Author Topic: KRYTOX 103 with 75% discount [international delivery from Italy]  (Read 3154 times)
Offline Giorgio
« on: Thu, 21 December 2017, 03:04:13 »
https://www.ridewill.it/p/en/starblubike-567010040-krytox-lubricant-for-gearboxes-15ml/30644/
https://www.ebay.ie/itm/Krytox-lubricant-for-gearboxes-15ml-STARBLUBIKE-bike/332263463113?hash=item4d5c7218c9:g:8PgAAOSwIJlaFFcF
If these sources can be believed, SB10 should be krytox 103.
Krytox 103 can be had "off the shelf" as SB10 a lube used for bikes and skis. (Blue sky racing is one source I believe.) There are several internet sources, try to google SB10. Krytox 100, (lower viscosity) lube I use and others have commented on is a bit more difficult to obtain in small quantity. Yes Krytox, at least in theory, violate liquid lube rule. Goes on wet, it's a thin film lube.
https://derbytalk.com/viewtopic.php?t=1501&start=30
We have mixed SB-10(krytox 103) and Nye-oil with ok results.
https://derbytalk.com/viewtopic.php?t=1656
Sb-10 is Krytox 103.
https://pinewoodp.proboards.com/thread/792
SB-10 is probably Dupont Krytox 103. That's what my Canadian Dupont rep said. If you can find a local rep for Dupont they might send you a free sample of Krytox 103. Krytox 102 has even less viscosity than 103... might be fun to try both. I think you can get away with using more of it without penalty unlike Nyoil II.
https://www.derbytalk.com/viewtopic.php?t=626&start=15
Then, what I found is SB-10. Looking roughly, it appears to be based on the Krytox 103. (Wakos Fusso 105 based on Krytox 105)
http://www.kbdmania.net/xe/freeboard/2147523
« Last Edit: Thu, 21 December 2017, 10:37:36 by Giorgio »
