Author Topic: FUSION : 60% aluminium case  (Read 3155 times)
Offline Vulcan
« on: Mon, 12 February 2018, 04:24:20 »
This is my second time making a keyboard case, the first case i made is for my presonal use. but this time i want to make a case that is sellable to the market, so I really need your help to make this case design better than it is.
the case i want to make is a 60% case, and this is the specification:
MAIN BODY
I will name this case "FUSION", The mian body for this case is made with aluminum
COLORING
For coloring I will try to anodize it or if not powder coating, which one is better?
ANGEL
I think 8 Degree is good enough, you guys have any suggestion?
how to get url for picture
FYI : I already made a tall version of this case, what do you guys think?
Offline gr4v3m4n
    • my store
Re: FUSION : 60% aluminium case
« Reply #1 on: Mon, 12 February 2018, 06:58:51 »
maybe you should put it on interest check, possibly got better feedback.
Offline Vulcan
« Reply #2 on: Mon, 12 February 2018, 23:06:27 »
Okey.. thank you
Sent from my SM-G935F using Tapatalk
