Author Topic: QFR switch orientation  (Read 1519 times)
Offline clasicks
  • Formerly KeyboardUser4
« on: Fri, 23 February 2018, 13:53:45 »
I forgot which way they face, and board is not in front of me, are they all north or south, or mixed?
(deciding if i want to try them silencing clips, but cant remember)
Offline TalkingTree
    • My projects
Re: QFR switch orientation
« Reply #1 on: Fri, 23 February 2018, 14:16:34 »
I own a ISO model and the switches face LED down aside for ISO key, Left Gui and Left Alt which face up.
Offline clasicks
« Reply #2 on: Fri, 23 February 2018, 14:39:53 »
Thanks, that is what I was thinking it had, looks like it will be a safe bet for QMX/Zealencios.
Hope ANSI enter isnt north facing tho....
