mon, 05 February 2018, 12:00:00 »
No shipping quotes yet. We only use DHL Express for international at this time. I imagine packed in a soft pack bag shipping for a PCB only would be around $20 USD. Shipping the whole kit would require a box, expect about $30-$35.
The under glow RGB is available, but you have to provide and install the LEDs yourself. We did this so the PCB could work in future and existing designs that accommodate under glow. The TKC 1800 does NOT support underglow.
« Last Edit: Mon, 05 February 2018, 12:05:03 by TheKeyCompany »
Offline avtar
« Reply #114 on: Mon, 05 February 2018, 12:13:21 »
Any chance of an assembled option?
Offline Vigrith
« Reply #115 on: Mon, 05 February 2018, 13:29:26 »
Would also like to know this. I have friends that can help out if assembly is not offered but it's always a plus in my book.
Offline heckenjoni
« Reply #116 on: Mon, 05 February 2018, 14:58:07 »
(shipping price sounds good to me) i rly want this pcb for a tx1800 v2, just a few questions about the underglow, with its not supported you mean the leds are not presolderd right ? did you guys got the underglow working on this pcb at any point ? if so could you provide a simple guide or something like this, if its not to hard to get the underglow working on this one i would buy one for sure !
Offline mogo
« Reply #117 on: Mon, 05 February 2018, 15:10:31 »
I believe they meant that the case does not support the... existence of underglow. Because it's solid plastic, no windows, no diffuser plate.
Offline heckenjoni
« Reply #118 on: Mon, 05 February 2018, 15:25:24 »
i see i think you are right, my english is not the best, would still love to know if there are places for the leds or if i can install an led strip
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #119 on: Mon, 05 February 2018, 16:29:53 »
There are places for the LEDs on the back of the pcb, I have a prototype that I was using for testing of my alps sliders, and that prototype has the LEDs on the board. They are probably not going to be on there as most cases don't support any underglow, and I don't believe they are going to change the pcb to remove those pads.
Offline sythie
« Reply #120 on: Wed, 07 February 2018, 10:07:45 »
The TX1800V2 ships with a bog standard MX1800 board from Leeku. It'll work.
How does the TKC1800 PCB compare to the MX1800?
The MX1800 looks thicker to me.
Would the brass plate for the TX1800v2 fit this kit?
Offline duynguyenle
« Reply #121 on: Wed, 07 February 2018, 22:00:40 »
First of all, how do you even infer the thickness of PCBs based on pictures? "Looks thicker" is not a scientific measurement. FWIW, the Leeku MX1800 FR4 substrate is a bog-standard 1.6mm thickness (measured with calipers on both v1.3 and v1.6 versions)
For the second part of your question, no the plate for the TX1800v2 will not work in an OG Cherry 1800 case. You will need to either get one from this GB or get one custom cut.
    • Viktus
« Reply #122 on: Wed, 07 February 2018, 22:20:33 »
To further this point, the TKC1800 uses a 1.6mm PCB as well, which is the standard for a lot of industries.
Offline TerryMathews
« Reply #123 on: Wed, 07 February 2018, 22:48:58 »
Correct. RGB LED pads are in place and supported by firmware, but they will not be factory installed as there's only one 1800 case (TX1800) that supports RGB underglow and their presence in a normal Cherry case requires alterations to the support structure in the bottom casing.
Offline under.pk
« Reply #124 on: Thu, 08 February 2018, 08:53:25 »
I check GH everyday, really want the plate and pcb so bad.
Offline heckenjoni
« Reply #125 on: Thu, 08 February 2018, 09:38:27 »
at what date can we expect to buy the pcb ? rly want this one :)
Offline Rayndalf
« Reply #126 on: Thu, 08 February 2018, 12:00:58 »
Glad to know I'm not the only one checking daily just to make sure I get the opportunity to be ~$150 poorer
Offline under.pk
« Reply #127 on: Thu, 08 February 2018, 21:10:53 »
Yeah I have the keyboard with QWERTZ ISO layout and I really want to change them to Ansi. QMK also a BIG PLUS.
Offline _rubik
« Reply #128 on: Fri, 09 February 2018, 13:13:23 »
Seeing as they are such similar cases, this question applies to the Cherry 11900. What is a good way to add weight to these cases. Obviously the 11900 is pcb mount, so the tkc1800 plate will stiffen it up and add weight, but has anyone added anything into the case?
    • Viktus
« Reply #129 on: Fri, 09 February 2018, 13:20:01 »
The ghetto way of doing it would be to go to hobby lobby, or similar hobby store, and buy some lead weights for pine wood derby cars. Otherwise you will have to do something more custom and expensive.
« Reply #130 on: Fri, 09 February 2018, 20:26:21 »
To expound on this: the slats in the stock case are meant to support the PCB. Anything that doesn't cross the top of the slats is not going to cause interference. There's a ton of space in the case to add dampening material and weight. You will probably want to wait until you have the board in hand before doctoring the case if you intend on installing and playing with either of the headers (I2C and SPI) as you will have to make space to accommodate the headers and routing for the wires.
Offline loud_asian
« Reply #131 on: Sun, 11 February 2018, 15:52:27 »
Any updates on when these are gonna go up for sale? I'd love to do a mx build and alps build in these
Offline _rubik
« Reply #132 on: Sun, 11 February 2018, 17:55:55 »
I came here just to ask the same question.
Offline heckenjoni
« Reply #133 on: Sun, 11 February 2018, 19:33:52 »
yeah would buy one aswell ... just need a date ^^
    • Viktus
« Reply #134 on: Sun, 11 February 2018, 20:10:52 »
He has been quite busy lately, hence him not having responded yet. I haven't heard anything yet, so just keep a look out for a post when he gets a chance.
Offline Uleoja
« Reply #135 on: Mon, 12 February 2018, 10:47:51 »
I would buy 1 maybe 2 PCB's.  I am excited!
« Reply #136 on: Mon, 12 February 2018, 14:35:47 »
Hey everyone. Hate to be the bearer of bad news, but were delayed again, hopefully for the last time.
Long story short, the PCB factory we ordered from basically decided to go AWOL and is not going to be fulfilling the order now.
We already got a bunch of quote requests out. Should know more in a few days.
If any vendors or makers have any recommendations on a good PCB supplier I can use, PM me. I appreciate it.
Full info here in a blog post.
Offline mogo
« Reply #137 on: Mon, 12 February 2018, 16:47:02 »
A bummer for sure, but waiting patiently is a skill everyone in this hobby must hone. And so we will continue to wait and hope for this excellent board!
(Side note, anyone have thoughts on the best way to go about making this a bluetooth board once I get one?)
« Reply #138 on: Mon, 12 February 2018, 17:03:11 »
Thanks for the patience!
Bluetooth will be pretty easy. I wanted to do a module made specifically for the case, but it was going to cost a fortune to design and produce, and the market wasn't really there. However, Terrymathews has been playing with an Adafruit board that works splendidly. And its quite affordable.
Offline avtar
« Reply #139 on: Mon, 12 February 2018, 17:16:35 »
Sucks about the delay but thanks for being deligent with the updates here :thumb:
Bluetooth sounds really good. I'd definitely sign up for that. Also, any thoughts regarding the following?
« Reply #140 on: Mon, 12 February 2018, 17:39:06 »
It would be really hard to do since the plates would have to be at the factory in order for them to assemble. I’m going to talk to a few community members to see if anyone wants to build a few for people.
Honestly, try building a board! It’s fun!  Unless you’re like me and just don’t have time.
Offline avtar
« Reply #141 on: Mon, 12 February 2018, 17:54:38 »
It's more the time issue for me as well. But no worries if that isn't an option, I'll figure something out :)
Offline heckenjoni
« Reply #142 on: Sat, 17 February 2018, 23:19:37 »
i would love to build some boards, but located in germany so would only be an option for ppl in europe i guess :)
Offline Kavik
« Reply #143 on: Wed, 21 February 2018, 23:34:14 »
This looks amazing. I am interested when this goes live!
Offline kevinzavier
« Reply #144 on: Fri, 23 February 2018, 14:23:32 »
I will def buy this board, i especially like the light blue version
Offline mogo
Surprised i haven't seen any update here, but TKC posted this on /r/mk yesterday:
And lastly, The TKC1800.
We have a new supplier set up and a new facilitator handling the production of the PCB. We feel confident enough with the new supplier to open up the GB. Currently we have ~100 painted cases in stock and ~30 BNIB stock black cases, 50 plates (more on order), GMK screw in stabs and all the other required parts. The ONLY part not in stock is the PCB. The lead time on the PCBs is about 60 days. We are going to open the GB on Friday, March 02, 2018 at 7pm EST. First come, first served as each color is limited (we will be getting more stock of the brand new stock black cases so those will be an endless supply). Ill post a proper IC tomorrow to get everyone up to speed on the details of the buy.
TL;DR
GMK Led Zep - Production complete. Ships Mid-March
DSA Drifter - Delayed approx 1 month
Terminal_ R2 - GB starts after GMK Led Zep ships
TKC1800 GB starts this Friday
https://www.reddit.com/r/MechanicalKeyboards/comments/810ioc/vendor_thekeycompany_gb_updates_tkc1800/?st=je8u648c&sh=2ed783b9
The hype train is finally pulling into the station!
Offline vewy_nice
I skimmed the thread, and didn't see much reflecting the available colors... Is it only the bright ones shown?
I bought Mint Dolch on MD, and it'd be amazingly super sexy to have a case that matches the minty legend colors :o
AFTEREDIT: The white will do nicely. That's super slick!
« Last Edit: Fri, 02 March 2018, 06:15:52 by vewy_nice »
Hey everyone! u/M1keHonch0 here!
Here it is. This is the official IC / Sale announcement of a project I have been working on for over a year. I am pleased to finally be able to bring it to all you fine clackers.
TKC1800
The story
The case:
The TKC1800 is a project I dreamt up back in 2016. I bought a vintage G80-1800 on mechmarket. The PCB was great but the case was a bit sloppy. I came to realize that the G81 cases are identical. Then I acquired a few brand new ones on eBay and swapped cases. It came out magnificent. (I since sold Red Alert to u/kimbless and I regret it every day.) This led me to buy a pallet of used G80-1800s from a nice fella in Europe with the intentions of providing a cheap solution to people for a custom 1800 style keeb. Well, the pallet arrived and the cases were beat to ****. I scuffed a few up in the garage with some scotchbrite and hit them with some Rustoleum. The end result looked pretty cool, although not a viable solution for a product. I contacted a friend who runs a body shop that restores classic cars and asked him to shoot a few and see if its something he could do and would want to do. After alot of going back and forth and testing and trying new things, we finally nailed that process down. I have since also sourced brand new black stock cases from the Cherry factory in near unlimited supply. They come in any color you want as long as its black.
The PCB:
I initially was going to use the 1800L3 PCBs from Leeku. Its a great PCB, the issue was getting enough of them and having control over manufacturing. I wanted this to be exactly how I wanted it to be. I decided a custom solution from scratch was the only way to go. I discussed the projects with a few different community members and was unable to find anyone willing to do it for a reasonable amount or in a reasonable time frame. So what did I do? I hired an embedded systems engineer (at great expense). Worth every penny. The new PCB has many upgrades to what is currently available. The PCB runs QMK firmware, it has and SPI interface meaning you can access the remaining pins on the processor to do fun things, like add a blue tooth module, or an OLED screen. Lets see what else you clever people can dream up with this feature! Its been a long road finding a suitable manufacturer, but we have finally nailed it down and are ready to start manufacturing. Did I mention its MX and Alps compatible? The firmware has been developed and tested by u/terrymathews and he is working on an OLED screen kit that will be available in the near future. A Bluetooth module is in the works, as well.
The Plate: Not much to say about the plate. I originally ordered them in 1mm thickness, Im not super happy with that. The new ones will be 1.5mm thickness. I will sell the 1mm ones off at a later date with the B stock cases. The colors initially chosen are really great in my opinion. Im going to add a few options to the GB and will place the order as soon as the buy is over so everyone gets what they want. There will be 2 variants available. One for Cherry MX switches with switch top opening and will work with PCB mount stabs. The Alps version will have cutouts for Alps switches and will use plate mount stabs. This way you can use any SP Alps keyset, or you can pick up some Nexus Alps to MX adapters designed by the brilliant u/blindassassin111.  We will be stocking these as well once they are ready.
FAQ
What is the case made of?
The case is injection molded ABS plastic that has been sanded, primed, adhesion promoter applied, then painted with automotive paint.
How much is it?
The pricing is on the product page on our site
Can I buy just a PCB?
Yes. And plates are available also.
Will the PCB and Plate fit a Dolch PAC?
Yes. The PCB and Plate fit in any G80 /G81 1800 case as well as the Dolch Pac, even the OG Skidata board. But in order to use a plate you must modify the case with a dremel or some other cutting device. We will offer the option to cut the case for you prior to shipping, u/blindassassin111 came up with a pretty slick jig that were going to use to get nice, clean cuts.
When does the sale start? When will the kits be delivered?
The products are available to preview on the site now. The sale goes live Friday, March 2 at 7PM EST. Theres enough to go around so if there is a particular color that you want you should be able to get it. I wont ever make more than 24 of any single color case (except stock black unpainted). Lead time on the PCBs is 60 days. Based on my experience with GBs and manufacturer lead times, I would say 60 days is a solid bet, but dont panic if it takes 90.
« Last Edit: Thu, 01 March 2018, 20:50:30 by TheKeyCompany »
Offline lemur
  • personal text
<snip>
Hey this looks great!
Just wanted some clarification..
On thekey.company website when it lists what is included in the kit it says:
Whats included in the kit?
Case
PCB
Plate
Brand new (improved) bump ons
Aluminum / Brass ID tag
New diffuser decal
and on the front page of this IC it says this:
-Case
-PCB
-Plate (optional) Anodized aluminum in choice of color 1mm thick
-Brand new (improved) bump ons
-Aluminum / Brass ID tag
-GMK screw in stabilizers in size of your choice
-New diffuser decal
-Switches of your choice from NovelKeys.xyz
These two are a bit different....  Can you give some clarification about which one is accurate, as this info would greatly impact my purchasing decision.
thanks!
keyboards
The info on the website is accurate. I need to just remove all the old info from GH. I was up pretty late putting the page together and didn’t clear it all out. Sorry for the mix up.
