Author Topic: GH60 Satan shows up as "Unknown USB Device (device descriptor request failed)  (Read 3215 times)
Offline SnarlesBarkley
My GH60 Satan is showing up as "Unknown USB Device (device descriptor request failed) in device manager
I tried updating, uninstalling, via device manager and nothing happens just comes back as the same thing
Im trying to Use Zadig but its not working either comes up with the error Driver Installation: FAILED (Resource Already Exists)
Tried Flip and it doesnt even show up as a device i can work with
PLEASE HELP!!!!!
Offline Tactile
Does this happen before or after you press the programming button on the bottom?
REΛLFORCE
both times, No matter what i do it is stuck in that mode
Offline pixelpusher
I remember one time having to uninstall it in the device manager about 4 times in a row.  Each time checking the “delete driver software from this device” and then rebooting.  The problem I had was I screwed around with zadig and flip too much and it was loading instances of drivers in the OS.  It queues them up so when you remove one, the next one replaces it.  To get back to zero you have to remove each one, one at a time, always choosing to delete driver software.
This was my experience. Yours may differ.
Tried everything and still doenst get out of that mode...
Offline pixelpusher
Did you build it yourself or buy it assembled?
If it was DIY, did you test the board before assembly?
