Author Topic: Is it possible to change keycap profile on all keyboard  (Read 5387 times)
Offline demas
« on: Tue, 27 February 2018, 10:12:23 »
Hi,
I have Jazz AK60 keyboard.
I want to change all keycaps beacause the default ones is too glossy.
And I think about to change the profile of all keycaps. As I see now I have OEM keycaps.  I want to get Cherry profile.
Is it possible to change the keycap profile for all keys in the keyboard ?
Offline xondat
  • i'm not a star
Re: Is it possible to change keycap profile on all keyboard
« Reply #1 on: Tue, 27 February 2018, 10:16:27 »
Your keyboard is basically what every single Cherry profile set starts with, so you won't have any trouble finding a set that will cover it completely.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2 on: Tue, 27 February 2018, 10:16:39 »
Not all keyboards will support all profiles. On some hi profile cases, the sides are too close to the switches for SA keysets, but aside from that, yes.
For your board, you won't have any issue swapping from OEM to Cherry profile.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #3 on: Tue, 27 February 2018, 10:18:21 »
Looks like the AK60 is a standard layout.
