Author Topic: [IC] Extra Keys pack (PBT dye-sub)  (Read 2976 times)
Offline Tom_Kazansky
  • Oblivion Knight
« on: Wed, 13 December 2017, 07:57:13 »
Hello!
I want to create a pack of keys which consists of media, macro, extra functions and other novelties. I created this topic to gather interests.
I plan to ask vendor everglide from China to produce the pack. (please check this topic: Custom DYE SUB for PBT keycaps   :)   sample set).
IC Form: here
Detail:
- 39 keys (I may add/remove keys)
- profile is Cherry, R4 row.
- PBT dyesub.
- color will be black legend on white key. (based on the sample, there are more color but I don't know if it's possible to order mix of colors)
- Price: not yet known. I will work on the submission file and ask vendor for the price.
If there is enough interests, I will ask someone else to run the group buy.
Thank you for reading,
Tom.
12/15/2017: new revision
OLD:
« Last Edit: Fri, 15 December 2017, 22:07:06 by Tom_Kazansky »
Offline t8c
Re: [IC] Extra Keys pack (PBT dye-sub)
« Reply #1 on: Wed, 13 December 2017, 12:00:44 »
Great idea! I am definitely in!
  • Oblivion Knight
« Reply #2 on: Wed, 13 December 2017, 21:13:07 »
I'm revising some keys, I want to add "community keys", anyone has the svg file for Geekhack icon? like in Nautilus keyset
 :thumb:
  • Oblivion Knight
« Reply #3 on: Fri, 15 December 2017, 06:30:08 »
Update:
- replace "sleep" and "camera" with "power" and "refresh"
- add "bright" and "dim" (for leds)
- add "cut", "copy", "paste", "save"
- modify macro keys, add "triangle" and "circle"
- remove F20 ~ F24
- add community key: VNMK, GeekHack, R/MK, Deskthority
should I remove all the "F" keys? or replace them with "P" ?
