Author Topic: E6-V2 Round 2 - 60% custom keyboard - (GB End)  (Read 273926 times)
Offline midnight2903
Re: E6-V2 Round 2 - 60% custom keyboard - (in production)
« Reply #550 on: Fri, 04 May 2018, 12:49:06 »
Shud have bought another e6 D:
Offline Tally810
« Reply #551 on: Fri, 04 May 2018, 12:52:18 »
Hi guys
here was some pictures i take from factory
plate was done ,bottom and middle is manufacturing
if all things go well it will be done almost on 15th May.  :thumb:
Very nice bud.  Still regretting not getting founders
Offline johuu
« Reply #552 on: Fri, 04 May 2018, 13:29:18 »
Hi guys
Thank you for the update.  :thumb:
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #553 on: Sat, 05 May 2018, 06:06:28 »
Hype, hype, hype!  :D
Offline mago
« Reply #554 on: Sat, 05 May 2018, 07:57:01 »
Group Buy going so quick, thanks for the update Exclusive!
Offline excluisve
  • Making & Thinking.
« Reply #555 on: Sat, 05 May 2018, 22:42:58 »
 :thumb:
Offline mmontess
« Reply #556 on: Wed, 09 May 2018, 14:14:07 »
I'm not sure if this has been asked before, but I see the port for this is centered and the OP says RGB bottom. Would that make this PCB compatible with a Viper case? Or am I overlooking something
Offline merlin64
    • MechMerlin
« Reply #557 on: Wed, 09 May 2018, 14:49:49 »
No it is not compatible. It's close though but you'd have to do some cutting, which I do not recommend.
Offline mmontess
« Reply #558 on: Wed, 09 May 2018, 15:21:59 »
ah, ty!
« Reply #559 on: Thu, 10 May 2018, 20:55:01 »
the pcb will fit in a viper case, but you need to get a new plate cut, and the USB port needs to be, ahem, adjusted to fit, but not any dangerous cutting
but it's not at all worth the effort
Offline lanyusea
« Reply #560 on: Thu, 10 May 2018, 22:05:47 »
I did a comparison between E6 and Viper,
There are two points after the PCB comparison
1. The distance between switches in e6 pcb is less than the one in viper --> means the e6 pcb is not compatible with viper plate
2. The width of e6 pcb is larger than viper --> means you need to cut it narrower first if you insist to use one with your own plate
3. the USB port position is exactly same, also the MCU position --> means no change need to be made about the case
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
Offline merlin64
    • MechMerlin
« Reply #561 on: Fri, 11 May 2018, 13:28:46 »
How are the switch distances different? Doesn't that mean the keycaps won't work as well? I thought that stuff was all standard.
Offline xondat
  • i'm not a star
« Reply #562 on: Fri, 11 May 2018, 13:29:30 »
Key units are 19.05mm as standard, E6 is 19.00mm. Keycaps are 18.1mm wide (1u).
« Reply #563 on: Fri, 11 May 2018, 13:52:58 »
yeah
****'s ****ed
Offline xondat
  • i'm not a star
« Reply #564 on: Fri, 11 May 2018, 20:14:27 »
Makes me wonder if the PCB would fit the 356mini? They seem very similar now I'm thinking about it.
« Reply #565 on: Sat, 12 May 2018, 01:27:03 »
i don't believe it will, i think it needs to be ground down too much since the mini has super tight tolerances
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #566 on: Sat, 12 May 2018, 22:45:50 »
V1 and V2 have different tolerances as well iirc
Offline nzhoward
« Reply #567 on: Mon, 14 May 2018, 11:41:15 »
Any update on the anodizing? Can't wait for these to ship!  :thumb: :thumb:
Offline excluisve
« Reply #568 on: Tue, 15 May 2018, 05:27:42 »
not yet
Still manufacturing
Offline excluisve
« Reply #569 on: Wed, 16 May 2018, 05:09:15 »
PCb was finish
Bootmapper:
Offline Atredl
« Reply #570 on: Wed, 16 May 2018, 05:11:30 »
Oof! That’s a slick pcb!
Offline lanyusea
« Reply #571 on: Wed, 16 May 2018, 05:28:57 »
PCb was finish
Bootmapper:
the hole for stabilizer seems as large as the one for switch..
Offline Tally810
« Reply #572 on: Wed, 16 May 2018, 08:40:09 »
PCb was finish
Bootmapper:
Very nice exclusive
Offline s3vv4
« Reply #573 on: Wed, 16 May 2018, 12:34:15 »
That's a pretty PCB  :thumb:
Offline Atredl
« Reply #574 on: Mon, 21 May 2018, 04:25:39 »
Since we’ve got time while we wait, how are the different switch plates cut? Laser, water jet, CNC?
Offline excluisve
« Reply #575 on: Mon, 21 May 2018, 04:27:33 »
We are CNC the plate .
Offline Atredl
« Reply #576 on: Mon, 21 May 2018, 04:29:28 »
Even the brass plate?
Offline excluisve
« Reply #577 on: Mon, 21 May 2018, 04:30:25 »
All plate was cnc .pc -alu-brass
Offline Atredl
« Reply #578 on: Mon, 21 May 2018, 04:45:55 »
Good to know! :thumb:
Offline excluisve
« Reply #579 on: Mon, 21 May 2018, 23:37:44 »
CNC is ready done still need wait 2 days or more to check
Offline Tally810
« Reply #580 on: Mon, 21 May 2018, 23:39:50 »
Tfw I should grabbed a founders.  Excited to see everything dude
Offline InvidiousIgnoramus
« Reply #581 on: Tue, 22 May 2018, 00:15:59 »
Getting excited
I long for the day when I find a beamspring. (At a not insane price)
Offline japanitrat
« Reply #582 on: Tue, 22 May 2018, 03:52:57 »
*drool* all of these do look amazing!
Offline mmontess
« Reply #583 on: Tue, 22 May 2018, 17:25:46 »
Legit drooling. These look amazing!
Offline Peiweisgreat
« Reply #584 on: Sun, 27 May 2018, 05:18:31 »
Exclusive you never fail to impress me. The pcb looks amazing. Can't wait to get my hands on my E6.
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #585 on: Sun, 27 May 2018, 07:07:35 »
Are these still shipping out at the end of May? That's fast approaching.
Offline HardcoreDesk
« Reply #586 on: Wed, 30 May 2018, 14:24:14 »
Tomorrow is the last day of May; any updates?
Offline jamoz330
  • Yup
« Reply #587 on: Wed, 30 May 2018, 15:16:12 »
+1 also curious as to the progress
Offline excluisve
« Reply #588 on: Wed, 30 May 2018, 21:02:17 »
Yea
CNC will all  done tomorrow , shipping day delay some days
« Reply #589 on: Wed, 30 May 2018, 21:32:08 »
Thanks for the update!
Offline OnceSavedGaming
« Reply #590 on: Wed, 30 May 2018, 21:35:09 »
Yea
So after cnc they go to anodizing or is it good to go after that?
Sent from my VS996 using Tapatalk
Offline excluisve
« Reply #591 on: Wed, 30 May 2018, 21:41:03 »
Yea
After done I will check each part then go to anodized
« Reply #592 on: Wed, 30 May 2018, 21:46:02 »
Yea
Do you think we will have them before the end of June or later?
Offline excluisve
« Reply #593 on: Wed, 30 May 2018, 21:51:38 »
Yea
Yep June.
Offline gridds
« Reply #594 on: Wed, 30 May 2018, 22:04:46 »
 :thumb:
Offline __foo_
« Reply #595 on: Wed, 30 May 2018, 23:05:28 »
Hyped!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #596 on: Thu, 31 May 2018, 03:25:10 »
Yea
Given the delays I may have to switch shipping address. Could you please confirm with me before sending?
Sent from my mobile using Tapatalk
Offline jamoz330
  • Yup
« Reply #597 on: Sun, 03 June 2018, 12:24:23 »
Might have to switch shipping address too unless it ships within the next two weeks or so.
Could you also please confirm with me before sending?
Offline excluisve
« Reply #598 on: Sun, 03 June 2018, 21:24:27 »
plz check you orders again
if anything was wrong plz let me know
like this : #23  - PC plate change to brass plate  ,make it clear
thanks !
before ship  i will let you guys check the shipping information ,btw those information was Privacy how to show you guys to check it ? one by one ??
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #599 on: Sun, 03 June 2018, 21:26:08 »
thanks !
I'd advise only checking in with the people who requested it. With others, assume that it is still the same address.
