Author Topic: Help choosing switches  (Read 2980 times)
Offline p_blaze
« on: Fri, 09 February 2018, 13:21:51 »
So I'm looking for nice switches for my next keeb. I wanted to get navy box switches, but the sound level seems to be too high (any sound much louder than an mx white is a problem). It would be awesome if anyone could recommend a quiet switch with similar tactility to the navys. Thanks :D
Offline MGMorden
Re: Help choosing switches
« Reply #1 on: Fri, 09 February 2018, 13:27:25 »
78g Zealio's?
I personally love clicky switches but if you want quiet a regular tactile switch is likely better and those are pretty decently heavy like the Navy Blues.
The other option would be Box Burn Oranges.  Same spring as the Navy Blues without the click bar.
Boards: Unicomp Spacesaver (Buckling Spring) - IBM Model M (Buckling Spring) - Scorpius iOne M10 (Cherry MX Blue) - Logitech K840 (Romer-G) - E-3lue Cobra (replaced with NovelKeys Box Jades) - Smith Corona 6311 (Acer switches) - Matias Tactile Pro PC (Matias Click Switches) - Apple Desktop Bus Keyboard (Alps SKCM Orange)
« Reply #2 on: Fri, 09 February 2018, 13:27:47 »
78g zilents
Offline _rubik
« Reply #3 on: Fri, 09 February 2018, 13:42:29 »
Not box, but I'll always recommend 70g Kailh Burnt Oranges. (I think Kailh has box equivalents ).
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #4 on: Fri, 09 February 2018, 14:06:35 »
Can't go wrong with Zealios. With each iteration/round they to get even better.
Offline p_blaze
« Reply #5 on: Fri, 09 February 2018, 14:12:17 »
Thanks for the recommendations! I'm interested in both, but I kind of want a crisp, almost clicky/crunchy freeling rather than a smooth bump like mx browns. Would the zealios or box switches be closer to this?
Offline macclack
    • Macclack
« Reply #6 on: Fri, 09 February 2018, 14:14:26 »
With Zealios, anything 65g or higher gets into the territory I think you're wanting. 67g might be a good place to start.
Offline mike-y
« Reply #7 on: Fri, 09 February 2018, 18:01:49 »
I have a batch of the Kailh Burnt Orange, and honestly, they feel more like a linear switch to me.  With the stiffer spring, the tactility actually feels less prominent than on the lighter brown box switch.  Maybe because you need more force to push the spring down, that it masks some of the force you'd need to get past the bump.
65g Zealios are the most tactile switch I own, but I don't have anything stiffer than that to compare to. I'd say they have a more noticeable bump than the box burnt orange.
Offline p_blaze
« Reply #8 on: Fri, 09 February 2018, 18:32:06 »
I might bite, then. Zealios sound nice but the price hurts my soul
EDIT: welp they sold out of 75g, looks like I need to look for something else. Outemu ice dark purple is supposedly similar to zealios, can anyone confirm this?
« Last Edit: Fri, 09 February 2018, 18:36:14 by p_blaze »
Offline _rubik
« Reply #9 on: Sun, 11 February 2018, 18:27:37 »
There is certainly merit in this observation. For me, I feel the bump more on the release then the press. The bump is also much closer to the top of the travel, as apposed to other switches where the tactile feedback is at the middle. For me, I like a smooth linear switch, but also love a stiff tactile bump; Burnt Oranges are a happy medium.
