Author Topic: [GB] Round 1: CA66 Custom Keyboard Kit (CLOSED)  (Read 410624 times)
Offline donut_sauce
Re: [GB] CA66 Custom Keyboard Kit(GB Open)
« Reply #150 on: Sat, 20 January 2018, 15:00:17 »
Just curious? What switches are you guys planning to put on these? I used Cherry Browns my whole life and would like to try heavier switches. 67g Zealios or 80g Aliaz from kbdfans? I want it to be silent as well.
I知 going to go with R9 78g zealios I think, or if I can justify it I値l make some Zilent Pandelios.
I'm tryin to justify also if I wanted to go with the 67g r9 blue Zilent Zealios switches. $1.05 per switch.
Ill be put in in Hako clears
I'm totally regretting not having gone in on the hako gb. This is what I want to be doing. Congrats on getting in on them
Offline foxlive
  • The quick brown fox jumps over the lazy dog
« Reply #151 on: Sat, 20 January 2018, 15:33:12 »
I have R8 zealios 78g, they are amazing. The R9 78g are at .70$ on zealpc ;)
Offline tanvir175
« Reply #152 on: Sat, 20 January 2018, 15:38:19 »
Box Navy's or maybe some Feelios.
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #153 on: Sat, 20 January 2018, 15:54:59 »
Try putting the stem and spring in a Panda housing with a light lubing....possibly the best tactile switch available IMO
Offline DJ Shoko
« Reply #154 on: Sat, 20 January 2018, 16:00:49 »
I'm pretty torn between Brown or Dark Red, especially since I'm planning to throw GMK Camping on there. Leaning a bit more towards Dark Red tho tbh. .-.
Offline Paopawdecarabao
« Reply #155 on: Sat, 20 January 2018, 18:15:23 »
I値l just probably try kailh speed silvers. Linears for a change. Lmao
Offline Devkey
« Reply #156 on: Sat, 20 January 2018, 19:12:17 »
I got bored and crudely mocked up Laser on the gray and red...gray is safest, but I don't think red looks half bad.
Offline energyd
« Reply #157 on: Sat, 20 January 2018, 20:40:44 »
can u do a purple mockup?
Offline PlayKeyboardTW
    • Shop
« Reply #158 on: Sun, 21 January 2018, 05:29:11 »
Would it be possible to see pics of the plates and their different colors?
No sorry. Since they are all simple colors and no photos of them. :)
what does the lightbar do? can they be indicator lights or are the just for show?
If your light bar is open on default layer, it shows animations.
If's it's off, the color will change by switch to different layers. :D
Offline Troif
  • Carpe Diem!!!
    • Daniel Ferrer
« Reply #159 on: Sun, 21 January 2018, 06:29:01 »
How can I change the color option chosen? I already received the invoice with the wrong color... (my fault)
Sent from my iPhone using Tapatalk Pro
Filco TKL Ninja Blues / CODE Greens / Pok3r Clears / HHKBpro2 / RF 87U 55g / Novatouch TKL / KC60 Clears / SSK and also regular Model M
    • Shop
« Reply #160 on: Sun, 21 January 2018, 08:33:03 »
Please pm me, thanks. ;D
Offline eyedrop
« Reply #161 on: Sun, 21 January 2018, 10:26:52 »
PlayKeyboardTW, did you receive my PM? Thanks!
Sent from my PH-1 using Tapatalk
Offline Brammm87
« Reply #162 on: Sun, 21 January 2018, 11:28:31 »
Probably box whites here. Do wonder if the sound would reverb too much inside the case.
pls gief bbv2
Offline Devkey
« Reply #163 on: Sun, 21 January 2018, 15:51:52 »
Sure.
Offline Devkey
« Reply #164 on: Sun, 21 January 2018, 16:19:41 »
Would there be an elegant way to limit the bleed from the right LEDs? That's the main thing that's causing me to hesitate on this thing
Offline amnesia0287
  • Formerly Amnesia
« Reply #165 on: Sun, 21 January 2018, 16:31:50 »
Dim them?
« Reply #166 on: Sun, 21 January 2018, 17:32:25 »
What's the weight on this? It seems its goin to be light.
Offline dc_in_sf
  • Old Bastard
« Reply #167 on: Sun, 21 January 2018, 17:38:32 »
From an earlier post:
2. It is 1.2 ~ 1.3kg on  complete assembly.
Offline dc_in_sf
  • Old Bastard
« Reply #168 on: Sun, 21 January 2018, 17:39:19 »
a 66% board that supports TMK/QMK and I can get it in blue? I'm in!
    • Shop
« Reply #169 on: Sun, 21 January 2018, 20:51:14 »
You can decrease the brightness easily by setting up some function keys.
QMK has been tested. No problem. ;D
Offline amnesia0287
  • Formerly Amnesia
« Reply #170 on: Sun, 21 January 2018, 21:39:17 »
Oh, also if it really bothered you, in theory you could attach some adhesive backed foam to the PCB around the leds. Either strips cut to the right size, or if you wanted to be perfect, a sheet cutout with an xacto knife. As long as you got the thickness right the plate would compress it and seal a bunch of the light. You could also do the same thing to the plate/topcase and then it should block almost all of it.
Offline mudcakehoney
« Reply #171 on: Sun, 21 January 2018, 21:43:52 »
Anyone else going for brown?
I'd be interested to see the lighter brown of this GB vs the darker brown.
I don't think I've *ever* seen anything offered in brown before.
I feel like it's going to look absolutely BONKERS with GMK camping!
I'm so excited!
My R2 coffee brown came in today for reference sake (and cos I知 stoked to have it in my hands!) is quite dark but should colour match really well with SA Chocolatier
Offline Fiona
« Reply #172 on: Sun, 21 January 2018, 21:51:49 »
Cool ,how can i buy it/
    • Shop
« Reply #173 on: Sun, 21 January 2018, 22:06:06 »
This is the Groupbuy thread for CA66.
IC Link: https://geekhack.org/index.php?topic=91874.0
Here are some pics of past GBs held in China:
Other photos: https://imgur.com/a/PcfAP
                     https://imgur.com/a/OPB9q
Building Log: https://www.flickr.com/photos/149475414@N03/albums/72157688199776126
Case:
  • Anodized aluminum
  • Default colors: Black, Silver, and Gray
  • Custom colors:  Gray blue, Dark red, Brown, Rose gold, Purple
Plate:
  • Anodized aluminum
  • Default colors: Red, Blue, Gold, Silver
  • Brass plate
Badge(for HHKB like layout):
  • Default: Brass
  • Titanium
Pics of Colors: https://imgur.com/a/F6KXj
Features of PCB:
  • Black PCB. Gold pads
  • Type C interface
  • In-switch LED Position: South (not the same as you see in photos of previous GBs)
  • RGB led animation on the right side (see the pic)
  • TMK firmware, online editor supporting: http://ydkb.io/?ca66#
  • QMK supporting
Layout:
Price:
  • Case: 275USD/pc for default colors (including case, alu plate, PCB and brass badge if you choose HHKB like layout)
  • Custom colors: +16USD
  • Brass plate: +22USD (you will get one Aluminum plate and one brass plate)
  • Titanium Badges: +26USD (you will get one Brass badge and one Titanium badge)
  • additional PCB: +27USD
  • Shipping fee: 45USD (for all locations)
  • 4.4% Paypal fee
  • Other details will be listed in the invoice
Timeline:
  • Order deadline: Feb 15th
  • Estimated shipping date: May 15th
  • No quantity limit
  • Invoices will be sent out through GB time, and deadline of payment will be write down on them.
Order Link: https://goo.gl/forms/W2RI6Fk9ER8cYSiw2
Check Your Order Here: https://goo.gl/EpCgDE
Please PM me if you have any request.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #174 on: Sun, 21 January 2018, 22:52:18 »
Have any pins been broken out on the PCB for modding?
Wondering if all that space inside the  case could be put to good use?
Offline typischt
« Reply #175 on: Mon, 22 January 2018, 00:27:28 »
I'm so excited!
Looking good! What color is the plate exactly? Seems to be peach, really like that color!
« Reply #176 on: Mon, 22 January 2018, 04:07:32 »
I'm so excited!
It痴 Gold coloured aluminium plate
Offline Harms
« Reply #177 on: Mon, 22 January 2018, 14:27:16 »
 The debate is real on whether I should jump on this or not  :-\.
Offline foxlive
« Reply #178 on: Mon, 22 January 2018, 14:38:29 »
Ahah you definitely should! I think it was of the most amazing design I have seen here :) ! I am so excited about it  :p
Offline clickstops
« Reply #179 on: Mon, 22 January 2018, 15:23:17 »
I'm so excited!
OH boy. That's niiiice.
Offline Peppermint216
« Reply #180 on: Mon, 22 January 2018, 15:39:00 »
Quick Taro render
Offline Kaleidoscope
  • I need to get over this clack addiction.
« Reply #181 on: Mon, 22 January 2018, 16:33:17 »
Ohhh can you do one with Laser as well!
Offline tanvir175
« Reply #182 on: Mon, 22 January 2018, 16:40:26 »
There is one a little further up on this page with Laser
Offline child
« Reply #183 on: Mon, 22 January 2018, 16:42:16 »
Also a blue one with Laser would be nice
Offline typischt
« Reply #185 on: Mon, 22 January 2018, 19:36:24 »
Can the CA66 Brass logo/badge be removed from the case to be polished? Based on the images in the build log it seems that it is not able to be removed.
    • Shop
« Reply #186 on: Mon, 22 January 2018, 20:11:53 »
Yes, just remove a screw. ;D
is this a gray one?
https://geekhack.org/index.php?action=dlattach;topic=93542.0;attach=186540;image
Yes.
Yes, but you need to mod directly from 32U4.
There are some space available but don't know how much you need.
Offline Harms
« Reply #187 on: Mon, 22 January 2018, 20:24:36 »
Anyone else going for the Dark Red? If so what plate color?
A very unique color for a case.
Offline ptiede
« Reply #188 on: Mon, 22 January 2018, 20:35:53 »
I with went gold.
Offline MrTq
« Reply #189 on: Mon, 22 January 2018, 20:38:24 »
Is rose gold a good choise? Which keyset is best combination with it?
Offline Harms
« Reply #190 on: Mon, 22 January 2018, 20:44:56 »
I with went gold.
Nice choice. I'm thinking the same. :D
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #191 on: Mon, 22 January 2018, 20:56:49 »
Gold would definitely look the best imo. I still delaying getting in on this gb. Can't decide what switches to put in it.
Offline nguyenhimself
« Reply #192 on: Mon, 22 January 2018, 22:27:30 »
Probably white (like SA Valentine/DSA Hana) or light blue.
→ https://www.houzz.com/ideabooks/76473615/list/what-goes-with-rose-gold
Offline euphxenos
« Reply #193 on: Tue, 23 January 2018, 00:20:35 »
If you missed it, there's a link in the first post to a spreadsheet of everyone's choices:
Of the 114 CA66s ordered so far, 16 of them are dark red.  Of those 16, 7 have a silver plate, 7 have a gold plate, and 2 have a red plate.  14 of us also ordered the optional brass plate.
(mine is dark red with a silver plate, plus the optional brass plate)
Offline Harms
« Reply #194 on: Tue, 23 January 2018, 00:49:02 »
Thank you very much sir :).
« Reply #195 on: Tue, 23 January 2018, 02:07:45 »
rose gold is good
9009 goes with everything
Offline vewy_nice
« Reply #196 on: Tue, 23 January 2018, 07:39:38 »
Quick Taro render
DAMNIT, I can't afford 2 of these :(
That looks SO. GOOD.
I'm already planning on buying Taro, anyways.
Offline Kavik
« Reply #197 on: Tue, 23 January 2018, 10:53:54 »
This looks beautiful, but I can't justify another $300-400 on a keyboard. Best of luck on GB, and I can't wait to see others' pictures.
« Reply #198 on: Tue, 23 January 2018, 16:16:36 »
Blue doesn't look as good as I hoped it would. People who want to put GMK Laser on this puppy - Are you going with Purple or Grey for the case colour? I'm leaning towards Grey since it's a more versatile colour.
Offline Vigrith
« Reply #199 on: Tue, 23 January 2018, 16:55:56 »
I don't think attempting to match the dominant colour of a set (with the main exceptions being beige and black) to the case one is going to use it with is ever a good idea. I think black, grey, even silver (seeing as it is matte) are all better options for Laser than purple is, just my opinion though. I think the idea colour for a case for Laser however is bubblegum/neon pink, which may potentially be able to be achieved by anodising but probably best had via powdercoat; for example TKC's upcoming painted 1800 kits.
