Author Topic: Just another Topre Realforce keyboard  (Read 4645 times)
Offline gorauskas
« on: Sat, 23 December 2017, 14:28:17 »
Found this one Topre Realforce 104UW:  https://www.ebay.com/itm/Topre-Realforce-104UW/122876389917
« Last Edit: Sat, 23 December 2017, 15:14:48 by gorauskas »
Re: Just another Topre Realforce keyboard
« Reply #1 on: Sat, 23 December 2017, 15:38:34 »
So how much do these go for usually and how good are they? Im pretty used to typing on model M & F's
Offline _rubik
« Reply #2 on: Sat, 23 December 2017, 16:53:03 »
Not sure about the 104u, but my 87u was right around $200. That being said, they have stopped making the revision I got, and have since started making a rev2 (I think, if someone knows more please correct me).
As for their quality, I absolutely love mine. The steel plate really stiffens the whole thing up, and is the closest you're going to get to a Model M in terms of plate. The switches are obviously going to be a different feel: a lot less mechanical and instead more pillowy.
I would suggest trying out a 55g topre before buying if you can. I jumped in blind and relied on the praise from other GH members, and was lucky enough to quite like the feel. Others have no had the same experience thought.
« Reply #3 on: Sat, 23 December 2017, 18:01:04 »
Thank you for the advice!  :)
Offline HotRoderX
« Reply #4 on: Sun, 24 December 2017, 02:13:42 »
I also have a 55g 87u and love it! I jumped in semi blind to the 55g switches and can say they feel lighter then my FC660C which is said to have 45g topre! either way I love my board to death! one of the nicest board's I own. Cherry's are nice and all but if you do a lot of typing its worth checking out the Topre's not saying its for everyone but worth looking at very least
Offline ander
  • I type, therefore I am
« Reply #5 on: Mon, 25 December 2017, 18:08:26 »
Being used to heavier switches, you'd probably enjoy one of the uniform 55-gram versions more than this 45g one, or one of the variables (35-45g except for 55g Esc, which is rather silly IMHO).
Your profile doesn't say what area you're in—but if you're in or near a fair-sized city, you should be able to find a Type Heaven (45g) to get the general Topre feel. Then just imagine one with a touch about 20% heavier. Or if you like the TH, you can get a new one of those for ~$130, and the only significant difference is the key material (which some of us actually prefer over RF).
But I digress.
