Author Topic: RGB PCB that works with 1up TKL  (Read 5117 times)
Offline proto
« on: Thu, 01 February 2018, 18:21:39 »
hi,
Does anyone know of an RGB PCB that works with the 1up TKL 2 plate case? (https://1upkeyboards.com/diy-tkl-2-plate-keyboard-kits-cf-black.html)
« Last Edit: Thu, 01 February 2018, 19:09:14 by proto »
Offline proto
Re: RGB PCB that works with 1up TKL
« Reply #1 on: Fri, 02 February 2018, 08:53:34 »
can anyone help with this?
Offline Giorgio
« Reply #2 on: Sun, 04 February 2018, 10:30:51 »
What kind of leds are you looking for, beside these?
Fancy LED Mods: Supports In-Switch Backlight Full LED, On-PCB Backlight LED, and Side LED
http://www.gonskeyboardworks.com/pcbs-and-controllers/60-nerd-tkl-ver20-pcb.html
Please keep me updated, I'm very intersted in your build.
« Reply #3 on: Sun, 04 February 2018, 14:37:51 »
hi,
1upkeyboards TKL isn't very good, it's bad at protecting the PCB, and it's generally not very good looking, and it doesn't sound good either
I think you'd be a lot better off buying the kbdfans 8x kit
it doesn't have RGB, but then again most kits don't
the only PCB that matters with RGB in-switch LEDs is the zeal60, and that's not a TKL PCB
there are a few others but they're not programmable
come on you should know better than to recommend GON PCBs from his site, he's a scammer
Offline TerryMathews
« Reply #4 on: Sun, 04 February 2018, 16:34:40 »
hi,
It's designed around a clone of Winkeyless's B.87 PCB, so an original or any of the clones would work. Look specifically for a USB connector on the left side of the PCB when looking at top.
I'm an idiot. GON's is the only board I know of that puts the USB there. Most are the left (Winkeyless, clones) or centered (Leeku)
« Last Edit: Sun, 04 February 2018, 16:37:02 by TerryMathews »
Offline Giorgio
« Reply #5 on: Sun, 04 February 2018, 19:12:01 »
hi,
The Gon keyboard is available on the 1up site.
« Reply #6 on: Sun, 04 February 2018, 19:15:23 »
hi,
nah, the USB is in the right spot, but it's on the bottom of the PCB, whereas standard placement is on the top
