Author Topic: Changing the color of Novatouch case  (Read 2318 times)
Offline HiImScott
« on: Mon, 29 January 2018, 17:32:05 »
Has anyone here spray-painted the case on the Novatouch? It's made of this matte finish plastic material. I'm not sure what kind of spray paint I should use or what brand, I heard plasti-dip was an option but I also read that it sprays unevenly.
Offline MajorKoos
  • 1 life please. Extra large.
Re: Changing the color of Novatouch case
« Reply #1 on: Mon, 29 January 2018, 18:01:00 »
I sanded mine to get rid of the matte finish and then used a white plastic primer before applying spray paint.
It took about 3 days to fully cure.
Offline HiImScott
« Reply #2 on: Mon, 29 January 2018, 18:08:51 »
What kind of sandpaper did you use? What brand of spray paint and primer do you recommend? Thanks for your help.
Offline dubious
  • 쏘쿨
« Reply #3 on: Mon, 29 January 2018, 18:52:34 »
Photoelectric posted an excellent thread on painting cases
very thorough  :thumb:
Offline HiImScott
« Reply #4 on: Mon, 29 January 2018, 18:55:16 »
Oh sweet! Thanks for showing me this
