Author Topic: Smashed PS/2 cable  (Read 2407 times)
Offline Phaedrus2129
Smashed PS/2 cable
« on: Tue, 06 April 2010, 07:54:15 »
So, the PS/2 cable on my G84-4100 got smashed in my suitcase while on vacation. I've tried bending the metal back into shape, but it's no use. The connector is futzed.
So is there any way to fix this? Say, cut off the connector, take a connector from another keyboard, braid, solder, electric tape them together?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
Smashed PS/2 cable
« Reply #1 on: Tue, 06 April 2010, 08:01:56 »
Well, you've answered your own question...but it's probably easier/cleaner looking to just take the whole cord off another keyboard so the uglies of the repair are hidden inside the case (assuming that keyboard has the space inside to accomodate said uglies of the repair).
kishy.ca
Smashed PS/2 cable
« Reply #2 on: Tue, 06 April 2010, 08:12:55 »
Hm... Do you think I could just take the whole cord off the controller PCB of another keyboard?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
Smashed PS/2 cable
« Reply #3 on: Tue, 06 April 2010, 08:24:07 »
It'd have to have the same connector on the PCB and that same connector would need to have the same pinout unless you know how to rearrange pins in the connector.
Guidelines:
-Never trust colour codes.
-Do not connect it and hope for the best.
-Always check pinouts with a multimeter or equivalent.
kishy.ca
Offline Rajagra
Smashed PS/2 cable
« Reply #4 on: Tue, 06 April 2010, 08:33:47 »
Find 2 PS/2 extension leads. Cut the male connector off one and attach it to the keyboard with only an inch or so of the original cable. Voila, quick release connection.
Smashed PS/2 cable
« Reply #5 on: Sat, 10 April 2010, 17:15:21 »
Fixed, I think. Managed to bend it into shape using some pliers. I've tried it with my Socket A file server and am using it through a USB adapter on my main PC. I'll try it straight to the motherboard next time I reboot.
Thanks for the tips, all. ;)
