Author Topic: Pok3r spacebar LED issue!  (Read 3380 times)
Offline NolandC
« on: Fri, 26 January 2018, 15:22:13 »
Hey guys I recently got a new Vortex Pok3r and have noticed the two spacebar led's have some issues.  I was wondering if anyone has had this issue and or know of a fix? The link is to a video of my keyboard.
https://photos.app.goo.gl/ARePou0rOrO5iIfq1
Offline Hyde
  • White Tofu Extraordinaire
Re: Pok3r spacebar LED issue!
« Reply #1 on: Sat, 27 January 2018, 14:10:23 »
I'm not 100% sure but maybe double check Pok3r manual and see if you were stuck in some sort of programming mode.
I know the bottom 2 LED generally only light up if you're try to set special programming.
Offline NolandC
« Reply #2 on: Mon, 29 January 2018, 11:26:26 »
"I'm not 100% sure but maybe double check Pok3r manual and see if you were stuck in some sort of programming mode.
I know the bottom 2 LED generally only light up if you're try to set special programming."
Hey Hyde thanks for the reply.
 I have verified that the programming mode is not the problem by factory resetting the firmware. I have also updated the video to show the issue a little better. I think I'm going to have to open her up and check out the solder points. I'll post my findings for anyone interested.
