Author Topic: IBM Model M, certain keys registering multiple keystrokes  (Read 1300 times)
Offline secularzarathustra
« on: Tue, 30 March 2010, 19:27:15 »
Has anyone run into a problem like this?
After a recent clean one of my model m's started registering double keystrokes for certain keys. For example if I hit "m" it registers "mh", when I hit "h" though it is correct. There are only four keys on the board that are doing this.
Is this board finally dead, or is there some way to resuscitate it.
Dark and the Desert and Destriers me ken,
And the Glaive and the Joust, and Paper and Pen.
Offline itlnstln
« Reply #1 on: Tue, 30 March 2010, 19:30:22 »
There might be a little water in the membrane (if you used water/cleaner).  Either that, or some broken rivets.
« Reply #2 on: Tue, 30 March 2010, 19:56:50 »
Crap, probably water in the membrane. Hmmm...maybe a hair dryer will help :)
« Reply #3 on: Wed, 31 March 2010, 07:54:24 »
I did remove them. Done this many times before without a hitch. Shouldn't of watched a video while cleaning, but man it's repetitive :)
