Author Topic: Anyone have changed the case on their iGK61?  (Read 2660 times)
Offline unluckygamer
« on: Thu, 11 January 2018, 00:57:18 »
Hi. I was thinking of changing my iGK61 case from the ABS one to maybe the 5 degree from KBD instead.
I am looking whether it is possible and how it went to someone who has made the change.
Offline Jacob4341
Re: Anyone have changed the case on their iGK61?
« Reply #1 on: Fri, 12 January 2018, 18:17:08 »
I Was thinking of doing the SAME things and really would love to know if this is doable.
Offline pixelpusher
« Reply #2 on: Thu, 25 January 2018, 21:16:57 »
It does not fit with the plate that comes in the kit.  I haven't disassembled it to see if another plate would work.
Offline Sshimosawa
« Reply #3 on: Tue, 01 May 2018, 01:18:49 »
Buy another backplate, any 60% will do. Then take the switches and stabs and transfer them over. I've done it on the ones I have and its quite easy.
