Author Topic: What is GH60? GK64 == GH60 ?  (Read 23902 times)
Offline demas
« on: Tue, 27 February 2018, 15:48:15 »
I have GK64 keyboard and I am looking for options to customize it - change case, keycaps and so on.
I have found many cases for GH60.  What is the GH60 exactly ?  it is all 60% keybords, right ?
Can I use GH60 cases for GK64 (this, for example https://ru.aliexpress.com/item/Iqunix-lambo-60-mechanical-keyboard-anode-alumina-shell-base-gh60-poker2/32677061753.html ?spm=a2g0v.10010108.1000016/B.1.763c650aLzBTy2&isOrigTitle=true) ?  Are the sizes and the places for screws the same ?
And more general question: can I use something (cases, keycaps) for GK64 if it is labeled as GH60.
Thanks.
Offline xondat
  • i'm not a star
Re: What is GH60? GK64 == GH60 ?
« Reply #1 on: Tue, 27 February 2018, 15:51:10 »
GH60 is one of the first 60% PCBs designed by the community, hence GH standing for Geekhack.
Can find most information here: https://geekhack.org/index.php?topic=34959
GH60 compatible generally means that it works with 60% PCBs as there is somewhat of a standard on the screw in placements etc.
GK64 has a different ZXC row, so compatibility between GK64 and GH60 probably doesn't cross over. I'm not too educated on what the GK64 is though.
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #2 on: Tue, 27 February 2018, 20:10:23 »
GK64 plates won't work on the GH60 or any 2.25u 60% PCBs.
GK64 cases use different mounting positions to the normal Poker-style cases. However the GK64 PCB supports Poker/gh60 cases.
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline whiskerBox
« Reply #3 on: Sun, 04 March 2018, 07:46:28 »
Found that the gk64 will fit in the kbdfans 5° case, and I was even able to use the dz60 plate that they have listed as well.
One thing I noticed though is that I think this pcb will need some shielding with this case, maybe some polyimide tape on the PCB.
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline demas
« Reply #4 on: Sun, 04 March 2018, 09:59:55 »
Does it mean that I can use GH60 wooden case (https://ru.aliexpress.com/item/gh60-poker-keyboard-wood-case-Black-walnutWood-Scented-RoseWood/32734682512.html) for GK64 ? As any other GH60 case.
Offline whiskerBox
« Reply #5 on: Sun, 04 March 2018, 10:13:45 »
Guy at work uses a gk64 with a wood case for kbdfans, works just fine.
Offline demas
« Reply #6 on: Sun, 04 March 2018, 13:19:14 »
Thank you.
Offline mike-y
« Reply #7 on: Thu, 08 March 2018, 16:41:39 »
The GK64 pcb is compatible with most GH60 cases.  The only issue I've run into are some cases that have a larger screw boss.  The hot swaps sockets will sometimes hit interfere with the screw boss if it is bigger than normal.  I had have a wooden case for mine, and have to file down the lower right screw boss to avoid interference.
Most aluminum cases fit fine though.
