Author Topic: What kind of stabilizers does a GK64 use?  (Read 5927 times)
Offline math225r
« on: Tue, 02 January 2018, 12:17:19 »
The title says it all. I'm new here so don't bash me if I did anything wrong
Offline mike-y
Re: What kind of stabilizers does a GK64 use?
« Reply #1 on: Tue, 02 January 2018, 13:52:38 »
that pcb uses plate-mounted cherry-style stabilizers.
Reference data: I own one :)
« Last Edit: Tue, 02 January 2018, 13:54:23 by mike-y »
Offline nickaster1
« Reply #2 on: Tue, 02 January 2018, 14:04:59 »
Can I just take them out and replace them with Costars? I’m not really in favor of Cherry-like stabs to begin with anyways
Offline mike-y
« Reply #3 on: Tue, 02 January 2018, 14:14:30 »
heh, unfortunately, it's not that easy (ask me how I know!)
I tried to do this on a board and didn't realize that the plate needs to support costar stabs (the cutouts are a different size),
I was making this super cool instructional video on how to swap cherry for costar stabs, and got halfway through before I realized it wouldn't work.  Then had to spend a couple of hours reinstalling the cherry stabs and fixing the keyboard.  :))
Maybe I should post that video, so others don't make the same mistake
Offline nickaster1
« Reply #4 on: Tue, 02 January 2018, 17:56:02 »
Actually, make it so that others can know why that can’t be done. One’s sacrifice is another one’s treasure, in this case there will be many :))
Offline rewben
« Reply #5 on: Fri, 02 February 2018, 02:51:52 »
the stock stabilizers on my gk64 are not good. it's best to replace them entirely with better options.
