Author Topic: Japanese Model M?  (Read 5820 times)
Offline daskeybo
Japanese Model M?
« on: Tue, 19 December 2017, 11:28:50 »
https://m.ebay.com/itm/IBM-5954339-Japanese-Keyboard-Japanese-Letter-Typing/162751818108?
Anybody know if this is buckling spring and can be converted to USB?
Offline 7h3_Pr0v010n3
  • Gmorning, Gafternoon, Gevening & Gnight! :)
Re: Japanese Model M?
« Reply #1 on: Tue, 19 December 2017, 11:38:37 »
« Last Edit: Tue, 19 December 2017, 11:53:07 by 7h3_Pr0v010n3 »
Offline clickityClackity
« Reply #2 on: Tue, 19 December 2017, 11:39:35 »
Yes, there is a good thread about it. I'll try to find it later (on mobile at the moment)
Offline harlw
« Reply #4 on: Tue, 19 December 2017, 11:43:16 »
Lots of infoz for you here
Ergodox (x2), V.EA Clone, Tada68, Atreus XL, Planck, Model M 70% Mod
Offline matt-taco
« Reply #5 on: Tue, 19 December 2017, 11:43:31 »
Pingmaster, alps skcc green, typing on one now. Extra smooth and delicious.
You can either wire a teensy to it, or you can take the easy rout and e-mail hasu for his tmk4704 for 45 bucks.
https://geekhack.org/index.php?topic=54706.0
Currently I use it as my school driver, I love it. Takes a week to get used to it, has a fairly short throw, 3mm, but its my fastest typer.
Offline ander
  • I type, therefore I am
« Reply #6 on: Wed, 20 December 2017, 01:46:44 »
Offline daskeybo
« Reply #7 on: Wed, 20 December 2017, 12:09:26 »
Thanks for the info
