Author Topic: [GB] Round 1: CA66 Custom Keyboard Kit (CLOSED)  (Read 410732 times)
Offline child
Re: [GB] CA66 Custom Keyboard Kit(Form closed, payment deadline to 16th)
« Reply #350 on: Mon, 19 February 2018, 03:13:49 »
QQ: do I need to buy switches that go on the pcb or on the plate?
If you want to use the plate (which I assume you do) you want plate-mount switches. However, this PCB has mounting holes allowing PCB-mount switches to be installed as well. So basically it doesn't matter :)
Offline mkarlsson
« Reply #351 on: Mon, 19 February 2018, 04:50:17 »
Even with plate I would still get pcb mounted switches, these ones include the 5 pins and the plate clip.
Offline MisterKnife
« Reply #352 on: Mon, 19 February 2018, 14:29:11 »
What is the upside of the pcb mounted over the plate mounted ones?
« Reply #353 on: Mon, 19 February 2018, 14:54:32 »
they're a little easier to align
Offline SeedyOne
« Reply #354 on: Tue, 20 February 2018, 02:48:39 »
Strange question but I'd assume the PCBs from earlier GBs would fit just fine in this one if for some reason we wanted to switch to North-facing LEDs (as this one is now south, unlike prior ones). Is that correct?
Offline PlayKeyboardTW
    • Shop
« Reply #355 on: Tue, 20 February 2018, 10:25:33 »
Correct. We took suggestions from the community to change orientation of switches. ;)
Offline SeedyOne
Re: [GB] CA66 Custom Keyboard Kit(Waiting for production after CNY)
« Reply #356 on: Tue, 20 February 2018, 14:45:38 »
Awesome, appreciate the info  :thumb:
Offline tanvir175
« Reply #357 on: Tue, 20 February 2018, 16:22:59 »
I'm super excited for this! Getting all jittery thinking about it  :D
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #358 on: Tue, 20 February 2018, 22:42:22 »
Pretty happy with the blue!
Offline mudcakehoney
« Reply #359 on: Tue, 20 February 2018, 22:56:32 »
That blue looks sublime! What caps and switches you putting on it?
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #360 on: Wed, 21 February 2018, 10:12:12 »
That blue looks really nice. I went with silver since it will match more sets than a more targeted color. That and I'll probably bring this keyboard to work and don't want it to be too flashy (not that dark blue is flashy, but pink/purple/etc...)
Offline JubJubCity
« Reply #361 on: Wed, 21 February 2018, 10:16:20 »
I picked Grey, I hope it will make my calm depths caps pop as well as be a universal case color for most key sets that I own   ;D
    • Shop
« Reply #362 on: Wed, 21 February 2018, 19:56:57 »
Glad it arrived to your hand safely. It looks nice. :D
Offline Makker4
« Reply #363 on: Thu, 22 February 2018, 06:25:46 »
This is my first build, so I could use some advice. What stabilizers do I need if I want to go with a ANSI and split spacebar? And should it be plate or pcb mount?
« Reply #364 on: Thu, 22 February 2018, 11:11:10 »
pcb mount, screw in preferably but not necessary if you're having trouble finding them
5x 2u (unless you want split backspace, then 4x)
Offline vewy_nice
« Reply #365 on: Thu, 22 February 2018, 12:54:50 »
I'd recommend getting a cheap kit board to practice on if this is your first build.
My first build, no matter how hard I tried, still kinda turned out meh.
I also had to desolder all the switches, because I forgot the spacebar stabilizer...
Especially for such a beautiful (and expensive) keyboard, it'd be worth picking up a bunch of really cheap parts to make a ~$60 practice board.
« Reply #366 on: Thu, 22 February 2018, 15:20:25 »
could also just buy a practice board and some loose wire for a lot less, but not as easy to make a return
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #367 on: Thu, 22 February 2018, 23:59:59 »
wait so we can choose led orientation? or is it set to South for this GB.
Offline eyedrop
« Reply #368 on: Fri, 23 February 2018, 00:02:29 »
This round for GH, the PCB has been revised for south facing LEDs.
Offline Makker4
« Reply #369 on: Fri, 23 February 2018, 02:35:29 »
Thanks for the advice. I just ordered a Gherkin kit to test my soldering skills on.
Offline MisterKnife
« Reply #370 on: Fri, 23 February 2018, 03:51:03 »
My first board as well, very happy with it. Finally a new little project where I can use my Weller soldering station :-)
gonna pair this up with a nice SA 1965 set
Offline vewy_nice
« Reply #371 on: Fri, 23 February 2018, 07:59:08 »
My 2nd build was a plate-mount Gherkin... And it turned out MUCH better than my first 60% ;)
It's not even just the soldering skills, it's aligning parts, remembering steps, and yes, making clean solder joints.
I've been soldering most of my life, and have 4 or 5 builds under my belt already, but I'm still going to be a bit nervous tackling this one. I just want it to be perfect!
Offline bball2
« Reply #372 on: Fri, 23 February 2018, 12:10:24 »
Quick question, for the WKL layout bottom row is it:
1.5 / blank / 1 / 1.5 / 7 / 1 / 1.5 or
1.25 / blank / 1 / 1.25 / 6.25 / 1 / 1.25?
« Reply #373 on: Fri, 23 February 2018, 13:25:17 »
looks like second one
« Reply #374 on: Fri, 23 February 2018, 16:54:31 »
Definitely 6.25
Offline bball2
« Reply #375 on: Fri, 23 February 2018, 19:28:41 »
Nice! Definitely makes compatibility of keysets a littie easier  :thumb:
    • Shop
« Reply #376 on: Fri, 23 February 2018, 20:36:59 »
Thanks for the help answer questions so far.  ;D
We just ended our CNY holidays and got lots of things to do these days.
Yeah it doesn't need to many add-ons.  :cool:
Offline Gamatatsu
« Reply #377 on: Sun, 04 March 2018, 20:34:32 »
Is it possible for me to change the color that I want from gray to black?
Offline Brammm87
« Reply #378 on: Mon, 05 March 2018, 07:37:13 »
Send a PM or mail to OP, I changed color too. Got a refund on the original invoice and a new invoice immediately.
pls gief bbv2
Offline MisterKnife
« Reply #379 on: Mon, 05 March 2018, 08:11:22 »
Can't wait for this to be shipped...  :p got my keyset ready for it
Offline l0uie
« Reply #380 on: Tue, 06 March 2018, 23:40:51 »
Are there any extras for sale?
Sent from my ONEPLUS A5000 using Tapatalk
Offline l0uie
« Reply #381 on: Wed, 07 March 2018, 00:13:50 »
If one of you wants to take my second order you are more than welcome to! Perhaps he can switch your name onto the order. Let me know if I need to do something for you!
This is the info:
CA66 Keyboard Kit
(Layout: HHKB like; Case color: Gray; Plate color: Gold)
1$275.00$275.00
Brass Plate
1$22.00$22.00
 Subtotal$297.00
Shipping$45.00
Paypal Fee (4.4%)$15.05
Total$357.05 USD
Is this offer still available?
Offline sacklunch
« Reply #382 on: Wed, 07 March 2018, 14:16:25 »
It was my order. I simply let it sit without paying (I had two orders and paid for the other one). Contact the seller and ask if there are any open slots?
Offline fendent
« Reply #383 on: Tue, 13 March 2018, 22:00:56 »
Offline BobCarltheThird
« Reply #384 on: Tue, 13 March 2018, 22:06:22 »
Stay strong and in shape, we've only got 2 months to go!
***loads of Vaseline for my meme TMO50 -- Acereconkeys
Offline bball2
« Reply #385 on: Tue, 13 March 2018, 22:45:51 »
Man saw someone sell one of the originals on r/mechmarket a few days. Looked amazing, can't wait for mine!  :thumb:
Offline tanvir175
« Reply #386 on: Tue, 13 March 2018, 23:27:24 »
Saw that too. He also had a built alps64 pcb with skcm blues for a ridiculous price of $150. I was, unfortunately, the second person to ask for it so I missed it :\
Offline vewy_nice
« Reply #387 on: Wed, 14 March 2018, 06:29:53 »
I was probably the 3rd then...
Yeah I spent a LOT of time looking at that timestamp.
I'm just so excited to build this dang thing!
Offline beekey
« Reply #388 on: Wed, 14 March 2018, 07:54:01 »
Hoping for a rerun. Missed this. :(
Offline tanvir175
« Reply #389 on: Wed, 14 March 2018, 12:55:18 »
Haha, I managed to snag some skcm blues that I will be using in the Modern M0110, whenever that comes around, but that deal was too good to be true.
I can't wait for this to arrive though. I think I want to build it using 78g Zeals, might take the time to lube it. I've already purchased some from the R10 GB from Zeal along with his transparent gold-plated stabs and am waiting for them to arrive.
    • Shop
Re: [GB] CA66 Custom Keyboard Kit(Manufacturing)
« Reply #390 on: Fri, 23 March 2018, 02:13:40 »
Hello guys, update here.
We are now in the manufacturing phase and hope everything goes well.
Thanks for everyone's patience. ;D
We got an email early this morning which asked us about why some CA66 photos were shown in replies.
Some of those were orders from Round2 groupbuy which was held in China.
He might be misunderstood the situation or just thought that we don't want to ship his order.
And he reported to paypal. :confused:
We already refunded to him and not going to take his order.
Please note the timeline below:
Order deadline: Feb 15th
Estimated shipping date: May 15th
No quantity limit
Invoices will be sent out through GB time, and deadline of payment will be Feb 15th.
Thanks everyone. :D
« Last Edit: Fri, 23 March 2018, 05:41:46 by PlayKeyboardTW »
    • Shop
« Reply #391 on: Fri, 23 March 2018, 02:14:26 »
(Blank post)
« Last Edit: Fri, 23 March 2018, 02:29:33 by PlayKeyboardTW »
Offline tanvir175
« Reply #392 on: Fri, 23 March 2018, 02:20:55 »
No quantity limit
Thanks everyone. :D
That's awesome! I can't wait to get this board in my hands :D
Shame about the guy who wasn't patient enough and forgot the timeline details in the OP.
Offline vewy_nice
« Reply #393 on: Fri, 23 March 2018, 10:04:37 »
You should give his slot to  l0uie  ;)
Offline l0uie
« Reply #394 on: Fri, 23 March 2018, 16:48:44 »
Haha I would love it but the M60-A is finally on sale and don't have the money for both :/
Offline beekey
« Reply #395 on: Sat, 24 March 2018, 05:32:32 »
I would love take the slot. :) Can I influence the color?
    • Shop
« Reply #396 on: Mon, 26 March 2018, 01:00:12 »
Hi everyone,
I got many PMs asking me if there is any extra to purchase.
The answer is yes, but I don't know the actual number right now.
The info will be released after we ship all our GB orders, then we will move on to this.
I think this is the most fair way for everyone, both GB attenders and those didn't join the GB but wanting to get a CA66. :thumb:
Thanks for PM me and shown your interest. ;D
Offline GreyAmbience
  • I can stop when ever I want
« Reply #397 on: Sat, 31 March 2018, 00:43:22 »
Hi everyone,
Sounds good dude! I can't wait for this GB to ship :)
Offline SeedyOne
« Reply #398 on: Sat, 31 March 2018, 02:14:35 »
Hi everyone,
Thanks for this. Will it be posted here or a separate thread do you think?
Offline fendent
« Reply #399 on: Wed, 04 April 2018, 19:37:12 »
