Author Topic: E6-V2 Round 2 - 60% custom keyboard - (GB End)  (Read 273895 times)
Offline excluisve
  • Making & Thinking.
Re: E6-V2 Round 2 - 60% custom keyboard - (ship group 2)
« Reply #800 on: Wed, 11 July 2018, 10:38:02 »
Tracking received!
Where did you receive the tracking? Did you just check the invoice and see it there, or did PayPal notify you that tracking had been added? I'm in group 2 and don't see mine yet (Exclusive may not be done adding all the tracking for our round though)!
Hello I have check the mailbox there was no message  from you
That why I am ask ppl add my discord as friends list
Geek hack messager sometimes broke down
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #801 on: Wed, 11 July 2018, 12:08:54 »
Tracking received!
As long as you provided a valid phone number to Exclusive you should get a text from DHL once it has been picked up and scanned into their system. I'm still waiting for mine too  :p
Offline eyedrop
« Reply #802 on: Wed, 11 July 2018, 12:38:08 »
Thanks for this info.  Good to know!
Offline AgonizedFish
« Reply #803 on: Wed, 11 July 2018, 14:33:47 »
Tracking received!
I emailed you with the email you provided and didn't see my name listed as one of the people you didn't get a response from! My phone number and  my geekhack id was included! I don't have discord so I went with the email option! Do I need to send you a message here too?
« Reply #804 on: Thu, 12 July 2018, 08:42:56 »
Tracking received!
Got everything straightened out, and received my tracking! Thanks again exclusive!
Offline zekkin
« Reply #805 on: Thu, 12 July 2018, 09:59:07 »
Got my tracking, should have the board in-hand tomorrow!
Offline SevenU
  • Grimace is Black
« Reply #806 on: Thu, 12 July 2018, 10:10:58 »
Apparently my boards will be here tomorrow too
Sent from my ONEPLUS A5010 using Tapatalk
Something, Something, blah, blah, blahbitty, blah
Offline ullr
« Reply #807 on: Thu, 12 July 2018, 12:00:12 »
Well, I got mine today. Looks great. What size allen wrench do the screws take though? I got two and both are too small to turn the ones in the bottom.
EDIT: evidently I got two for fixing the name plate with the little fasteners instead of one each?
« Last Edit: Thu, 12 July 2018, 12:03:56 by ullr »
Offline excluisve
« Reply #808 on: Thu, 12 July 2018, 12:03:22 »
Ah the small wrench is for nameplate
case screws i s m2.5 i think is common screws also easy to buy a wrench .
Offline ullr
« Reply #809 on: Thu, 12 July 2018, 12:04:55 »
case screws i s m2.5 i think is common screws is easy to buy a wrench .
Okay, thanks. Finish is impeccable, very pleased with the board.
Offline johuu
« Reply #810 on: Thu, 12 July 2018, 14:41:40 »
I got my tracking infos as well, will get the board hopefully on monday  ;D
Offline radio_killah
  • Chinchillin'
« Reply #811 on: Fri, 13 July 2018, 00:43:24 »
Just got my set. Packaging was great. It is a shame though that you can still see marks from where the components were held during anodization. Maybe that is just my set of components but its pretty obvious. The matte black PCB is a really lovely touch. Polycarb plate is also really well done.
My only issue with the kit is that the anodization between my top and bottom housings is really off. It is hard to capture in a photo but my bottom is almost a matte green where the top is a shiny green. It isn't the biggest issue since I will pretty much just see the top of the keyboard but it is still a bit disappointing.
I look forward to putting this keyboard together.
Offline eyedrop
« Reply #812 on: Fri, 13 July 2018, 00:46:02 »
Any pics?
Offline midnight2903
« Reply #813 on: Fri, 13 July 2018, 04:35:42 »
Kinda sad that my ALT key and spacebar collide sometimes if I dont press the Alt key on center. The PCB holes are just SLIGHTLY off. The tolerences are too tight :-X
Offline yonghf
« Reply #814 on: Fri, 13 July 2018, 04:45:05 »
The left ALT key? I had the exact same issue. Had to desolder that switch 3x to get it fixed. Initially I thought it was my GMK spacebar being iffy.
« Reply #815 on: Fri, 13 July 2018, 04:46:33 »
Yea i tried desoldering but it ended up the same. I will probably file the pcb hole sometime, giving up now.
« Last Edit: Fri, 13 July 2018, 04:52:37 by midnight2903 »
Offline excluisve
« Reply #816 on: Fri, 13 July 2018, 04:55:39 »
The anod hooking all parts is like that on the inside .i have try myself to make it hard to find.
the color top shiny and bottom matter i thinks is a little ,coz when anod the top and bottom on the same hooking however the top is thinner than bottom ,it will transformation earlier than bottom .
Offline excluisve
« Reply #817 on: Fri, 13 July 2018, 05:08:41 »
You can find that e6 keycaps gap was less-than other board .
coz standard keycpas gap was 19.08 i have decrease to 18.88 it make looks gorgeous
about hhkb layout you need push  1.5 alt switch and 1 u win (or something ) to left ,move the switch then solder
i have try it many times it work well,you can try.
Offline excluisve
« Reply #818 on: Fri, 13 July 2018, 05:16:40 »
HHKB
Offline excluisve
« Reply #819 on: Fri, 13 July 2018, 05:21:02 »
WKL.
Offline excluisve
« Reply #820 on: Fri, 13 July 2018, 05:24:52 »
WK with block
Offline nzhoward
« Reply #821 on: Fri, 13 July 2018, 08:13:09 »
Just got my board yesterday. I found that I don't like the polycarb plate as much as I thought I would. If anyone is interested I am looking to trade for any metal plate. Pm me on reddit, I'm /u/nzhoward  :thumb: Otherwise this board is great! Love it already!
« Reply #822 on: Fri, 13 July 2018, 09:02:57 »
oh **** mine comes today
Offline eyedrop
« Reply #823 on: Fri, 13 July 2018, 09:04:15 »
If someone has a bootloader PCB and would like to trade for a QMK one, let me know.  Thanks!
Offline Dead Encryption
  • Dead...
    • Twitch Channel
« Reply #824 on: Fri, 13 July 2018, 09:05:51 »
Mine too! I'm hyped!!!! If it gets here this morning, planning on doing a build stream for sure.
Offline merlin64
    • MechMerlin
« Reply #825 on: Fri, 13 July 2018, 09:22:09 »
If you can send me the matrix for that board, I could probably get QMK on it too.
Offline ptiede
« Reply #826 on: Fri, 13 July 2018, 09:26:46 »
Ooof regret not getting a round 2 e6, now my. Great work exclusive once again.
« Reply #827 on: Fri, 13 July 2018, 09:56:10 »
I think I got it to work somehow. No collisions so far. Thanks for the headsup excluisve.
Offline Atredl
« Reply #828 on: Fri, 13 July 2018, 12:38:46 »
Absolutely incredible quality on this case and I can’t wait for the switches to get in so I can build it.
On another note, did everyone who got a bootmapper pcb get the matte black one?
I got the QMK pcb and it’s a yellow/orange color that IMO doesn’t look that nice. I’m not super bothered by it but if I had known they were going to be different colors, I would’ve chosen the bootmapper pcb. Especially since it’ll also most likely be ported into QMK.
Offline tomu
  • hi
« Reply #829 on: Fri, 13 July 2018, 16:26:10 »
199981-0199983-1199985-2
Finished building my E6 last night, really surprised with the quality of this board.
Typing test is with filmed 68g Vintage Blacks lubed with 205g0 on a 1.5mm poly plate.
https://clyp.it/kfq30w1y
« Last Edit: Fri, 13 July 2018, 16:30:35 by tomusan »
G80-3700 | HHKB Pro 2
Offline oldcat
  • 65% is Life
« Reply #830 on: Fri, 13 July 2018, 16:31:11 »
Tracking received!
Let's do another round of E6-V2. Please.
« Reply #831 on: Fri, 13 July 2018, 18:18:51 »
gonna be a while before i get to building it, but it's absolutely gorgeous.
Offline Photoelectric
« Reply #832 on: Fri, 13 July 2018, 18:57:31 »
Swoon.  Beautiful combo.
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #833 on: Fri, 13 July 2018, 19:16:49 »
Thoroughly impressed with the green anno exclusive.
It's actually beautiful.
Out did yourself
Offline ryan60197
« Reply #834 on: Fri, 13 July 2018, 19:49:23 »
Just built my E6. My only problem with it is that since I chose the MAO option for all my nameplates, the letters are almost impossible to see even from just sitting at my desk. White was used to fill in the engraved parts for two of them and for the plate that says e6-v2 there is no filling at all so that one is basically invisible even up close. Other than that everything is perfect and I'm glad I joined this group buy  :thumb:
Don't know how to use GH so here's the imgur album https://imgur.com/a/UsgynBE
Offline Atredl
« Reply #835 on: Fri, 13 July 2018, 21:52:09 »
I have the same thing with my MAO nameplate and it makes me super happy I decided to get a second in a different color. Though the MAO was my first choice before I realized it was “blank”.
Offline johuu
« Reply #836 on: Sat, 14 July 2018, 05:47:30 »
Keyboard arrived today :eek:
Quality is awesome. Looks like the brass plate doesn't support switch opening, so I will need to wait for Halo switches from MD (-> Holy Pandas) to build the board.
Offline jacky
« Reply #837 on: Sat, 14 July 2018, 10:08:44 »
 i also get mine from china  :thumb:
Offline excluisve
« Reply #838 on: Sat, 14 July 2018, 10:18:23 »
Thanks Dead sharing his video and beautiful wrist ~
PS: FE  will start ship Monday ,weekend express not work
Offline ullr
« Reply #839 on: Sat, 14 July 2018, 10:41:08 »
A photo of mine. Not perfect, but very nice. Love the small blockers. I'll have Troubled Minds on it early next year ;)
Offline lanyusea
« Reply #840 on: Sun, 15 July 2018, 01:08:49 »
SF will work. ship mine thanks
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
Offline zekkin
« Reply #841 on: Sun, 15 July 2018, 09:02:03 »
All built up!
And a typing test for those who like that kind of thing:
This board is definitely something special, thanks for the smooth and pretty fast group buy, Exclusive!
Offline tomu
  • hi
« Reply #842 on: Sun, 15 July 2018, 16:16:12 »
You could just build with pandas and pull them out for modding since they have those sockets
Sent from my LG-H871 using Tapatalk
Offline fatpolomanjr
« Reply #843 on: Sun, 15 July 2018, 18:34:14 »
Typing test videos make me want to cut off my ears. I'm not sure why I click on such videos, but your work is certainly appreciated. Your build is fantastic.
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline InvidiousIgnoramus
« Reply #844 on: Sun, 15 July 2018, 18:44:47 »
Why? Makes your boards sound bad?
I long for the day when I find a beamspring. (At a not insane price)
« Reply #845 on: Sun, 15 July 2018, 20:08:03 »
This may come as a shock to you, but I believe some refer to this unusual phenomenon as a "pet peeve".
It's not like my keyboard noise is any less quiet or annoying to others, I think it just has something to do with the noise being transmitted through a video. If it were real life my blood wouldn't curdle like it does with a video; there's something about it I just can't put my finger on. Like an uncanny valley but for sound instead of 3d animations.
e: I think it might have something to do with the actual video being of someone's hands typing. If the video was of text being typed into an editor then I could probably focus on the sound more, and not cringe internally so much.
« Last Edit: Sun, 15 July 2018, 20:12:30 by fatpolomanjr »
« Reply #846 on: Sun, 15 July 2018, 20:17:53 »
close ur eyes famalam
« Reply #847 on: Sun, 15 July 2018, 20:23:38 »
Yeah I thought about that, then tried it just now. Still feel the cringe. I have no idea what it is. Sound fidelity / not in person? Unnatural typing speed; as in, you normally would type with pauses and gaps? Can't see the text being typed? I need help either overcoming my typing test video watching issues or my typing test video impulse to watch knowing what'll happen issues. Or my *****ing about it on gh gb thread issues.
e: Just to reiterate, I really do appreciate anyone who loves the board so much as to take the time to record themselves typing on it, as a means of showing off its awesomeness. Kind of hard, even for me, to **** on something like that and not give credit where credit is obviously due.
« Last Edit: Sun, 15 July 2018, 20:37:06 by fatpolomanjr »
Offline Will_26
« Reply #848 on: Mon, 16 July 2018, 07:50:30 »
Well it arrived today and it's beautiful. You've outdone yourself Exclusive, I can't wait to build and use this.  :D
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #849 on: Mon, 16 July 2018, 09:55:34 »
No u -
but that's beautiful, yes.
