Author Topic: [GB] Chiwi60 kit w/ brass plate [under glow][Non-floating 7 deg] - Shipping  (Read 81998 times)
Offline Lisinge
Re: [GB] Chiwi60 kit w/ brass plate [under glow][Non-floating 7 deg]
« Reply #50 on: Tue, 13 February 2018, 00:37:53 »
Can you tell us what the brass moq is and current number of brass orders? Also it would be great if you could tell us when the brass moq is reached so we know.
I think we can make when >20.
Got around 70+ interesting.
But the order quantity is not enough now.
If moq is not able to reach by next week.
We have to cancel brass ver.
Alright thanks. Would appreciate getting notified in time so we can put in a order for aluminum kit if brass moq is not reached.
Offline midnight2903
« Reply #51 on: Tue, 13 February 2018, 00:47:19 »
Will the white aluminium version chip?
« Reply #52 on: Tue, 13 February 2018, 01:04:01 »
hard to gauge, but if it's MAO it's definitely not a durable finish
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #53 on: Tue, 13 February 2018, 01:11:11 »
It's not MAO, it's more like a paint finish. ED is short for electrodeposition. Another name is e-coating.
« Reply #54 on: Tue, 13 February 2018, 01:13:39 »
ah, EPD
depends on what the coating is made of, if it's enameled/ceramic coating then yeah it can chip for sure, but if it's something stronger i think less likely
anodizing will always be the more durable option, followed closely by cerakote
of course, anodizing isn't always the most color-correct option and you can't ano white
but anyway
Offline babb2
« Reply #55 on: Tue, 13 February 2018, 03:15:24 »
Hello, very much interested.
What firmware does it use ? Sorry if this is a naive question but it's my first time custom keyboard and would like to be able to map easily :)
« Reply #56 on: Tue, 13 February 2018, 03:16:24 »
DO60 uses QMK, but apparently OP is trying to make it simpler (GUI maybe?)
Offline sennin32
    • Doyu Studio
« Reply #57 on: Tue, 13 February 2018, 10:41:53 »
Yes, we've found a solution to compile/flash qmk with gui, but with limited function.
We're looking for modify it, so people are able to use qmk without command lines.
Depend on which PCB you use.
DO60 use qmk.
Offline babb2
« Reply #58 on: Thu, 15 February 2018, 18:36:32 »
I love white, but can't help being worried about
- durability
- will it get dirty easy
esp. without having to touch this in person.
to buy or not is an easy choice, what color to buy is not!!
Offline Visionaire
« Reply #59 on: Thu, 15 February 2018, 20:35:16 »
Just placed my order, hopefully it still goes through!
Offline online
« Reply #60 on: Thu, 15 February 2018, 22:21:10 »
Interested in the brass case.
Can I use a standard 60% plate and PCB with the brass case?
« Reply #61 on: Thu, 15 February 2018, 22:29:41 »
- durability
White doesn't really get dirty easily, but durability might be a worry since its not anodized.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #62 on: Thu, 15 February 2018, 23:27:39 »
You can't use standard plates as this is top mounted. The upside is that the plate is included in the kit anyway and top mounted is said to be more stable than tray mount.
Offline Kavik
« Reply #63 on: Thu, 15 February 2018, 23:33:48 »
That full brass case looks amazing, and the layout looks great too. I'm trying not to buy anything else at the moment though, dang it. I guess I'll just enjoy the pictures. Good luck with the GB.
Offline online
« Reply #64 on: Fri, 16 February 2018, 00:43:59 »
Ok.
I thought it could be a good case for a handwired bluetooth project. :(
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #65 on: Fri, 16 February 2018, 00:57:04 »
Ok.
What are the prerequisites for handwired build? Wouldn't it still work regardless of whether it's top or tray mounted?
Offline rm-rf
« Reply #66 on: Sat, 17 February 2018, 02:47:47 »
how many orders are needed for the brass?
Offline KaosJ
« Reply #67 on: Sat, 17 February 2018, 07:48:51 »
Didn't get it, current count is 70+  and the MOQ is >20?
Offline Peppermint216
« Reply #68 on: Sat, 17 February 2018, 07:50:48 »
IC count was 70+ I think he means.
Current count is not at MOQ of 20.
Offline cdn-mini
« Reply #69 on: Sat, 17 February 2018, 07:52:53 »
I doubt they had any real intention of making it in brass.
They never once even addressed the many inquires about a matching brass bottom.
Bait and switch....pretty shameful.
Offline KaosJ
« Reply #70 on: Sat, 17 February 2018, 08:01:06 »
Not sure why they should bait you.
The fact they didn't wanted to give a matching brass bottom might be because they want it to be RGB without making a total new design for bottom, which is totally understandable.
I'm pretty sure that if they offered it, they want to make it if the MOQ allow it.  Would be a stupid and illogical bait, if they just showed the alu version, i would be already in for alu but since they showed the brass version too, i will be in only when the brass version will offer a different color of PVD.
Offline KaosJ
« Reply #71 on: Sat, 17 February 2018, 08:03:05 »
Probably right. Guess people don't want that gold color on PVD on brass  :D
Offline Minha
  • I Don't Want To Die Like Cobain
« Reply #72 on: Sat, 17 February 2018, 08:37:32 »
delete your account
Offline KaosJ
« Reply #73 on: Sat, 17 February 2018, 08:37:51 »
delete your account
LMFAO
Offline Vigrith
« Reply #74 on: Sat, 17 February 2018, 09:39:36 »
delete your account
Accurate
Offline Visionaire
« Reply #75 on: Sat, 17 February 2018, 18:04:28 »
delete your account
This. What a ridiculous accusation.
Offline KaosJ
« Reply #76 on: Sun, 18 February 2018, 05:03:12 »
delete your account
Well seems fair to respond to a ridiculous accusation with a ridiculous accusation.
cdn-mini sees conspiracies pretty often apparently and his reasons are just hilarious.
Offline rm-rf
« Reply #77 on: Sun, 18 February 2018, 05:12:40 »
what i really meant to ask was, how many left are needed to make it successful for the brass version?
« Reply #78 on: Mon, 19 February 2018, 05:34:25 »
Hey sennin, can you reply to my message? Thanks.
Offline afrokobe
« Reply #79 on: Mon, 19 February 2018, 09:58:22 »
sent a pm
Offline darthzero
« Reply #80 on: Tue, 20 February 2018, 12:31:51 »
The question is dark purple or dark grey^^
Discord: kuno#0600
Reddit: u/darthzero
Offline sennin32
    • Doyu Studio
« Reply #81 on: Wed, 21 February 2018, 11:03:30 »
Back from new year vacation this week!
It is not enough for now depend on the quantity we discuss with manufacturer.
Now, I have to ask if they're willing to make less.
If they do, will the price makes us losing money.
If we're going to lose money, we have to cancel it since the MoQ issue :(
Replied :)
Offline KaosJ
« Reply #82 on: Wed, 21 February 2018, 11:17:45 »
Replied :)
Just asking, the moq of 20 from your manifacturer is for pvd in general or is for each color in PVD? (even tho i know this gb was offering only gold pvd since you said me this already).
e.g. if in the future you want to make PVD black, gold and purple for example, will the moq be 20 for black, 20 for gold and 20 for purple, or just 20 for any of these colors?
« Last Edit: Wed, 21 February 2018, 11:19:51 by KaosJ »
Offline Darknight00z
« Reply #83 on: Wed, 21 February 2018, 17:20:45 »
PVD black hmmmmmmm
Offline KaosJ
« Reply #84 on: Thu, 22 February 2018, 03:01:41 »
PVD black hmmmmmmm
Yeah boi that's hot!  Asked sennin about it and he said maybe in the next rounds
Offline sennin32
    • Doyu Studio
« Reply #85 on: Thu, 22 February 2018, 08:07:54 »
for each color.
although it can be processed with other products for PVD.
But it makes manufacturer feels annoying to make multi colors.
Few people willing to do that even pay higher unit price.
For example.
Getting watch order for $1 profits each, 10000 pcs.
Getting keyboard order for $100 profit each, 10 pcs.
Not body will make keyboard for busy factories.
The other issue is even I begging manufacturer to make it for me with 10 pcs each color.
And they accept.
There will have people ask how about pink, rose gold, purple ...balabalabala, become endless issue.
We've offered so many options, people keep asking if xxx is possible, how about ooo.
If the quantity is enough, okay.
But we don't have money to cover so many options that is far away from MoQ.
Offline sennin32
    • Doyu Studio
« Reply #86 on: Thu, 22 February 2018, 08:12:36 »
PVD black hmmmmmmm
For the huge difference between interesting check and group buy result.
I think it is hard to run another round PVD group buy for this model.
I've asked PVD ver. quotation based on the quantity in the interesting check.
But finally get only 1/10 quantity of interesting check result.
I'll ask if manufacturer is willing to do this order.
If they can't, we can only cancel PVD orders.
Offline KaosJ
« Reply #87 on: Thu, 22 February 2018, 11:10:13 »
PVD black hmmmmmmm
Got it, i suggest to give it a chance for the next round, pretty sure people are not entering because it is GOLD pvd (which isn't appealing to many).  I heard plenty of people interested in PVD colored which looks awesome.  Pretty sure with a Black/titanium/other colors of pvd that was already with 40+ orders
Gold pvd is ok for plate and weight, but for the case looks a bit mehhhhh
« Reply #88 on: Thu, 22 February 2018, 17:20:04 »
Out of interest can you post the current order count?
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #89 on: Tue, 27 February 2018, 00:16:42 »
Brass version GB period has been extended in order to make MOQ (we're still 9 short)
https://shopkey.doyustudio.com/001kit00bp-gd
Buy up lads!
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #90 on: Tue, 27 February 2018, 20:14:27 »
New IC specifically for black PVD coated brass Chiwi.
https://geekhack.org/index.php?topic=94274.0
This is for serious buyers only.
Offline sennin32
    • Doyu Studio
« Reply #91 on: Fri, 02 March 2018, 14:59:08 »
Check more pics and latest pics here : https://www.instagram.com/doyushopkey
Talk **** with us on Discord : https://discord.gg/YkrdMpy
« Last Edit: Fri, 02 March 2018, 15:02:05 by sennin32 »
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #92 on: Sun, 04 March 2018, 08:30:33 »
Will this case able to fit DZ60 PCB? If not, will the DO60 PCB be able to create this layout: http://prntscr.com/imoyc5?
Also, will there be RGB LEDs pre-installed underneath the PCB? (Edit: seems to be so according to the website)
« Last Edit: Sun, 04 March 2018, 09:14:23 by cldskt »
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline cldskt
« Reply #93 on: Sun, 04 March 2018, 11:07:42 »
Additionally, is your website undergoing changes? It doesn't seem to be working - I can add items to "My Cart" but when it comes to the shipping page, it just keep loading forever.
Offline Liam
« Reply #94 on: Sun, 04 March 2018, 13:21:05 »
Yes for all questions. Remember to choose "Universal" in Layout and Port type.
IBM Model M - Leopold 750r - Custom Numpad
Offline sennin32
    • Doyu Studio
« Reply #95 on: Mon, 05 March 2018, 01:07:31 »
You can chose universal port.
And our PCB support this layout.
It should work, if not you can send us a screenshot.
Offline cldskt
« Reply #96 on: Mon, 05 March 2018, 01:37:17 »
Using another browser solves the problem! But the website seems to be lagging here and there still, hope you will solve the issue :)
Offline cldskt
« Reply #97 on: Tue, 06 March 2018, 03:44:44 »
Last day of GB! Wondering why this GB seems to be less popular than the rest  :confused:
Offline sennin32
    • Doyu Studio
« Reply #98 on: Tue, 06 March 2018, 04:07:19 »
I don't know T_T
Maybe people afraid I might run away with their money.
Offline cldskt
« Reply #99 on: Tue, 06 March 2018, 04:09:25 »
I don't know T_T
Has the MOQ been reached yet? If yes, there shouldn’t be a problem right? :)
And oh I wanted to ask, for brass weight at the bottom PC plate, will there be engravings? If yes, what would it be? Do you have a prototype to show? Would you offer the option to customize as well?
I think showing pictures of real life (latest) prototypes might help a lot with buyer's confidence if any :') And of course, reddit marketing would do wonders! :thumb:
« Last Edit: Tue, 06 March 2018, 04:19:11 by cldskt »
