Author Topic: E6-V2 Round 2 - 60% custom keyboard -GB OPEN  (Read 59635 times)
Offline excluisve
  • Making & Thinking.
Re: E6-V2 Round 2 - 60% custom keyboard
« Reply #50 on: Tue, 13 February 2018, 21:21:17 »
I have sort the asking.
FAQs:
1.Is there have sliver ?
- is okay but final colors still just have 5
2.It will have brass opton?
- yes,it have brass plate name tag weight and middle (plz check the Specifications:  )
3.Why there was no qmk pcb and left port ?
-For R1 i have run 4X different pcb 2x plate 2x case it really makes me meesed up
- so in the R2 just have middle port and bootmapper ,i think  bootmapper is functional and easy to use
- my original opinion was make run smooth and clear .
4.R1 parts were fit with R2?
- i am sorry that R2 have modify something btw r1 weight and name tag was fit
5.Where is the Dark blue?
-Is show on homepage with GMK Nautilus
6.Why there was no big block ?
- personal thinks small may fit well with 60% makes it unique but for the big block may more fit with 80%
- things still way out ,final decision still depends on our discussion
sounds good, thanks
i really want apple silver and teal
and as long as there's HHKB i'll probably join regardless of color choices
Apple sliver actually is lit bit grey.this color between sliver and white.
sry it not available in R2 :(
Offline Vadurr
  • Valar Morghulis
« Reply #51 on: Tue, 13 February 2018, 21:23:11 »
The dark green looks amazing. But I can't really think of any keycaps that would fit that aside from maybe Royal Alpha which got cancelled :(
epbt green
ccng
white blanks
I can understand EPBT green and CCnG (cant find it tho), but would white blanks even look good on the dark green?
White blanks would look good on anything IMO.
« Reply #52 on: Tue, 13 February 2018, 21:23:41 »
FAQs:
sounds good, thanks
regular silver is OK too, i mostly just want it to sort of match my mira for the nice family pictures
but if not, that's ok too, i'm not locked in yet
Offline midnight2903
« Reply #53 on: Tue, 13 February 2018, 21:24:05 »
FAQs:
Thanks, maybe you should put this in the first post.
« Reply #54 on: Tue, 13 February 2018, 21:24:25 »
epbt green
ccng
white blanks
ghost white EPBT :nut:
https://kbdfans.myshopify.com/collections/keycaps/products/enjoypbt-blank-keycaps-117keys
Offline excluisve
« Reply #55 on: Tue, 13 February 2018, 21:25:57 »
FAQs:
Thanks remind me
« Reply #56 on: Tue, 13 February 2018, 21:26:22 »
epbt green
ccng
white blanks
I was thinking of getting that for another keyboard, looks pretty shiny tho.
« Reply #57 on: Tue, 13 February 2018, 21:26:48 »
epbt green
ccng
white blanks
they're more matte in person
Offline amnesia0287
  • Formerly Amnesia
« Reply #58 on: Tue, 13 February 2018, 21:35:24 »
CCNG was cancelled, Royal Alpha was just delayed because one of the proxies didnt pay or something, unless I'm missing something.
Offline Peppermint216
« Reply #59 on: Tue, 13 February 2018, 21:47:43 »
Fyi silver was added to the IC, get revoting
Offline Vadurr
  • Valar Morghulis
« Reply #60 on: Tue, 13 February 2018, 21:52:41 »
Does anyone know how tall this board is in the front?
Offline amnesia0287
  • Formerly Amnesia
« Reply #61 on: Tue, 13 February 2018, 22:27:42 »
The bumpons it comes with are kinda massive (at least R1), so its up pretty high by default, but the case itself is ~20mm.
Offline godinjointform
« Reply #62 on: Tue, 13 February 2018, 23:09:28 »
Would definitely pick up a silver version. Maybe a dark blue, too...
« Reply #63 on: Tue, 13 February 2018, 23:59:06 »
I think donutcat said that GMK have yet to reply to him, so yea maybe not cancelled per say but probably won't be out for some time.
Not really a fan of cases that are too THICC in the front so hopefully the bumpons are milder now
« Last Edit: Wed, 14 February 2018, 00:02:04 by midnight2903 »
« Reply #64 on: Wed, 14 February 2018, 00:50:10 »
i just bought a ton of small bumpons on amazon for like $6
Offline excluisve
« Reply #65 on: Wed, 14 February 2018, 00:54:22 »
2cm
Offline Vadurr
  • Valar Morghulis
« Reply #66 on: Wed, 14 February 2018, 01:13:33 »
Offline donut_sauce
« Reply #67 on: Wed, 14 February 2018, 04:43:08 »
Does the PCB have Qmk support or bootmapper only? Qmk would be wonderful
« Reply #68 on: Wed, 14 February 2018, 05:00:55 »
BootMapper only, see the second post for FAQ.
Offline donut_sauce
« Reply #69 on: Wed, 14 February 2018, 05:26:10 »
I did see that. Some bootmapper pcb’s also support QMK so was looking for clarification if this does too
Edit: looks like post now says QMK supported. Woohoo! In:)
« Last Edit: Wed, 14 February 2018, 05:27:49 by donut_sauce »
« Reply #70 on: Wed, 14 February 2018, 05:27:42 »
The FAQ changed, QMK supported.
Offline excluisve
« Reply #71 on: Wed, 14 February 2018, 10:48:19 »
any chance we will have the option to buy just case/plate/weight?
You don’t need PCb ? But PCb was customized .you may can’t find PCb fit case
« Reply #72 on: Wed, 14 February 2018, 12:03:08 »
maybe he has extras from r1? idk
« Reply #73 on: Wed, 14 February 2018, 12:08:11 »
I can't see anyone mentioning the exagerated embossing on the logo/nameplate for round 2, what are everyones thoughts on this?
I prefered the flush design.
Offline excluisve
« Reply #74 on: Wed, 14 February 2018, 21:11:50 »
We will have all brass version limited 10,next few days rendering
Offline excluisve
« Reply #75 on: Wed, 14 February 2018, 21:15:44 »
So we will be able to get white MAO?
Also exclusive is there any chance to get full 1u blockers for small block?
1U Block supported now .
Offline Peiweisgreat
« Reply #76 on: Wed, 14 February 2018, 23:37:03 »
Geez, I definitely have to hop back on for round 2. I love this freaking E6 I'm using right now, but I need one that isn't scratched. It just wouldn't be right to not try and get a perfect one. Count me in Exclusive, but give my wallet a little bit of time to rest. The spirit is willing, but the flesh is spongy and bruised.
Offline excluisve
« Reply #77 on: Thu, 15 February 2018, 02:51:14 »
Haha thanks Peiweigreat. it have time to let wallet rest   ;) ;) ;)
Offline InvidiousIgnoramus
« Reply #78 on: Thu, 15 February 2018, 11:28:31 »
That's okay, i didn't need that money anyway.  :eek:
I long for the day when I find a beamspring. (At a not insane price)
« Reply #79 on: Thu, 15 February 2018, 11:32:42 »
What's with everyone going all brass recently?! It looks so weird.
Offline kmba
  • Formerly tameone
« Reply #80 on: Thu, 15 February 2018, 11:39:55 »
You can coat brass. And should. Doesn't have to be shiny and uggo
keyboards.
« Reply #81 on: Thu, 15 February 2018, 11:58:13 »
Wrong. Uncoated brass is the only way to go.
Offline amnesia0287
  • Formerly Amnesia
« Reply #82 on: Thu, 15 February 2018, 12:07:45 »
E6 brass isn’t shiny. Is matte and sexy as hell.
Zomg. Sign me up. Would it work with colored weights and midcases?
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #83 on: Thu, 15 February 2018, 12:16:57 »
You have my wallet now!  ;D
Offline HardcoreDesk
« Reply #84 on: Thu, 15 February 2018, 18:08:11 »
dibs
Offline excluisve
« Reply #85 on: Thu, 15 February 2018, 19:23:28 »
Today was Chinese New Year ‘s first day
Best wishes to you!
« Reply #86 on: Thu, 15 February 2018, 20:08:40 »
Best wishes to you!
Thanks exclusive, enjoy your holiday.
Offline Muffin_Smasher
« Reply #87 on: Thu, 15 February 2018, 21:48:27 »
The Special Teal + Black combo would be a definite buy for me.  I'm hoping it is one of the chosen colors.
Offline Tally810
« Reply #88 on: Thu, 15 February 2018, 23:31:27 »
Looking good exclusive.  I'll be down for one.
Offline godlikekitten
« Reply #89 on: Thu, 15 February 2018, 23:45:23 »
Could someone explain how the "Rows" work when choosing colors?  I only see 3 possible rows for the case the top, middle, and bottom.  As for the plate section do those rows go in order so Row 1 is the color for the plate, row 2 for the name tag, and row 3 for the weight?  Wanna get in on this but not sure what I'm selecting lol
Offline fatpolomanjr
« Reply #90 on: Fri, 16 February 2018, 00:38:20 »
I have the exact same questions as godlikekitten: are the Rows our preference from 1st to 5th? Like voting for what 5 colors will be available for the case and what 3 colors for plate/nameplate/weight?
I really dig the red and black hhkb layout though. Only thing I might want is the option for the middle part of the case to be red and the plate to be black. But even then I'm not sure since it already looks so good and is the perfect bloody/murderface case.
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline excluisve
« Reply #91 on: Fri, 16 February 2018, 01:09:51 »
Thanks tally ;)
Offline excluisve
« Reply #92 on: Fri, 16 February 2018, 01:11:32 »
as fatpolomanjr said:  voting for what 5 colors will be available for the case and what 3 colors for plate/nameplate/weight
Offline excluisve
« Reply #93 on: Fri, 16 February 2018, 01:15:45 »
Yes it was
Offline GeneriksGiraffe
  • Living the Rubber Life
« Reply #94 on: Fri, 16 February 2018, 14:41:16 »
Would the "dark blue" and "special teal" case color options work well with GMK Nautilus?
SOMEONE PLEASE SELL/TRADE ME AN HHKB PRO 1
Offline excluisve
« Reply #95 on: Fri, 16 February 2018, 19:23:15 »
Yes, the  combo was dark blue top and bottom with special teal middle
The mainly picture
Offline excluisve
« Reply #96 on: Sat, 17 February 2018, 07:48:42 »
Save time to build it WKL big block
Offline oatmicro
« Reply #97 on: Sat, 17 February 2018, 08:05:38 »
Love that big block WKL and also Two-piece style(?) as well  :thumb:
Offline zekkin
Re: E6-V2 Round 2 - 60% custom keyboard -updated 1U block supported
« Reply #98 on: Sat, 17 February 2018, 08:34:33 »
Big block is the way!
Offline kuang2
« Reply #99 on: Sun, 18 February 2018, 11:03:56 »
I have some picture of E6 in Apple Silver: https://imgur.com/a/aN6Re
and I will ask Exclusive to change the bumpon to 3M SJ5302 :-)
and have more render soon
