Author Topic: [IC] BOK.CP Custom Keyboard (Compact 1800)  (Read 46363 times)
Offline JFKroflcopter
Re: [IC] BOK.CP Custom Keyboard (Compact 1800)
« Reply #50 on: Wed, 27 December 2017, 02:39:35 »
Hoping that I can snag one of these when the GB opens.. this looks incredible  :thumb:
Offline poolside
« Reply #51 on: Wed, 27 December 2017, 03:30:28 »
If the brass weight plate is optional, does that mean that stainless steel will be the default material for the weight plate?
Antique treatment process is 2 times dry plating and coated preventing fingerprint like brass weight.
Ss weight is not included in the price.
There is only brass weight.
Bok.cp will be made in same factory with txkeyboards.
Quality gets better by high quality material and better anodizing factory.
Thanks, have you already tried to achieve colors closer to silver with the antique finish?
BOK.CP Final Rendering...
check please...
Great board to start off 2018 with!
I only wish the plate had support for 1u 1u 1u between the spacebar and the arrow cluster, like the TX-CP.
Offline cocobrais
« Reply #52 on: Wed, 27 December 2017, 04:30:20 »
check please...
tx cp and this pcb are same in my understanding.
Offline wholypantalones
  • text and icon mods plz.
« Reply #53 on: Wed, 27 December 2017, 05:39:07 »
check please...
PCB should be a Leeku Compact L3, but the plate doesn't support it from what I see.
Offline BOK
  • i,m fine
« Reply #54 on: Wed, 03 January 2018, 19:31:25 »
Sorry for late schedule but machining have been processing continuosly. GB will be opened in this week.
Offline BOK
  • i,m fine
« Reply #56 on: Wed, 03 January 2018, 20:38:10 »
Very excited about this one. It looks awesome.
Thank you for your interest. :)
Offline finalarcadia
« Reply #57 on: Wed, 03 January 2018, 21:04:27 »
I want this  :thumb:
Offline BOK
  • i,m fine
« Reply #58 on: Wed, 03 January 2018, 21:40:14 »
I want this  :thumb:
Thanks. As I mentioned before, GB will be started within this week. Maybe participants will be satisfied with this KBD. ;D
Offline Unforgivable
« Reply #59 on: Wed, 03 January 2018, 22:24:07 »
I want this  :thumb:
Maybe? You’re crazy, lol.
It looks amazing!! I’m sure everyone will be satisfied.
I’m for sure very excited. I hope I can buy one on time!
Offline BOK
  • i,m fine
« Reply #60 on: Thu, 04 January 2018, 00:30:55 »
I want this  :thumb:
Wow! Thanks.. I also hope that you will be able to join my GB. See you soon! ;D
Offline xondat
  • i'm not a star
« Reply #62 on: Wed, 10 January 2018, 09:37:43 »
Where is the link to the order form?
On the group buy page. This is the interest check.
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #64 on: Wed, 10 January 2018, 09:39:28 »
It’s closed. Was limited to 50 units
Mod Edit: GB thread open here, locking IC thread
« Last Edit: Wed, 10 January 2018, 10:53:23 by HoffmanMyster »
