Author Topic: Vintage (pre 1977) keyboards - Desperate to find  (Read 5463 times)
Offline gofil10
« on: Tue, 16 January 2018, 09:43:25 »
Hi! Can anybody refer me to a dealer/marketplace/auction/etc. that has one or more pre-1977 keyboards up for sale? Urgently need one (ideally functioning) for a museum display project.
Offline JP
Re: Vintage (pre 1977) keyboards - Desperate to find
« Reply #1 on: Tue, 16 January 2018, 10:47:22 »
Probably eBay if you are in a pinch. I did find one keyboard but it was dated 1977.
About Me | The Collection
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Offline ander
  • I type, therefore I am
« Reply #3 on: Thu, 18 January 2018, 00:32:10 »
Most keyboards of that age were built into consoles, rather than freestanding units. So if it's just for a display, I wouldn't bother spending big bucks on a genuine '70s keyboard... I'd just make a little case out of plywood and put a $30 set of retro-styled keys in it, like these on eBay:
186741-0
Who'd know the difference?
Offline gofil10
« Reply #4 on: Thu, 18 January 2018, 15:08:41 »
Well, the keyboard should be able to operate the system next to it...
So it's more of a "working display"
Offline hking0036
« Reply #5 on: Thu, 18 January 2018, 16:30:49 »
That's a much harder task. A lot of 70's boards will have strange formats that don't have any way to convert to newer standards (yet, anyways). Good luck, though. Maybe if you can find a beamspring (were those 70's or just early 80's?) that will fit what you're looking for, but those are pricy. The pretend keycaps may be the best solution in this case.
« Last Edit: Thu, 18 January 2018, 16:41:06 by hking0036 »
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
