Author Topic: IBM SSK With APL Keys  (Read 7502 times)
Offline JP
About Me | The Collection
Offline Techno Trousers
  • ʘ_ಠ
Re: IBM SSK With APL Keys
« Reply #1 on: Mon, 05 February 2018, 22:41:41 »
Just as a heads up for those who don't know, these appear to be the Unicomp version of the APL keys. More orange than red.
Offline JP
« Reply #2 on: Mon, 05 February 2018, 23:03:57 »
To my knowledge there essentially are three versions of these APL keys. The first were a reddish orange Model F quality keys and were used on terminal boards typically like the F104, next are the standard orange Model M era APL keys. Lastly are Unicomp's set which are inferior to the ones from the Model M era. Also Unicomp uses a different font so that is always something to look for.
Vintage Model M APL Set:
188068-0
Unicomp Vs. Model F era APL
188070-1
« Last Edit: Mon, 05 February 2018, 23:07:15 by JP »
Offline Giorgio
« Reply #3 on: Tue, 06 February 2018, 04:41:22 »
How much do these usually get? 300$?
  • ʘ_ಠ
« Reply #4 on: Tue, 06 February 2018, 12:54:52 »
You are definitely more knowledgeable than I am. Do you concur that these look like the Unicomp ones? It's also odd seeing an SSK without the number pad sublegends. Though I guess they couldn't have had both numpad and APL sublegends on those keys.
  • ʘ_ಠ
« Reply #5 on: Tue, 06 February 2018, 12:59:56 »
There was a big injection of SSKs into the market thanks to our resident seller. I've been seeing them go for between $185 and $235 lately.
If these are original IBM APL caps, I'd expect that to add maybe $125-$150 to the sales price. If they are Unicomp's, those sold for $40 a set, IIRC.   But a lot of people don't like them, so it's not likely to add to the perceived value over a stock SSK. It might even lower the price if the original caps with sublegends aren't included in the sale.
Offline JP
« Reply #6 on: Tue, 06 February 2018, 15:58:11 »
You raise some interesting points. Not having the original SSK keys should definitely be a factor in determining the value as those might not be easy to acquire if say you wanted the APL's for a different board or not at all. It is an older SSK at least so it will fetch a fair price regardless. I've heard the older Unicomp APL's were less faded than they are now but I do not believe these are Unicomp's.
Here is another comparison I found.
188105-0
Source:
https://geekhack.org/index.php?topic=62543.0
« Last Edit: Tue, 06 February 2018, 16:55:57 by JP »
