Author Topic: [GB] GRAY COD67 60%Custom Keyboard【GB sold out】  (Read 84805 times)
Offline AIRPOTTER
  • Owner of Gray Studio
« on: Sun, 25 February 2018, 21:32:10 »
GB forGray COD67  will start on Feb. 26th 12:00 a.m. PST  ;D and will last til March 19th.
189701-0
Join here: https://en.zfrontier.com/products/cod67    (Officially launched after 12 a.m. on Feb 26th)
IC: https://geekhack.org/index.php?topic=92191.0
More pictures:https://imgur.com/a/6TE9Y
                        https://imgur.com/a/gPTD0
Gray COD67 is a 60% keyboard with a modern and bold design. Featuring 20 RGB Underglow LED lights and an unique diffuse placement, the COD67 has the most stunning RGB light strip for a custom mechanical keyboard.
COD67 will be limited to 75 units worldwide in order to guarantee better quality control and faster production.
189703-1
- Top case (10 anodization color options or Micro-Arc Oxidation White*)
- Bottom case (10 anodization color options or Micro-Arc Oxidation White*)
- Aluminum plate (10 anodization color options, can upgrade to Electroplated Brass or Titanium plate)
- PCB (2u left Shift layout or 2.25u left Shift layout)
- Front nameplate (10 anodization color options or Micro-Arc Oxidation White*, customizable**)
- Aluminum weight (customizable**)
- Diffuser
- Screws, rubber feet, etc.
- Wooden box
* Micro-Arc Oxidation will charge extra $7 per piece.
189705-2
** Customization will cost extra. You will need to prepare or provide us .cdr, .ai, .dxf, .dwg or other vector files. If you are not able to create vector drawings, please prepare a high resolution image and Gray Studio will convert it for you.
 189707-3
PCB FEATURES
- Programmable with ydkb.io
- 2u left Shift or 2.25u left Shift support
- 20 RGB Underglow LEDs
- USB-C connection
COLOR OPTIONS
10 different anodization colors (Silver, Black, Titanium, Red, Gold, Rose Gold, Purple, Ocean Blue, Sky Blue, Light Green) are available and you could choose the colors separately for the top, bottom case, aluminum plate and aluminum weight. Micro-Arc Oxidation White is available for the top, bottom case and aluminum weight.
« Last Edit: Tue, 20 March 2018, 01:53:01 by AIRPOTTER »
Offline Visionaire
Re: [GB] GRAY COD67 60%Custom Keyboard
« Reply #1 on: Mon, 26 February 2018, 21:39:54 »
Bought one this morning! Excited for this GB!
« Reply #2 on: Mon, 26 February 2018, 22:01:58 »
Looks great! GLWGB
Offline mudcakehoney
« Reply #3 on: Mon, 26 February 2018, 22:14:44 »
I’m all in for this with customised plates. So happy this is happening!
Offline vtachkov
« Reply #4 on: Mon, 26 February 2018, 22:39:56 »
I've been waiting for this. What's the best way to provide you with the customization vectors?
Offline ayamterbang
« Reply #5 on: Mon, 26 February 2018, 22:41:44 »
I'm interested, but it's too hard for me to decide which color...
shoot an email to OP, hopefully you can help me.
cheers!
Offline AIRPOTTER
« Reply #6 on: Mon, 26 February 2018, 23:06:57 »
Thank you very much. I guarantee that this is absolutely a perfect GB experience :)
Offline AIRPOTTER
« Reply #7 on: Mon, 26 February 2018, 23:07:36 »
Offline AIRPOTTER
« Reply #8 on: Mon, 26 February 2018, 23:23:36 »
Ah, this way. You can send the document(Custom file) and order number to my mailbox(871138172@qq.com)and zf mailbox( alex.lin@zfrontier.com), and we will backup it.
Offline AIRPOTTER
« Reply #9 on: Mon, 26 February 2018, 23:41:56 »
cheers!
Ah, I have the same choice difficulty... :eek:
But in my opinion, the grey system can be referred to as the all-match (with most keycap look good).
So,I recommend : gray top / MAO cover / black weight.
PS:I dont know what OP means... :(
Offline AIRPOTTER
« Reply #10 on: Mon, 26 February 2018, 23:43:50 »
Aye...the process is really hard to me...
And thank you for your attention. :))
Offline ayamterbang
« Reply #11 on: Mon, 26 February 2018, 23:59:36 »
cheers!
OP = Original Poster - Thus, yourself.
Check your email btw.
Furthermore, I don't see any Grey color options in zF site?
The one in your example looks more light green-ish or faded teal rather than grey.
Sent from my SM-G930F using Tapatalk
Offline AIRPOTTER
« Reply #12 on: Tue, 27 February 2018, 00:20:02 »
cheers!
ok,take those pictures
Offline ayamterbang
« Reply #13 on: Tue, 27 February 2018, 00:27:58 »
cheers!
Thanks :thumb:
so that's a Titanium Grey I suppose?
Offline AIRPOTTER
« Reply #14 on: Tue, 27 February 2018, 00:41:01 »
cheers!
Thanks :thumb:
Aye,Titanium Grey ;D
Offline Kalopsia
« Reply #15 on: Tue, 27 February 2018, 00:46:18 »
What would be the best color choices for a rose gold and gold combinations? Or something else that might match the rose gold color?
Offline AIRPOTTER
« Reply #16 on: Tue, 27 February 2018, 01:04:06 »
My opinion, Rose gold or Gold  is more hopping, so I will choose a few more calm to match(like titanium gray / Black / MAO white, these colors).
By the way, you can refer to these pictures
Offline yuppie
« Reply #17 on: Tue, 27 February 2018, 01:08:06 »
is it possible to NOT have the "GREY COD67" label on the top right of the top plate?
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline AIRPOTTER
« Reply #18 on: Tue, 27 February 2018, 01:32:47 »
Aye,youcan choose a Nameplate Customization alone,A piece of $7.
https://en.zfrontier.com/products/cod67csec?variant=4164470833163
The effect is like this.
PS;A little upgrades:The Nameplate Customization is  magnetic  connected to the top case.
« Last Edit: Tue, 27 February 2018, 01:41:00 by AIRPOTTER »
Offline AIRPOTTER
« Reply #19 on: Tue, 27 February 2018, 01:54:44 »
Edit,Titanium gray top/MAO white cover
More in:https://imgur.com/a/0gE9T#6Si0Hh1
Offline vtachkov
« Reply #20 on: Tue, 27 February 2018, 09:19:46 »
Looking over my order, I think I picked the wrong color. Is the blue-gray color supposed to be sky blue or light green? It might help to label the pictures with their colors.
Offline AIRPOTTER
« Reply #21 on: Tue, 27 February 2018, 20:12:50 »
Er...bule gray? Gray only a color of titanium gray...
Offline vtachkov
« Reply #22 on: Tue, 27 February 2018, 20:18:59 »
Sorry, maybe I worded that wrong. Which color would be the one for the top case in this picture?
Offline xoppel
« Reply #23 on: Tue, 27 February 2018, 20:27:09 »
Can anyone with eyes-on the titanium (?) green-grey color in the pictures speak to how well it would match EnjoyPBT Forgive's dye-sub color?
 (https://kbdfans.cn/collections/keycaps/products/gbenjoypbt-forgive-132key-keycaps)
Offline Velvet_Crowe
« Reply #24 on: Tue, 27 February 2018, 20:41:45 »
cheers!
Is this a titanium grey top and MAO white bottom?
Do you have a picture to show what a silver top looks like?
EDIT: Nvm, got my answer!
« Last Edit: Tue, 27 February 2018, 21:51:55 by Velvet_Crowe »
Current daily: OTD 356mini v1 (Red) | OTD 356CL (Gunmetal) | TGR Jane V2 CE (Black) | zekk.works Ogre (Dark Grey) | Noxary Vulcan Pro (Silver/Red) | 488 Pista Spider (Red)
Offline zF_ScrambledEggz
    • zFrontier
« Reply #25 on: Tue, 27 February 2018, 20:51:44 »
This color was actually a result of an accident, the anodize factory made a mistake when doing the titanium finish. Which I admit is a beautiful color and thats why i choose this as a sample. :( however this color is hard to duplicate.
the accurate titanium will be like this https://geekhack.org/index.php?topic=94251.msg2567628#msg2567628
and you can take this as an showcase (still the beautiful accident titanium tho) https://geekhack.org/index.php?topic=92191.msg2567178#msg2567178
Offline vtachkov
« Reply #26 on: Tue, 27 February 2018, 20:57:04 »
In that case can I just buy that sample :)
Offline AIRPOTTER
« Reply #27 on: Tue, 27 February 2018, 21:19:33 »
cheers!
aye~
Offline Peppermint216
« Reply #28 on: Wed, 28 February 2018, 11:50:20 »
Would it be possible to remove the nameplate and not have the cut out from the case?
« Reply #29 on: Wed, 28 February 2018, 12:36:56 »
no
people asked about it in the IC
Offline AIRPOTTER
« Reply #30 on: Thu, 01 March 2018, 20:56:45 »
Er,I'm sorry to be late.And you mean like this?
« Reply #31 on: Thu, 01 March 2018, 23:52:19 »
Exactly
Offline AIRPOTTER
« Reply #32 on: Fri, 02 March 2018, 02:42:54 »
Exactly
Ok,we can customize the non - nameplate version for you :)
Just make a note in the order :)
« Reply #33 on: Fri, 02 March 2018, 03:11:37 »
That's great! thanks for accommodating.
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #34 on: Fri, 02 March 2018, 03:30:21 »
Pardon my noob question but what exactly is Micro-Arc Options? Is it a way that the material is wielded? Do you have a pictorial example of it?
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline JMD
  • All we want is happiness.
    • Mech Keys
« Reply #35 on: Fri, 02 March 2018, 04:08:36 »
Wow. This is the first time that I have been really impressed by somebody elses keyboard. This looks great guys. I really want to get one now :)
- mechkeys - ca -
Offline p_blaze
« Reply #36 on: Fri, 02 March 2018, 09:24:48 »
If its for hhkb style boards what about the arrow icons like we see on Rama's Keyset??
pls no
i like the current legends a LOT
been looking for a set like this for a long time
It's the only way to get the white color, but it feels a bit different from anodization and gets dirty easier. It also costs a few dollars more
Offline bball2
« Reply #37 on: Fri, 02 March 2018, 12:20:47 »
How is the customization on the front name plate / back weight done? The current pics look like "GRAY COD 67" is hollowed out while this customization:
https://cdn.shopify.com/s/files/1/1674/0405/products/Untitled-3452345_1024x1024.png?v=1519620171
Looks like white lettering on top of a blue weight; is the white lettering metal inserts? Or some kind of paint on top? Are you limited to what kind of design you can put on the weight plate (ie. simple letters only, or are complex shapes possible?)
I kind of wanted to get something like this done:
https://i.imgur.com/6lUIt7l.jpg
https://i.imgur.com/Hl1k9bP.jpg
And was wondering if it would be possible (the Lakers logo looks fairly complex).
« Reply #38 on: Fri, 02 March 2018, 12:27:50 »
i know how much kobe paid extra for that lakers weight, and let me tell you it might not be worth it
and the customization isn't engraved on this board, there was some more info higher up
Offline p_blaze
« Reply #39 on: Fri, 02 March 2018, 12:54:32 »
I see the customized weight isn't engraved... are the differing colors made by anodized aluminum inserts? Also, how complex can the customization be?
EDIT: also, I remember brass weights in the IC, is that not an option anymore?
« Last Edit: Fri, 02 March 2018, 13:03:36 by p_blaze »
Offline bball2
« Reply #40 on: Fri, 02 March 2018, 12:58:45 »
Here's a mockup (quick 5 mins in ms paint, would do a nicer mockup with a single color down the line) of what I was thinking of doing:
https://i.imgur.com/jEhKNgO.png
If the warriors logo / nba logo are too complex I could just take them out and stretch out the team name wider.
Planning on gold top, blue bottom, gold weight, and blue plate.  :thumb:
« Reply #41 on: Fri, 02 March 2018, 13:09:59 »
looks like it's just laser printed on there, not an anodized insert
Offline p_blaze
« Reply #42 on: Fri, 02 March 2018, 13:14:59 »
welp im an idiot, i didn't even consider that possibility
but that means custom weight prints will not be anodized and will be silver colored?
    • zFrontier
« Reply #43 on: Fri, 02 March 2018, 20:56:35 »
The custom prints are actually laser engravings. The laser not strong enough to make a dent, but it removes the dye (yes anodized colors are dyed into the anodized surface) and leaves a silver / off-gray mark
Offline AIRPOTTER
« Reply #44 on: Sat, 03 March 2018, 01:43:16 »
Hello, big fan of the Warriors :thumb:Like your offensive super fire and defensive mobility.. :D
But there are some bad news, that is, the laser radium carvings can only be carved monochromatic :(, refer to this picture
And the golden blue is a little chromatic aberration with the yellow and blue of the warriors.
    • zFrontier
« Reply #45 on: Tue, 06 March 2018, 04:42:46 »
We have less than 10 spots left  ;) Dont forget to join!
Offline cldskt
« Reply #46 on: Tue, 06 March 2018, 12:50:14 »
Question: If we choose the option of customizing nameplate, will the default nameplate still be given to us (i.e. uncustomized one / "Gray Cod67")?
Offline vtachkov
« Reply #47 on: Tue, 06 March 2018, 12:53:33 »
That's correct. That is explained on the additional components page. If you get a customized nameplate or weight, you'll still receive the default nameplate / weight in the color you chose on the main page.
Offline cldskt
« Reply #48 on: Tue, 06 March 2018, 14:01:18 »
Ah. Somehow I missed it. Thanks for the clarification!
Offline mankikami
« Reply #49 on: Tue, 06 March 2018, 20:30:10 »
Is there any way I could purchase the customization service without paying the extra shipping fee?
