Author Topic: Urgently need help with Model M repair!  (Read 2889 times)
Offline snarfarlarkus
« on: Mon, 26 February 2018, 22:01:31 »
Hey guys I'm trying to repair my Model M... My spacebar hammer is loose, does this mean I have to open up the board and seat it? I've tried seating the spring on the loose hammer and it doesn't buckle, it just becomes like a linear switch and I don't think it registers. Any suggestions on what to do? Thank you!
Offline captsis
  • Formerly matt2dlg
Re: Urgently need help with Model M repair!
« Reply #1 on: Mon, 26 February 2018, 22:52:50 »
Sounds like busted rivets to me.
« Reply #2 on: Mon, 26 February 2018, 23:35:31 »
The M is bolt modded, sorry forgot to mention
Offline Techno Trousers
  • ʘ_ಠ
« Reply #3 on: Mon, 26 February 2018, 23:50:22 »
Are the bolts around the spacebar loose? At least you have the option of taking it apart and seating the flipper properly.
« Reply #4 on: Mon, 26 February 2018, 23:56:32 »
No nothing is loose as far as I am concerned... Is there anyway to fix water damage as well? A few keys are not registering and I believe it is because of water damage.
  • ʘ_ಠ
« Reply #5 on: Tue, 27 February 2018, 00:06:41 »
It sounds like it's had a tough time. Since it's already bolt modded, I'd recommend disassembling it, carefully washing and thoroughly drying everything (except the springs and electronics), then bolt it back up.
  • ʘ_ಠ
« Reply #6 on: Tue, 27 February 2018, 00:09:12 »
I should say too that you can get replacement membranes from Unicomp if yours is damaged. You just have to let them know the model number for your keyboard. You can also send the whole thing in for a repair/overhaul by Unicomp, but they may also "fix" the bolt mod by re-riveting the barrel plate.
« Reply #7 on: Tue, 27 February 2018, 00:26:03 »
What parts do you think were damaged in the water damage? Is it just a hammers/membranes? THanks
  • ʘ_ಠ
« Reply #8 on: Tue, 27 February 2018, 14:42:17 »
I'm not an expert, just guessing that if water penetrated the membrane it might need to be replaced. Other than that, probably just a risk of rusty springs.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #9 on: Tue, 27 February 2018, 16:02:35 »
Not unless it's been sitting underwater outside in the rain.   For a year.  It may need to be disassembled and wiped down but short term water exposure will not impact the membrane in any lasting way.   Might short the traces while it's in there, but cleaned up it should be fine.
  • ʘ_ಠ
« Reply #10 on: Tue, 27 February 2018, 17:06:02 »
Well, he said there was water damage. Maybe it was recovered by deep sea divers. ;p
Offline Aer Fixus
  • And now, back to lurking...
« Reply #11 on: Wed, 28 February 2018, 16:46:22 »
If it's bolt modded, your bolts could be too tight and pinning the hammer between the rubber sheet and the barrel plate and preventing it from pivoting. I'd loosen up a few of the bolts in the general area of the problem and see if that improves things.
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
