Author Topic: [IC] FUSION60  (Read 263690 times)
Offline Kerasan
Re: [IC] FUSION60 (Final Design & Estimate Price)
« Reply #150 on: Mon, 28 May 2018, 14:26:08 »
This is how the prototype looks like.. we cant make the sides looks as sharp like the 3d render.. what do you guys think? Should I keep it like that or remove the side design?
Sent from my SM-G610F using Tapatalk
this detail seems to be the weak point of design, it could improve imho. however, the look is really nice.
KMK Labs
« Last Edit: Mon, 28 May 2018, 14:28:44 by Kerasan »
Offline Vulcan
« Reply #151 on: Tue, 29 May 2018, 05:46:33 »
Here is another photograph from different angel
Offline Vulcan
« Reply #152 on: Tue, 29 May 2018, 06:26:07 »
KMK Labs
Yea.. i agree..Do you have a suggestion to fix that?
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #153 on: Tue, 29 May 2018, 07:56:50 »
Is it just me or the top plate doesn't seem to be flush with the bottom plate? Or is this a known problem that is only in the prototype?
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline Vulcan
« Reply #154 on: Tue, 29 May 2018, 08:23:00 »
It's not screwed in properly yet.. we haven't receive the screws yet
Offline fine_italian_leather
« Reply #155 on: Tue, 29 May 2018, 08:51:51 »
Any chance we could see a silver (anodized) or maybe even a white (powder coat/cerakote) version?
Offline cldskt
« Reply #156 on: Tue, 29 May 2018, 10:40:29 »
Ah cool. That is totally fine then.
Additionally, maybe for the side design, the top-part of the case can have a curve above the side design part, so that it looks seamless and not like a ‘roof’. I’m not sure if I’m describing this clearly.
Offline bball2
« Reply #157 on: Tue, 29 May 2018, 14:29:57 »
I think it looks really slick! I like the side design; makes it a bit more unique.
Offline Archedemus
« Reply #158 on: Wed, 30 May 2018, 16:51:54 »
This case is ABSOLUTELY AMAZING: DZ60 support, looks, anodizing( I hope), true hhkb, integrated plate ... everything is so good, and it will be about 200$  for the kit!
I would like to see purple ( Tokyo cyberpunk pink*)coating too, but if it won’t happen I will go with the purple color.
I regard this case as an ultimate competitor to Tina. The latter, I suppose is so overpriced. Basically they are sold for 110$ on mechmarket. Damn it. KBDFans have some serious issues with anodizing. I hope your GB will get a perfect finish, don’t save any money on it, as anodizing is what makes ANY case unique.
Offline gr4v3m4n
    • my store
« Reply #159 on: Wed, 30 May 2018, 18:58:55 »
couldn’t agree more, just a little curve on the bottom of the top case would make a perfect look...
ohhh...and two tone would look sooo cool.
« Last Edit: Wed, 30 May 2018, 19:01:13 by gr4v3m4n »
Offline Unforgivable
« Reply #160 on: Wed, 30 May 2018, 19:11:11 »
Is it possible to continue the design to affect the top?
The way it looks now kind of kills the look, IMO.
Offline nickaster1
« Reply #161 on: Wed, 30 May 2018, 21:53:02 »
Would like to see the plate sold separately
Offline Archedemus
« Reply #162 on: Thu, 31 May 2018, 01:30:38 »
I don’t see anything bad in the design. I have to admit it looks “simple”, not “aggressive” as it was supposed to be.
Offline Puss
  • Formerly 0GBobbyJohnson
« Reply #163 on: Thu, 31 May 2018, 02:04:19 »
Been looking around for a nice 60% case lately. This might just be the one!
Offline Archedemus
« Reply #164 on: Thu, 31 May 2018, 02:06:05 »
This is it. There is no other choice.
Offline Puss
« Reply #165 on: Thu, 31 May 2018, 02:08:18 »
Haha it’ll definitely depend. Getting a new board means no artisans for a while :(. And getting switches + keycaps makes it pretty pricey.
Offline Archedemus
« Reply #166 on: Thu, 31 May 2018, 02:09:36 »
Tina (the same kit) costs 160$ but shipped, and this is a unique.
« Last Edit: Thu, 31 May 2018, 13:17:25 by Archedemus »
Offline Vulcan
« Reply #167 on: Thu, 31 May 2018, 20:36:02 »
Tokyo cyber pink like GMK Laser pink? Yeaa.. I like that color too.. I'll se what i can do. But to make sure im pictureing the same color like you said.. can you give me picture of the color?
Btw. I heard KBDfans is partnering up with a new manufactureing company.. maybe now they have better results.
Two toone??? Hmmmm... i have tried it before with render.. it doesnt seams to work well..
Yep, i the top case also is bugging me.. I'll try me best to make this case look like one piece...
Why would you like to buy the plate seperately?
Offline Archedemus
« Reply #168 on: Sat, 02 June 2018, 15:27:48 »
So the color I suggest :
Hex: #cc3b7c
RGB: (204, 59, 124)
 OR
HEX: #a1355c
RGB: (161, 53, 92)
Offline Archedemus
« Reply #169 on: Sun, 03 June 2018, 06:43:17 »
What's the estimated GB timeline? Guess, I'll go for Tina-A.
Offline dantambok
« Reply #170 on: Sun, 03 June 2018, 08:35:01 »
Note that top mount and tray mount feel really different from one another. Tina is tray while the fusion is top mount
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline Archedemus
« Reply #171 on: Sun, 03 June 2018, 08:37:28 »
I know, still don’t want to wait for half a year
Offline elcubismo
    • Reddit page
« Reply #172 on: Sun, 03 June 2018, 21:02:25 »
Anyway you could describe the difference? I've only ever had tray mount and the fact that this is top mount was great to hear.
Leopold FC660C lubed, silenced with landing pads | Norbatouch lubed, silenced with hyperspheres | Poker II MX Blue with vortex aluminum case, vortex red/white doubeshot pbt caps and o-rings | CODE TKL MX Clear with Miami | Unicomp Buckling Spring | GMMK with rainbow vomit switches, mostly jailhouse blues and pandealios
Offline ideus
  • Björkö.
« Reply #173 on: Sun, 03 June 2018, 21:19:52 »
Nice pricing, but you should remove the renders of the true-happy layout that is not covered by the design.
If I just were not waiting for an upcoming sub-sixty model to try out...
Good job.
Offline Mekuno
« Reply #174 on: Mon, 04 June 2018, 10:22:25 »
I know I may be the minority, but would it be possible to add some form of RGB on this board?  :-[
Offline elcubismo
    • Reddit page
« Reply #175 on: Mon, 04 June 2018, 14:43:28 »
You can always use a different, rgb-compatible pcb
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #176 on: Mon, 04 June 2018, 18:44:31 »
I think the original design had acrylic sections for underglow like on Duck keyboards, but it was removed to keep cost down.
Offline duckboi
« Reply #177 on: Wed, 06 June 2018, 13:44:23 »
I just want to say that I found this pretty recently and am really looking forward to it!
Also, to clarify, is the prototype you showed in black or in gray?
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline zap2oz
« Reply #178 on: Wed, 06 June 2018, 22:27:53 »
Just wanted to say that I really dig the design of the prototype. Watching the thread now and can't wait for GB to open!
Offline feedbaack
« Reply #179 on: Thu, 07 June 2018, 10:22:42 »
Definitely interested too !   :thumb:
Offline Yeoh
« Reply #180 on: Thu, 07 June 2018, 12:37:17 »
Not sure if this has been brought up yet, but is there any chance for a fixed ANSI plate?
« Last Edit: Thu, 07 June 2018, 12:50:03 by Yeoh »
Offline cldskt
« Reply #181 on: Mon, 11 June 2018, 04:12:19 »
Yo Vulcan,
You might wanna post the video of the prototype you posted on Indonesian MK FB Group here as well. I’m sure all of us would appreciate it :)
« Reply #182 on: Mon, 11 June 2018, 06:43:06 »
This looks great to me. Maybe you should add it to the OP?
Offline cldskt
« Reply #183 on: Wed, 13 June 2018, 04:18:05 »
Some more teaser photos from OP:
[Deleted as per request by the OP]
My bad!
« Last Edit: Wed, 13 June 2018, 04:26:37 by cldskt »
Offline Yeoh
« Reply #184 on: Wed, 13 June 2018, 10:56:47 »
My bad!
Hmm, guess im too late, would have liked to have seen them.
Offline SteffeMK
« Reply #185 on: Wed, 13 June 2018, 11:39:01 »
Any updates when the gb will start?
Skickat från min SM-N950F via Tapatalk
Offline Vulcan
« Reply #186 on: Wed, 13 June 2018, 15:26:06 »
Hai all!, sorry for he late updates.. I've boon out of town for the past week, here is some more photo of the first prototype, still need to fix a couple things.
Offline crusader_alex
« Reply #187 on: Wed, 13 June 2018, 16:41:17 »
Oh wow this looks absolutely phenomenal,im definitely in for the gb!!!
Offline Fatboychard
« Reply #188 on: Wed, 13 June 2018, 19:12:03 »
The prototype looks great!
Offline gr4v3m4n
    • my store
« Reply #189 on: Wed, 13 June 2018, 19:34:54 »
damnn...i still dig that two tone look eventhough its just the light efect...:D
Offline Vulcan
« Reply #190 on: Thu, 14 June 2018, 06:34:46 »
Since there is alot of request on changing the shape of the top case to match the side of the bottom case.. I think the GB will start on late august..
Offline elcubismo
    • Reddit page
« Reply #191 on: Thu, 14 June 2018, 10:23:52 »
aw that's so far away :(
still, this looks amazing and will be worth it!
Offline Vulcan
« Reply #192 on: Thu, 14 June 2018, 10:29:22 »
Do you think i should run round 1 with this current design? :D
Offline SteffeMK
« Reply #193 on: Thu, 14 June 2018, 10:32:43 »
I like it, so I think you should!
Offline Mekuno
« Reply #194 on: Thu, 14 June 2018, 12:13:48 »
No, take your time, time gives you chance to perfect the shape and quality.
Additionally, it gives us to save some money for it as well. There are gonna be few big drops coming in next few weeks.
Offline Yeoh
« Reply #195 on: Thu, 14 June 2018, 12:14:17 »
I have no problem waiting until you reach a design you are fully confident in.
Would also appreciate time to save up, as there have been alot of amazing gb's already this year.
Good things are worth the wait.
« Last Edit: Thu, 14 June 2018, 12:16:00 by Yeoh »
Offline cldskt
« Reply #196 on: Thu, 14 June 2018, 12:34:10 »
As the others have said, I would say no to running the GB now. Perfect your case to what you envisioned it to be, as "R2" is only plausible when you have a successful "R1".
Delay is never good, but delays are easily forgotten with a good product.
Offline mr scooty
« Reply #197 on: Thu, 14 June 2018, 12:54:35 »
+1 for taking the time to perfect the case  :thumb:
Offline elcubismo
    • Reddit page
« Reply #198 on: Thu, 14 June 2018, 13:39:52 »
Honestly it's probably worth the wait to get things right, though I'm pretty sure I'd join in on R1 if you did it at the current price.
Offline Vulcan
« Reply #199 on: Thu, 14 June 2018, 22:38:17 »
Ok, I will post some alternative design to match the bottom case and make polls.. I will need you guys to choose which is the best :)
