Author Topic: Can you identify this keyboard?  (Read 1948 times)
Offline okan
« on: Tue, 23 January 2018, 05:47:56 »
Hey,
Can't see whats under the keycap but do you think is there a chance that this keyboard might be mechanical? Thank you!!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Can you identify this keyboard?
« Reply #1 on: Tue, 23 January 2018, 05:58:08 »
I very much doubt it.
Offline invariance
  • ...here with all the other boson's
« Reply #2 on: Tue, 23 January 2018, 16:42:30 »
Googled the part# and got a hit on cool3c but on my phone so can’t translate and see if it’s relevant.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline Tactile
« Reply #3 on: Tue, 23 January 2018, 23:04:05 »
According to the FCC ID it was made by Tai Hao so it's probably one of these.
REΛLFORCE
Offline ander
  • I type, therefore I am
« Reply #4 on: Wed, 24 January 2018, 00:50:21 »
Windows keys are usually a good sign a keeb isn't mechanical. (The Dell AT-101W [Alps Black] is the only commonly seen MK with Win keys.)
Another clue is the big word SOFT on the back. That'd usually refer to a "soft touch" board—meaning quiet, meaning non-mechanical.
