Author Topic: [IC] SINGA 75, R2 April 2018. Photos of protos added. GB starting soon  (Read 76809 times)
Offline catweewee
  • SINGA | singakbd.com
  • Yellows
    Hi guys, I'm catweewee. This is a little project I have been working on from July 2016 from the design stage until September when it started manufacturing. It is also the very first keyboard that I've designed and of course with much appreciated help from Yuktsi TGR, Juahenza and Pwner ION
THIS IS AN IC FOR R2
Now, some details about the SINGA and the concept.
SINGA is Lion in the malay language, which is where I'm from. Regal and magestic. Something what I’d like SINGA to be
__________________________________________________
SINGA R1
Specifications:
Full Album: https://imgur.com/a/Nks3Z
  • The SINGA comes with a dual brass weight for heft. The LION brass weight is connected to an inner brass bar inside
  • Custom SINGA PCB by TGR (Winkeyless Bootmapper software)
  • Plates come in either brass or aluminium. Plates are all CNCed instead of laser cut, which makes it sturdier and gives a much cleaner cut
  • 8 Degree Angle
  • Approximately 2 KG weight without caps
  • Each individual SINGA is hand polished to ensure a better quality anode.
Colours:
Layouts:
_______________________________________________________________________________________________
SINGA R2
SINGA R2 will differ from R1 with the following:
  • SS Lion Weight, SS inner weight, Brass plates and Alu plates in the new colours
  • 6 colours: Burnt Orange, Sailor Navy, Champagne Gold, Jet Purple, Velvet (from r1) and Black (from r1)
  • WK and WKL options.
  • Limited to 55 units, FCFS Store Purchase. Once all 55 slots are taken and paid for, ordering will end and production will start.
IC FORM: including the poll for WK and WKL tops https://goo.gl/forms/5Pthq2fOebkRQvq12
UPDATES:
  • 25/2 R2 will have both blocked and non blocked tops :)
  • 25/2 Champagne and Navy Blue prototypes currently made. GB might start earlier, in mid or end March.
  • 28/3 Prototypes in :) Waiting for Colourchips and GB will start. 2nd week of April?
  • Pricing: Alu kit: 376 USD, Brass Plate: 388 USD, with PCB, fees INCLUDED (4.4%+0.3). Slight price change due to currency exchange.
  • Brass plates and alu plates offered. No more ss plates.
Photos!
Champagne and Navy
Album: https://imgur.com/a/qakGd
[/list]
« Last Edit: Tue, 03 April 2018, 05:16:23 by catweewee »
Offline Murrellz
Re: SINGA 75
« Reply #1 on: Fri, 05 January 2018, 18:24:55 »
Very interested. Will you be keeping the same weight design as R1?
Offline renzpwns
  • I didn't like money in my wallet anyways.
Re: SINGA 75
« Reply #2 on: Fri, 05 January 2018, 18:31:08 »
I'm part of R1 and just dropping by to say that catweewee is a great runner so far with her first GB, giving us fairly frequent updates through email.
Quick question for cat though, is it feasible to get an option for an F row with spacing this time around? Like this 75SQ.
Definitely understand if not since the pcb, plate and top piece would need a redesign.
Offline fublamchu
  • ㅋㅋㅋ
Re: SINGA 75
« Reply #3 on: Fri, 05 January 2018, 18:35:30 »
Interested!
LZ-CE VBlacks
910-CE
Offline mike52787
  • Alps Aficionado
Re: SINGA 75
« Reply #4 on: Fri, 05 January 2018, 18:43:50 »
I second this. Very good gb so far. Can't wait to get mine!
Offline gr4v3m4n
    • my store
Re: SINGA 75 R1
« Reply #5 on: Fri, 05 January 2018, 18:51:11 »
damn thats one beautiful board, too bad my wallet is flat on its ass, probably going to join r2, good luck..
Offline catweewee
  • Yellows
Re: SINGA 75
« Reply #6 on: Fri, 05 January 2018, 18:54:40 »
Yes the lion brass weight is the main feature of the board. Singa actually means LION in my language :)
Offline catweewee
  • Yellows
Re: SINGA 75
« Reply #7 on: Fri, 05 January 2018, 18:56:18 »
yup you got it, it would be an entire diferent board, and the pcbs, plate would need a redesign.
Re: [IC] SINGA 75 and [IC] for SINGA R2
« Reply #8 on: Fri, 05 January 2018, 19:09:46 »
im in
Offline duynguyenle
  • Personal text? What personal text???
« Reply #9 on: Fri, 05 January 2018, 19:10:18 »
Elaine!!!! Sick board  ;D
+1 for the spaced out F-row, if that's feasible to do.
Looking forward to seeing more information :D
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline catweewee
  • Yellows
« Reply #10 on: Fri, 05 January 2018, 19:11:29 »
uhm thts not my board lmao
Offline duynguyenle
« Reply #11 on: Fri, 05 January 2018, 19:15:06 »
No but is it possible/reasonable to add for R2?
Offline megaforce
« Reply #12 on: Fri, 05 January 2018, 19:18:10 »
Your Signa in April.
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline catweewee
  • Yellows
« Reply #13 on: Fri, 05 January 2018, 19:21:24 »
No because then youd also have to change the pcb tracing, a change in machinin costz
Offline catweewee
  • Yellows
« Reply #14 on: Fri, 05 January 2018, 19:23:16 »
Offline renzpwns
« Reply #15 on: Fri, 05 January 2018, 19:28:19 »
Fair enough, was worth a shot. Can't wait for my boards!  :thumb:
Offline duynguyenle
« Reply #16 on: Fri, 05 January 2018, 19:37:11 »
Oh well it's not like a normal 75% is hard to live with anyway. Hyped :)
There is ISO support on the plate and PCB right?
« Reply #17 on: Fri, 05 January 2018, 19:48:11 »
you can see in the album that there is ISO support
Offline Ponkan
« Reply #18 on: Fri, 05 January 2018, 20:44:43 »
Ayy, I hope I can get my blue and smoke one R2.
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #19 on: Fri, 05 January 2018, 22:16:31 »
I'd definitely be interested on this!
Offline kmba
  • Formerly tameone
« Reply #20 on: Fri, 05 January 2018, 22:19:09 »
what set is the enter/esc from on the prototype?
keyboards.
Offline neralo
« Reply #21 on: Fri, 05 January 2018, 22:21:34 »
I 3rd this! Other gb runners take note!!
HHKB Pro 2 55g | TGR 910 55g Vintage Blacks | Apple Standard M0116 Orange Alps | Rosewill RK9000 Cherry MX Blues | Diverge TM 2 WKLears
Offline mike52787
  • Alps Aficionado
« Reply #22 on: Fri, 05 January 2018, 22:48:07 »
Wait... was purple an exclusive color to the first round? if so i'm even happier I went with it.
Offline catweewee
  • Yellows
« Reply #23 on: Sat, 06 January 2018, 00:48:40 »
Gmk plum :))
Offline catweewee
  • Yellows
« Reply #24 on: Sat, 06 January 2018, 01:09:53 »
Sorry which one?
Offline Peiweisgreat
« Reply #25 on: Sat, 06 January 2018, 02:00:36 »
I like how the red for this case seems darker than some of the other red cases I've seen. The lion looks really good too. If I was into 75% this would be an instant buy. Good luck with getting R2 started.
Offline catweewee
  • Yellows
« Reply #26 on: Sat, 06 January 2018, 02:07:41 »
Haha yes, most red boards are really bright. Dark reds are much easier to match most keysets as well.
And thanks!
Offline nickysan92
Re: [IC] SINGA 75, R2 in April 2018
« Reply #27 on: Sat, 06 January 2018, 07:38:03 »
Interested and definitely joining this one.
Offline catweewee
  • Yellows
« Reply #28 on: Sat, 06 January 2018, 08:58:56 »
Thanks! Means alot.
Offline avid
« Reply #29 on: Sat, 06 January 2018, 09:02:08 »
Really nice. Glad to see blockers in 75% size.
Offline mike52787
  • Alps Aficionado
« Reply #30 on: Sat, 06 January 2018, 09:02:12 »
Sorry which one?
Ah, wait nevermind, I see it now.
Offline nocturalowl
« Reply #31 on: Sat, 06 January 2018, 10:03:06 »
STHAP teasing dem brass weight sis! HAWT af  :cool:
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #32 on: Sat, 06 January 2018, 12:59:23 »
This looks awesome. Like the blockers and the deep red color. Very interested in R2!
Offline catweewee
  • Yellows
« Reply #33 on: Sat, 06 January 2018, 21:58:35 »
Thank you.
Offline bminhz
« Reply #34 on: Sun, 07 January 2018, 14:00:01 »
The deep red color looks very much similar to the maroon one from GMK Camping, any chance we can compare these two color? If they are same, Camping would be dope on this  :D
Offline holtenc
« Reply #35 on: Sun, 07 January 2018, 21:17:51 »
I'm curious how a CNC'd plate is more sturdy than laser cut. Could you clarify?
Offline catweewee
  • Yellows
« Reply #36 on: Sun, 07 January 2018, 22:22:49 »
Sorry sturdier would be the wrong word. It makes a cleaner cut, and if you have a thicker plate, less flex so this is where i guess you can sturdier. Laser cutting done wrong can make edges not straight etc.
Re: SINGA 75
« Reply #37 on: Mon, 08 January 2018, 02:06:00 »
Any chance R2 is going to keep this semi staggered F Row? From the picture of this R1 Singa?
Offline captsis
  • Formerly matt2dlg
« Reply #38 on: Mon, 08 January 2018, 02:11:22 »
so the keyboard includes every key of a full sized keyboard? (if im counting right) Awesome! definately interested
Offline Pwner
  • soon™
Re: SINGA 75
« Reply #39 on: Mon, 08 January 2018, 02:15:59 »
Singa is mostly normal 75 with bottom row blockers.  F-row is standard 75.
Offline gloomycloud
  • me enjoy 60s
Re: SINGA 75
« Reply #40 on: Mon, 08 January 2018, 02:35:25 »
Oh, the split F row look really great.
HHKB Pro Hybrid || Polaris || Kei || Meridian || Leviatán
Offline catweewee
  • Yellows
« Reply #41 on: Mon, 08 January 2018, 04:41:17 »
Not too sure but maybe this will help
Offline bminhz
« Reply #42 on: Mon, 08 January 2018, 11:39:29 »
Definitely help, they look much alike. Love what I am seeing here, definitely interested  ^-^
Offline pixelpusher
« Reply #43 on: Mon, 08 January 2018, 12:41:57 »
Wow.  Just... wow.   :thumb:
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #44 on: Mon, 08 January 2018, 12:44:28 »
Offline pixelpusher
« Reply #45 on: Mon, 08 January 2018, 12:57:10 »
oh Jesus.  This will be stuck in my head all day now.
Not only is this board a beauty, I learned this week that:
The English language name Singapore comes from its Malay name Singapura, which is derived from Sanskrit meaning "Lion City". Singa comes from the Sanskrit word siṃha (सिंह), which means "lion", and pūra (पुर) means "city" in Sanskrit and is a common suffix in many Indian place names.
Offline aaron6301
  • Pixel Pusher
« Reply #46 on: Tue, 09 January 2018, 15:20:03 »
Definitely in for a deep red, nice work  :thumb:
Offline rmendis
  • Artisan addict
« Reply #47 on: Wed, 10 January 2018, 00:05:41 »
The red looks awesome, Elaine! Definitely interested.
Offline SeedyOne
« Reply #48 on: Wed, 10 January 2018, 00:56:17 »
That red is amazing, definitely interested. +1 on the F-row spacing if possible too  :thumb:
Offline pixelpusher
« Reply #49 on: Wed, 10 January 2018, 01:55:37 »
I don't know if anyone has asked this yet or not:
In the first photo, the accent red keys (ESC and Enter)... are those from GMK Plum?  If so, they would be RO1 and seem to perfectly match the red of this case.
Burgundy R2 is coming up... might have to sign up for both :)
