Author Topic: Cherry mx keycap topre sliders on massdrop  (Read 55648 times)
Offline nogoodnames444
  • I like keyboards
Offline zslane
Re: Cherry mx keycap topre sliders on massdrop
« Reply #1 on: Thu, 11 January 2018, 12:30:33 »
They are great except for one thing. The plate on a Topre Realforce lacks holes for the stems that hold stabilizer inserts on MX keycaps. That means drilling a pair of holes in the plate for every 2u (and larger) key position. Ugh.
  • I like keyboards
« Reply #2 on: Thu, 11 January 2018, 16:05:40 »
That's a major design flaw
Offline zslane
« Reply #3 on: Thu, 11 January 2018, 20:15:23 »
Flaw in the design of what? Topre keycaps don't have stabilizer stems, so there is no need for holes to accommodate them in the plate. This only becomes a problem when you try to put MX keycaps onto a keyboard that was never intended for them.
  • I like keyboards
« Reply #4 on: Wed, 17 January 2018, 14:28:48 »
The stabalisers
Offline Gajible
« Reply #5 on: Wed, 17 January 2018, 14:56:12 »
If you're drilling into the plate at any point you're doing it wrong!
You just need holes in the plastic "stabilizer insert". Easily done by hand and completely harmless should you revert back to Topre sliders
  • I like keyboards
« Reply #6 on: Wed, 17 January 2018, 15:31:50 »
Oh good cause i just baught some on kbd fans and you just saved me a lot of time
