Author Topic: second project.. 40 percenter  (Read 2497 times)
Offline kgolden
« on: Mon, 26 February 2018, 13:58:53 »
I wasn't planning on building a 40 percent but things happen...
edit: just a note on a few of the keys, this is only a temporary set. There are a few keys that do not match what the key really is (IE win and alt keys)
Also thank you JDCarpe for the help!!
« Last Edit: Mon, 26 February 2018, 20:24:59 by kgolden »
Offline jimirolln
Re: second project.. 40 percenter
« Reply #1 on: Sun, 04 March 2018, 01:00:25 »
i feel the beauty of the 40 is the split space bar, so half of the bar can be cleverly utilized hacking the function layer...however i am interested to know how you navigate thru your function layers...it is a wonderful board...i dig it...looks good
Offline kgolden
« Reply #2 on: Sun, 04 March 2018, 20:07:21 »
Thank you. I'm still getting used to the layers. But I press the FN key to move up a layer. With this key cap set I cannot tell the second layer keys... I just try to memorize the keys I need. I actually go back and forth between this JD40 and my Phantom TKL. But I also have a GH60 that I'm building, just waiting on parts to arrive.
edit: see below, I had altered the key caps.. The FN key is there now.
« Last Edit: Sun, 04 March 2018, 20:12:34 by kgolden »
Offline jimirolln
« Reply #3 on: Mon, 05 March 2018, 17:02:53 »
nice...the function layers are crowded on the 40...i'm workn on a planck right now...waiting on parts for my first hhkb clone...the layout has grown on me since getting into the hobby but the materials and cost of the original board i don't feel are justified...i found a nice chiwi case that supports the hhkb layout and picked a key cap set...building boards is life...good luck with all of yours
« Last Edit: Mon, 05 March 2018, 17:04:47 by jimirolln »
