Author Topic: Place to by alps click leafs  (Read 3278 times)
Offline rich1051414
« on: Thu, 21 December 2017, 09:57:21 »
Is there anywhere you can buy loose alps click leafs? I don't know if anyone else has problems with the pinging across the room sometimes, or hooking on your fingernail, but I would really like to have extras, and buying a switch just to harvest a leaf does not seem economical at all.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: Place to by alps click leafs
« Reply #1 on: Thu, 21 December 2017, 10:29:25 »
you can probably get the blacks from a dell at101 for free
-Dana
Offline rich1051414
« Reply #2 on: Thu, 21 December 2017, 10:51:27 »
Blacks are tactile, I need click leafs, and also, where to I acquire free at101s?
I actually have a surplus of tactile leafs as I normally mod towards clicky, as the tactility is better. Cutting a tactile leaf is not the same. This results in a click that is softer and less tactile than a proper click leaf, not to mention inconsistent.  I have been using white alps for click leafs, as the click leaf itself is basically the same design as blue alps, but I don't really like looting them, white switches aren't bad, and they are starting to get more valuable.
Regardless, I was hoping my googlfu was just lacking, and there was a place you could buy click leafs in bulk.
« Last Edit: Thu, 21 December 2017, 10:56:52 by rich1051414 »
Offline Fluffypupper22
« Reply #3 on: Thu, 21 December 2017, 14:15:16 »
If you want extra click leafs you'll have to buy more switches. Keep track of them when disassembling switches and you'll be fine.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Thu, 21 December 2017, 14:30:25 »
Matias?
Offline rich1051414
« Reply #5 on: Thu, 21 December 2017, 17:35:14 »
Matias?
Well, I looked, and you can get 200 matias click switches for $50. That isn't bad! I guess that would be the closest thing possible to a supply of click leafs.
Offline klennkellon
  • I like bottoming out
« Reply #6 on: Thu, 21 December 2017, 19:28:32 »
Matias leafs are actually really good and you can buy them brand new.
They're a great way to spruce up more mediocre Alps like black and cream dampened.
Offline OfTheWild
« Reply #7 on: Fri, 22 December 2017, 16:41:47 »
Right... you want the leaf though, and then make it clicky:
https://geekhack.org/index.php?topic=79539.0
Free AT101's no... but the garbage black alps that came in them: anywhere.
-Dana
