Author Topic: [GB] LZ CLS s x h (Classic 60) : [Finish]  (Read 150765 times)
Offline dubious
  • 쏘쿨
Re: [GB] LZ CLS s x h (Classic 60) : [Finish]
« Reply #400 on: Tue, 30 April 2019, 14:53:47 »
Did anyone else have an issue with their plate where the switch openings were so tight that it actually compressed the switch and changed the feel? I got the b-stock CLS h, maybe it was just an issue with this unit.
If anyone has a plate file for this I'd be much obliged.
are you using holy pandas or some variation of them? i know that can be an issue on those switches
but also switches just change over time regardless soooo
Ink actually. I think I had an issue with MX Black too but I'll check again.
aren't those some holy panda variation? that's probably it
ink are gaterons with new plastic
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #401 on: Tue, 30 April 2019, 21:46:57 »
They're Gat linears.
I went and checked again, it seems fine after lubing, maybe the housings are compressed a little but with lube it doesn't matter.
I was using some frankenswitch originally and that was way too big for the cutouts, it really ruined the feel of those.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #402 on: Tue, 30 April 2019, 22:17:17 »
I had one cutout on mine that was too tight for the switches to fit and just took a file to it.
Problem solved.
Offline AlexG
« Reply #403 on: Wed, 22 May 2019, 22:03:07 »
Does anyone have the plate file? I'm trying to get a few cut. Thanks!
« Reply #404 on: Mon, 05 October 2020, 19:40:59 »
Anyone have the plate files for this board? I know LZ posted them but unfortunately the links are broken. Really want to make a custom plate for this, so any help would be appreciated. Thanks!
Offline MajorKoos
« Reply #405 on: Tue, 06 October 2020, 12:00:49 »
https://github.com/MajorKoos/KBDParts/tree/master/Switch%20Plates/CLS-Series
« Reply #406 on: Tue, 06 October 2020, 17:31:46 »
Thank you so much!
Offline AlexG
« Reply #407 on: Sun, 25 October 2020, 12:42:02 »
I need the plate file for this. It's restricted and I'm trying to get a new one cut
« Reply #408 on: Sun, 25 October 2020, 12:47:37 »
It's linked above
Offline AlexG
« Reply #409 on: Sun, 25 October 2020, 13:01:21 »
Offline Haskel
« Reply #410 on: Mon, 22 February 2021, 02:43:30 »
Can anyone confirm if the plates are 1.5mm?
Jane V2 CE | Frog TKL | GSKT-00 | TKL One (PC) | RS60
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #411 on: Mon, 22 February 2021, 05:13:17 »
Yes
