Author Topic: [IC] Cherry Font PBT Sub - Blue on White  (Read 4839 times)
Offline keykaboo
« on: Mon, 25 December 2017, 09:46:44 »
Hi all, I will be organizing a small GB for Blue on White Dye Sub. Please read the details carefully before joining the GB in the near future.
This GB is the final phase of my project with several Vendor that provide quality Thick PBT Dye Sub at an affordable price.
There have been many rounds of revision and we are coming very close to getting it right.
I believe that in this round of GB, we will be getting it right and I would like more people besides myself to try the product.
In this GB, there will be 10 sets, with the option of add on kits. As the sets are still under development, an 50% discount on all kits is given.
Please note that this may or may not be 100% GMK alike but from the earlier sets I have made, you can see that it is extremely close.
Changes that will be included in this GB.
1. Change of ^ on 6
2. Change of < and >
3. Change of font size of Function Row
4. Distance from left boarder of Esc and Function Row
5. Change of Windows logo to Code
6. Change of Menu logo to Menu
7. Change of “ to something closer to the original Cherry Font
All sets will be carefully checked before mailing out. Please understand that this is a custom-made set, slight discrepancies will be expected.
Kindly help me fill up the form
Form - https://docs.google.com/forms/d/1gXeVBJtrM42NB7pCguQVg8UhnYil6qVL89LLvjZXUCo/edit
Thank you!
Merry Christmas and Happy New Year!
Re: [IC] Cherry Font PBT Sub - Blue on White
« Reply #1 on: Mon, 25 December 2017, 10:26:08 »
The legends all look off center, especially on the mods.
I like the color scheme though.
Offline nickaster1
« Reply #2 on: Mon, 25 December 2017, 13:07:58 »
Will this be on the same or near the level of quality of EnjoyPBT? I like the color scheme that you have on here
Offline keykaboo
« Reply #3 on: Mon, 25 December 2017, 17:47:22 »
They are off centered and they are to the left.
Is that not the same as GMK?
Offline keykaboo
« Reply #4 on: Mon, 25 December 2017, 17:48:30 »
I have some samples that are sent to different vendors and I think the quality is probably the same
« Reply #5 on: Mon, 25 December 2017, 17:48:53 »
i mean i can tell that much
they don't look straight
Offline keykaboo
« Reply #6 on: Mon, 25 December 2017, 18:09:22 »
It is in the mail for me, so I will get more shots and all when I get them.
It could be due to the angle I think
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #7 on: Mon, 25 December 2017, 19:28:00 »
The price seems affordable! I filled the form. :thumb:
though I have many plans already (build boards, keysets,...), I'm not sure I would jump on this.  :(
I would buy the whole set if it support this kind of compatibility:
(image from kbdfans, please ignore the arabic sub-legends)
I might ask for too much but please take it into consideration.  :)
Offline keykaboo
« Reply #8 on: Wed, 27 December 2017, 07:33:21 »
The set will have all I believe, minus the 3U space bar
Offline keykaboo
« Reply #9 on: Wed, 27 December 2017, 07:34:14 »
GB will commence soon.
Will be doing a 10 set trial run.
For everyone else, you can join the set when it is completed, prices will adjust to reflect that as well.
Offline keykaboo
« Reply #11 on: Fri, 29 December 2017, 00:46:56 »
Add stepped caps lock and I'll probably grab a set.
Offline keykaboo
« Reply #12 on: Fri, 29 December 2017, 02:24:39 »
The dye sub for that has some alignment issues, if you are ok with the blank, i will can add that in.
In the future for the full set GB, it will include that.
This round the price is significantly lower due to all these issues.
