Author Topic: [GB] Chiwi60 kit w/ brass plate [under glow][Non-floating 7 deg] - Shipping  (Read 82152 times)
Offline voxkey
Re: [GB] Chiwi60 kit w/ brass plate [under glow][Non-floating 7 deg] - Shipping
« Reply #200 on: Wed, 30 January 2019, 19:04:21 »
On the hunt for a Chiwi60, preferably in gray, but also considering silver or white. Send me a PM if you have one up for grabs.
Offline sennin32
    • Doyu Studio
« Reply #201 on: Thu, 31 January 2019, 02:28:07 »
What happened to the website?
The Doyu shop displays some broken page with leather tools on the header image now:
https://shopkey.doyustudio.com/
Hi,
We're moving hosting to GCP but engineer ****ed up with database.
I've fixed it and the site, work now.
But we changed the theme, lot of image/text need to be replaced.
We're working on the new contents now :)
Speed is because of I turned cache server off when I'm testing web engine speed.
I'm working on how to make it faster even without cache server.
Offline .
« Reply #202 on: Thu, 31 January 2019, 02:45:47 »
Hello, I have a DO60 v0.2 PCB and a Chiwi60 (bought second-hand) and got a nice custom plate for it based on the design in the OP. (https://gitlab.com/sennin32/chiwi60/blob/master/plate/output/drw_plate_ansi.dwg)
However, it seems to not fit at all. Here are some pictures:
Note: there is a switch in the Esc key position
And this is the plate file I made to compare to the original: https://cdn.discordapp.com/attachments/490585581328531506/532969696262225970/custom_chiwi60.dxf.
No answer to this sennin?
Offline sennin32
    • Doyu Studio
« Reply #203 on: Thu, 31 January 2019, 02:46:57 »
Hi,
I measured again.
Distance between switches is correct.
What's your's PCB's switch spaces @@?
Offline .
« Reply #204 on: Thu, 31 January 2019, 03:41:12 »
Hi,
I measured again.
Probably not exactly 19.05mm. It's a pcb from you (DO60) so I think you would know.
Offline sennin32
    • Doyu Studio
« Reply #205 on: Thu, 31 January 2019, 05:04:23 »
Hi,
I measured again.
Strange, it should fit.
The pic is back space?
I can see it very clear, could you give me more pic so I can see which position goes wrong?
Offline sennin32
    • Doyu Studio
« Reply #206 on: Thu, 31 January 2019, 05:05:55 »
sorry, it has to take a while to check this, can't do a quick reply.
Offline .
« Reply #207 on: Fri, 01 February 2019, 03:33:48 »
I took some more pictures: https://imgur.com/a/zMegAo5
Offline sennin32
    • Doyu Studio
« Reply #208 on: Sat, 02 February 2019, 02:33:23 »
Only back space position has issue?
If there's only backspace.
Could you measure the distance of switch between the key has issue and the one of it's left?
Measure both PCB and plate.
it should be 19.05, see which one is not 19.05, should able to spot the issue.
Offline .
« Reply #209 on: Sat, 02 February 2019, 09:50:20 »
The battery of my digital caliper is dead right now, so I did some testing with GMK keycaps. As you can see the gap between 0 and - is bigger than the other gaps, which means that the two keys are off. You can also see that the tab key is off, which I also had problems with. I have not tested any other keys. The switches used are new PCB mounted Gateron Blacks.
212029-0
212031-1
Offline kiwi99
  • that's a gnarly dookie
« Reply #210 on: Tue, 12 February 2019, 18:20:24 »
yea the backspace 1+1u switch holes are off. they measure around 19.2mm give or take I just tried building a custom board with a do60 and found this issue as well so I think I can confirm maartenwut that its the pcb, I'll try to get some pictures. sorta disappointed since I lasered some stuff to use the do60s I had lol. :'(
Offline sennin32
    • Doyu Studio
« Reply #211 on: Wed, 13 February 2019, 04:18:45 »
Hi,
Yes I just confirmed that some of switches are a little off.
Some plates might not work.
could you send us a mail/msg?
see what we can do for that.
