Author Topic: [IC] Dedicated Keycap Set for 75% Keyboards. (50$ FOR THE BASE KIT) (Cubic)  (Read 13616 times)
Offline CAPS UNLOCKED
    • capsunlocked
Hi,
This is a thread to gauge whether there is interest in a keycap set specifically for 75% keyboards.
Here is the current proposed layout:
188865-0
Possible New Layout:
189021-1
This is a budget keycap set, that is aimed at those whom are looking for a keycap set for their new (or current) 75% keyboard.
If you would like to provide feedback for this keycaps set, please leave a comment below.
Kind regards,
capsunlocked
« Last Edit: Tue, 13 March 2018, 08:39:18 by CAPS UNLOCKED »
Offline p_blaze
Re: [IC] A Keycap Set for 75% Keyboards.
« Reply #1 on: Tue, 13 February 2018, 16:10:05 »
I don't think there's enough of a price difference between a tkl set and a 75 set. Might as well buy a tkl set and save probably more money because of moq fulfillment and have wider appeal.
« Last Edit: Tue, 13 February 2018, 16:16:17 by p_blaze »
Offline TalkingTree
    • My projects
« Reply #2 on: Tue, 13 February 2018, 16:12:10 »
Gladly. GMK with R0 and R5 rows.
Offline noSatellite
  • perpetual n00b
« Reply #3 on: Tue, 13 February 2018, 16:14:58 »
I am absolutely down for this. GMK sounds awesome. I would also be in for DSA.
What I lack in time, resources, and knowledge I make up for in passion, enthusiasm and ignorance.
    • capsunlocked
« Reply #4 on: Tue, 13 February 2018, 16:32:44 »
Thank you for your feedback.
Unfortunately a standard 108/109 keycap set does not feature a 1.75 shift key.
Thank you for the feedback!
This is unlikely to be created by GMK, due to the price. I would consider DSA.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #5 on: Tue, 13 February 2018, 16:38:52 »
I would recommend adding a 1.5u Ctrl and a 1.5 Alt for the right of the spacebar for those who would prefer not to use 3x 1u keys.
« Reply #6 on: Tue, 13 February 2018, 16:41:31 »
or for boards that don't support 3x 1u
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #7 on: Tue, 13 February 2018, 16:48:59 »
Speaking of which, I recommend:
- 2x 1.5u Ctrl
- 2x 1.5u Alt
- 1x 7u Spacebar
- 1x 1.5u HHKB Backspace <---
See below for bottom-row guidance:
Offline Jhors2
« Reply #8 on: Tue, 13 February 2018, 17:55:07 »
I agree with this.
Duck Blackbird | Duck LSv3 | Duck Unicorn X Legend |  TX-75 | Mira SE | LZ-CP | LZ Iron | LZ Ergo | Duck Jet Fire | OTD 360 Corsa Apple Silver | TGR-910 CE
Incoming: Zeal Zephyr | Duck TC-V3 | Singa R2 | LZ GH v2 | Noxary 280 S | Noxary 220 S
Offline TwiztedGaming
« Reply #9 on: Wed, 14 February 2018, 04:36:54 »
Could we get it in white or would black be the only option?
Sent from my Pixel using Tapatalk
Offline kmba
  • Formerly tameone
« Reply #10 on: Wed, 14 February 2018, 06:45:50 »
As long as is supports alternate bottom rows, and works with most 75, 68, 65, 60, and hhkb layouts, it should be worthwhile. 68 would require a second 2u shift.
keyboards.
    • capsunlocked
« Reply #11 on: Wed, 14 February 2018, 11:41:26 »
- 2x 1.5u Ctrl
- 2x 1.5u Alt
- 1x 7u Spacebar
Those can be added, however this set will most likely feature the DSA profile.
The colour scheme has not been decided yet, I was curious as to whether there was interest in the layout.
I will only be adding keycaps that are relevant to the 75% layout, as I want this to be as affordable as possible. Sorry.
    • capsunlocked
« Reply #12 on: Fri, 16 February 2018, 13:37:13 »
This is the latest layout:
189023-0
Is there interest in this kit?
The Signature Plastics colours used are:
- Keycaps: NN
- Legends: GY
No colours have been confirmed.
« Last Edit: Fri, 16 February 2018, 13:39:05 by CAPS UNLOCKED »
Offline kmba
  • Formerly tameone
« Reply #13 on: Sat, 17 February 2018, 08:03:26 »
That is better. All it needs now is split backspace support, which I might add, is an option and used on 75%s
keyboards.
Offline xondat
  • i'm not a star
« Reply #14 on: Sat, 17 February 2018, 08:30:45 »
And stepped caps ;)
    • capsunlocked
« Reply #15 on: Tue, 20 February 2018, 13:25:32 »
Thank you for your feedback, this is going to be the final kit:
189206-0
I think that this set will be produced by SP, and the profile will be either DCS or DSA.
The profile and colour theme need to be confirmed, so I am open for feedback/suggestions. :)
Offline xondat
  • i'm not a star
« Reply #16 on: Tue, 20 February 2018, 13:45:59 »
Can't help but say this: if you're doing split backspace, it's pointless without a R2 1.5u backspace. I'd add that, and make one of the blanks the | \ key.
    • capsunlocked
« Reply #17 on: Tue, 20 February 2018, 14:52:50 »
Sure, I can add that.
Offline xondat
  • i'm not a star
« Reply #18 on: Tue, 20 February 2018, 14:54:35 »
Also +1 to DCS.
The text alignment on the mockup is off, any pictures of what is expected with DCS/DSA?
    • capsunlocked
« Reply #19 on: Wed, 21 February 2018, 01:31:42 »
I have fixed the layout.
Here are some simple, but classic, colour schemes:
189305-0
189307-1
If you would like to see a particular colour scheme, please let me know.
« Last Edit: Wed, 21 February 2018, 01:37:57 by CAPS UNLOCKED »
    • capsunlocked
« Reply #20 on: Wed, 21 February 2018, 01:37:38 »
Those images with the white keycaps were not very clear, here they are again:
189309-0
189311-1
Offline Petch
« Reply #21 on: Wed, 21 February 2018, 07:29:12 »
1.75 R3 control key please
Is the nav column intentionally left blank?
    • capsunlocked
« Reply #22 on: Tue, 13 March 2018, 08:21:10 »
Tai-Hao can produce this set, and the base set will be 50$.
The profile will be cubic.
No colours have been confirmed; all suggestions are welcome!
All feedback is appreciated!
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
Switching out those blanks for R1 Printscreen, Delete, Home, Insert, R2 Page Up, R3 Page Down, and R4 End would be nifty, and maybe even make the R1 blank for split Backspace into Scroll Lock, that way there's a ~full set of nav keys instead of just blanks.
Just to make it clear, not saying that split backspace should be scroll lock, most likely delete may go there, but using that last blank spot for at least one of the nav keys is a good use.
« Last Edit: Tue, 13 March 2018, 22:42:49 by donutcat »
Offline Visionaire
Very interested, depending on profile and price. Will be watching!
    • capsunlocked
The reason as to why they are blank is because not everyone uses those keys on a 75%.
    • capsunlocked
A few users in the reddit IC were interested in seeing this set with the Miami Nights Colour Scheme:
191860-0
What does the community think?
Offline Visionaire
Would REALLY love it in that color way. Might be my phone but the 2nd color doesn't look to be cyan like Miami Nights and though. What colors would you use? Instabuy for me in that color way
Sent from my SM-G920V using Tapatalk
    • capsunlocked
191862-0
I have added the corrected version!
Thanks for the support!
