Author Topic: Broken HHKB from... who?  (Read 2960 times)
Offline didjamatic
« on: Sat, 03 April 2010, 22:59:47 »
Ebay seller pooponanengine has a broken HHKB available.
Offline skcheng
    • Tenafly Dentistry
« Reply #1 on: Sat, 03 April 2010, 23:15:57 »
Can those broken switches be replaced?   It was fairly simple replacing a cherry blue on a Filco.
Offline kriminal
« Reply #2 on: Sun, 04 April 2010, 00:48:27 »
no you cant replace the switch i think, because it uses a rubberdome membrane or "mat" with springs under each dome..
but older geekhackers can correct me on this..
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline Rajagra
« Reply #3 on: Sun, 04 April 2010, 01:02:45 »
All versions of the Happy Hacking keyboard other than the "Professional" ones use membrane switches.
http://en.wikipedia.org/wiki/Happy_Hacking_Keyboard
Having said that, the original HHKB might feel better than the mediocre HHKB Lite. There has to be a reason they called it the "Lite" version, right?
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #4 on: Sun, 04 April 2010, 01:55:36 »
Ask yourself this one question-
Would you buy something from someone with the name "pooponastick"
errrr..."engine"?
haahaa =P
Since it's not a mechanical board, its not really worth fixing with the prices of working ones in great shape for cheap.
haahaa, whatta name XD
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline elbowglue
« Reply #5 on: Mon, 05 April 2010, 00:09:48 »
Heh I was fooled into thinking this was a capacative keyboard.. but it's a dome..  wonder how you fix a dome keyboard. :P
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
