Author Topic: 60% split KB  (Read 2421 times)
Offline DonnyD
60% split KB
« on: Fri, 23 February 2018, 14:41:04 »
Doing split 60% KB, whats safest layout for split space bars compatibility ? Should I split it into 1.75 + 1.75 + 2.75 ; or somethin differently ? I know split spacebars are not very common in itself, but whats most common ?
Re: 60% split KB
« Reply #1 on: Fri, 23 February 2018, 14:45:46 »
Safest layout would have something like 2.25 +2.75 in the center. That way you can use spare shift keycaps. I like 1.75 myself, but they are honestly harder to source, unless you buy 40% compatibility kits every time.
Offline DonnyD
Re: 60% split KB
« Reply #2 on: Fri, 23 February 2018, 14:57:52 »
So You saying to go with 2.25 + 2.75 + 1.25 and just change positions as I like ? If keycaps profile is XDA, DSA or G20, what would work really well !! Thanks for advice !!!
Re: 60% split KB
« Reply #3 on: Fri, 23 February 2018, 15:02:19 »
Yes, that's what I would do. :)
