Author Topic: Common screw sizes?  (Read 3387 times)
Offline Krakob
    • Krakblog
Common screw sizes?
« on: Mon, 01 January 2018, 09:54:08 »
Hey all! I'm working on a tenting design currently. I figured you can use the screw holes to mount extensions to achieve tenting. What screw size is most commonly used for screws on the bottom? Are there any advantages to using a bigger/smaller size?
Ducky Shine 2 (MX Blue, white backlight) • Obins Anne Pro (Gateron Brown) • Model M • XD60
Offline ddot
  • Master of Suspense
Re: Common screw sizes?
« Reply #1 on: Tue, 02 January 2018, 09:50:37 »
I remember this post by TP from a few years ago regarding the original Ergodox.  May be something useful in there.
https://geekhack.org/index.php?topic=50020.msg1086814#msg1086814
Offline Krakob
    • Krakblog
« Reply #2 on: Thu, 04 January 2018, 03:29:48 »
Some mentions of M3 screws is all. Thanks anyhow! :)
Offline mike-y
« Reply #3 on: Thu, 04 January 2018, 16:27:01 »
I've built a few keyboards and they have used M2 or M3 screws.
I've mostly seen M2 screws on boards where the PCB just drops into the case and you screw it to the standoffs on the bottom.  The bottom of the case supports the PCB, so large screws aren't needed, they are just there to hold it in place.
I have a couple of boards where the the plate is screwed into the underside of the case, and the pcb is actually suspended from the plate and doesn't touch the bottom of the case at all.  These cases have a clear/frosted acrylic bottom, so that the underglow shines through.  These cases have used the bigger M3 screws, since the plate is being supported by the screws themselves, and does not rest on the bottom of the case.
